Step 2The Parts List
(6) 470 picofarad, 20KV Ceramic Doorknob Capacitors.
(6) HV03-12 12KV PIV High Voltage Diodes.
(7) Brass or copper wiring posts (homemade).
(8) 8-32 x 1 in. brass screws.
A length of 50KV High Voltage wire for the output.
A length of 20KV High Voltage wire for the input.
A length of 12ga. Stranded wire for ground.
(3) #8 Wire lugs.
(1) Ziploc Food Storage Container big enough to hold the multiplier(not a bag).
(1) qt. Mineral Oil.
RTV Silicon Rubber Sealant.
NOTE: Only the voltage rating on the components is critical.
The higher the rating, the higher the input voltage can be, resulting in a higher output voltage. The input limit on this design is 10KV (with safety margin built in). Ignition wire or coax cable with the shield removed may be substituted for high voltage wiring if need be.
I think your answer is no because the 1n4007 does not have a fast enough switching speed. At high enough frequency like in the kHz range the diode would conduct backwards. Here a youtube link i saw this at. It starts at 3:02
http://www.youtube.com/watch?v=cyhzpFqXwdA&feature=endscreen&NR=1
