3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High-Torque Steering Mechanism for really large Remote Controlled toys
This 'ible leans heavily on instructions given in my previous 'ible on building a pannable vision system. As such, it's a little less step-by-step and more a photographic tutorial on the concepts involved.
The position sensor feedback circuit used in this steering mechanism is the same as that used in the previous 'ible, a simple potentiometer.
This is the steering rig I build for my ATRT (All Terrain Robotic Trike) vehicle. You can see that in action here, if you like. The panning vision system that I covered recently was built later, to be an add-on module for the ATRT, so covering this subsytem now is kind of back-tracking for me.
I think this system could be adapted to other large 3-or-4 wheeled remote control vehicles or robots. Adding a suspension system or all-wheel-drive would probably complicate the system of tie rods needed, but it could still be done.
Step 1Build steering knuckles
Ok, this step is not an easy one. You will need a fairly large sheet of scrap sheet metal, and several pieces of additional metal to reinforce the mounting points for the tires.
If you have invested in a welder and a cutting torch, then you will probably enjoy this step a lot more than I did. I did my cutting with a metal blade in a jigsaw, and by hand with a hacksaw. I used a power drill for all of the holes, and lots of nuts and bolts in lieu of welding.
I did get a good deal on nuts and bolts: 80 metric M6 machine screws and matching nuts in a convenient organizing case at the local dollar store. I guess it's because they were metric, that the normal retail stores didn't buy them.
Feel free to use or adapt the imperfect hand-drawn pattern that is shown.
10 comments
Sep 7, 2010. 6:02 PMvareah says:
I am currently doing a project similar to this project.Programming of PID Controller on Vehicle Platform via Bluetooth. I am required to upgrade the steering with feedback. any recommendation??
May 27, 2009. 5:27 PMsnowpenguin says:
I saw this and thought, RC Office Chair, w00t!!! Oh well.
May 28, 2009. 9:47 AMsnowpenguin says:
Ummmmmmmmmm..... No... Maybe.... Yes? I don't know. It would be pretty cool though. Just imagine ,you're sitting in your cubicle and you look back only to see an office chair drive by.... With no one in it!
Feb 14, 2009. 3:01 AMlemonie says:
If I understand this correctly the motor unit uses the thread on the steering rod to crank it along. You've got a hex-nut on the rod with the blue gear teeth on the outer which driven by the motor and held in place by metal plates. How fast does this move, e.g from central to full-lock? L
Feb 14, 2009. 2:28 PMlemonie says:
It's a fairly tight pitch thread, and none too smooth I guess. But seems to work OK nevertheless. Had you considered a cam mechanism instead? I think that whatever is used, like you say, a more powerful motor would give better response. L
Feb 14, 2009. 4:15 PMlemonie says:
This is a solid worm-type mechanism, it's not going to shift unless it breaks, so that's a good feature. If you had one you'd want to worm the can (pun there?) but you'd probably find the parts hard. I like the use of bits here - it's simple and it works. L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:psymansays
Hi, I'm psymansays. I'm an engineer from California. I enjoy sunsets, and long robot test drives on the beach. More from me: http://psymansays.deviantart.com/ http://www.youtube.com/user/mobilisC...
more »
