3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High Voltage Multiplier
Step 3Build It!
Build It!
  • C:\Documents and Settings\Owner\My Documents\My Pictures\gen032.jpg
  • C:\Documents and Settings\Owner\My Documents\My Pictures\gen034.jpg
  • C:\Documents and Settings\Owner\My Documents\My Pictures\PowerSupply\finished.jpg
This step isn't rocket science, just common sense building techniques. Just copy the design shown with the binding studs added.
Start by cutting (7) pieces of 16 guage brass or copper wire two inches long. Bend each piece around a drill bit and shape with a loop at one end.
Next, cut the heads off of four of the screws to make the studs that join the capacitors together.
Screw a stud into one of the caps. Place a binding post over the stud and screw on another capacitor. Screw in another stud, place a binding post over it and screw on the last capacitor.
Repeat the previous step to create two stacks of three caps each.
Lay the two stacks side by side with the binding posts pointing up.
Cut the four remaining screws to 1/2 inch long.
Attach binding posts to the right side end of each stack using a screw.
Attach a binding post to the left end of the bottom stack using a screw.
Attach the diodes as shown and solder them to the binding posts.
Cut off any excess binding post tops and file them flush to the soldered diodes. No sharp edge here or you will get an unwelcomed breakover which could ruin your project.
Attach the wires with lugs. Tighten the screws and make sure the entire assembly is tight.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:burningsuntech
A long life and lots of opportunities to engineer some neat stuff is what Im made of. There isnt much I dont like to build or tinker with and my projects run the gambit from computer toys to high vol...
more »
