High Voltage Power Supply For Marx Generator
 by Plasmana
Some of you are asking me to post an instructable about how to make an high voltage power supply to power the Marx Generator on this instructable.
Well, here is the instructable you have been waiting for!
The device we are going to use to make a power supply for the Marx Generator is called Cockroft-Walton Voltage Multiplier, now that is a lot of words, so what most other people call it is what we are going to call it, the Voltage Multiplier.
This one is a different design from the one I used for my Marx Generator, I was going to post the other design, however, it was quite difficult to build, so I came up with this new design.
The new design has more advantaged over the old design, I will explain them:
  • Easy to build
  • More efficient
However, the new design has one disadvantage, it requires mains electricity, but that is not very much a problem, we can just add fuse (and safety resistors if you want). At least it is easier to build!
Disclaimer: This project is very dangerous to operate, it generates high voltages (6000 volts). Please do not attempt to build this voltage multiplier unless you are familiar with high voltage. I am NOT responsible what ever happens to you and others with this voltage multiplier.
Step 1: Get the things!!
Depending where you live, get the things that will be suitable to your mains power..
If your country uses 110v or 120v, get the things as listed:
  • 34 1N4007 diodes
  • 34 100nF film 200v (or greater) capacitors
  • 100mA fuse
If your country uses 220v or 240v, get the things as listed:
  • 18 1N4007 diodes
  • 18 100nF film 400v (or greater) capacitors
  • 100mA fuse
The X2 capacitors will also work well, that is what I used for this voltage multiplier.
(UPDATE)
I got the diodes and the fuse from Farnell. I got the capacitors from Maplin, however, the capacitors are no longer stocked at Maplin, But you can still get it from Farnell. Here is a list of things you will need to get if you are going to buy the components from Farnell.
1N4007 diodes
100nF film 400v capacitor
100nF film 200v capacitor
100mA fuse
willstr1 says: Aug 23, 2012. 11:58 AM
is it possible to create a semi variable version if I had a way to change which stage it connects to?
like if i connected at the beginning and between 20 and 21 would that lower the voltage but keep the other stages so that I could switch to a higher voltage if i need it (of course shutting down and unplugging and waiting (so that all charge is gone in the capacitors) before doing the transfer) or would that mess up the components that aren't in use?
willstr1 in reply to willstr1Aug 23, 2012. 12:13 PM
Also is it possible to add more stages and get a higher voltage? I need 10+kv for a ion lifter.
my wookie in reply to willstr1Apr 20, 2013. 8:06 AM
yes to the second one but as for the first one it would only discharge as you switched it it would still work though if you don't mind waiting for it to charge again
zmilosavljevic says: Mar 16, 2013. 10:58 AM
Why do we have to use a 100mA fuse exactly? Could we use one with another value, like for example 500mA? What would be a the difference?
my wookie in reply to zmilosavljevicApr 20, 2013. 7:56 AM
i didn't use a fuse when i made mine, and my little brother decided to short the input voltage... he got a big yellow spark and decided it looked cool. i kept hearing a bang in there so i went to check it out and i got there right as he blew the breaker. then my dad made me take it apart.
plasasesamo22 says: Dec 14, 2012. 4:58 PM
Hey! If i have a little stun gun that make 100v from 2 batteries and i want more voltage.
You think it will work if i put one voltage multiplier like this?
my wookie in reply to plasasesamo22Apr 19, 2013. 6:36 PM
: ( old post, better late than never, if its AC then yes but i doubt it. its most likely DC if it came from 2 batteries.
mshbi says: Mar 10, 2013. 8:29 PM
After I made mine and measured the voltage it measured the same as the input. Anyone know what is wrong?
正安 says: Dec 3, 2012. 1:02 AM
I use a variac transformer which can output 0~260VAC(5A) and then connect a Cockroft Walton Voltage Multipliers which use camera capacitor 104/1KV and 1N4007 as diode.
I made it series connection about 10 stages,theoretically it can output 10X(input voltage),but I didn't get that much. Here is my situation:
10VAC→100VDC
20VAC→180VDC
30VAC→240VDC
40VAC→300VDC
50VAC→360VDC
60VAC→400VDC
70VAC→450VDC
80VAC→500VDC
90VAC→520VDC
100VAC→560VDC
Is there anything wrong?Why can't i get that 10 times voltage?
kanni1303 says: Sep 4, 2012. 8:37 AM
I tried this one but it is not working.
I used
2G104J capacitor and
IN4007 diode
with 200mA fuse
and power supply from mains, I live in INDIA
and my supply is ~230V
Quyzi says: Aug 13, 2012. 7:09 PM
Does it matter if hot and neutral are swapped? I can't find a polarized plug :(
amaziliauskas says: Jun 12, 2012. 2:55 AM
hi,how much is one stage ?plz tell me(sorry for my language)
Higgs Boson in reply to amaziliauskasJul 17, 2012. 7:47 AM
Every stage adds another input onto the output (if each stage consists of two capacitors and two diodes). If there were only one stage then the output would be double the input. Every stage you add after that adds another input voltage onto the output.
AChillyDog says: Jun 18, 2012. 6:45 AM
Could i use 6000 volts to make it put out huge voltages?
Higgs Boson in reply to AChillyDogJul 17, 2012. 7:45 AM
You would need caps rated for much higher voltages if you did that.
amaziliauskas says: Jun 8, 2012. 1:47 PM
hi,how much is one stage?
Dreistein says: May 1, 2012. 2:12 AM
hey i'd like to make a device i can attach to say my foot ,that if i touch someone they would get a shock basically like when you walk with socks over a carpet but the effect is automated. A guy made an ible http://www.instructables.com/id/The-mini-electrostatic-generator/ where he makes what im describing but its not very detailed. any ideas?
Dreistein says: May 1, 2012. 2:11 AM
emihackr97 says: Feb 11, 2012. 12:40 PM
Hi, I want to build your marx generator, but on the video from that 'ible, you power it all from a single AA battery, is it possible to get the schematic for the inverter circuit, an also, you say it outputs 450v, so how may stages of Caps-Diodes will I need?
Thanks,
emihackr97
Kalace says: Jan 19, 2012. 3:52 PM
Does this plug into the wall for power, and if so does this trip the circuit breaker often?
Kalace in reply to KalaceJan 19, 2012. 3:56 PM
I live in US so i get 120volts
reed00112 says: Jan 11, 2012. 1:42 PM
So say i wanted a reeeally low output current for ultimate safety and i used a 2M Ohm resistor in series with the output. What kinda current would we be looking at? and what voltage drop should i expect ?
Help will be greatly appreciated!
Speedmite says: Dec 4, 2011. 8:31 PM
I was just wondering, If I built this multiplier, could it feed into a larger multiplier such as this one?
http://www.instructables.com/id/High-Voltage-Multiplier/
Or would everything need higher ratings?
Robdei says: Nov 29, 2011. 5:18 PM
would some 1 picofarad ceramic 500v capacitors be able to substitute for the film capacitors?
AGT563 says: Nov 24, 2011. 7:37 PM
I am working on something like this, but much smaller and independent of mains power, I will be posting it soon. on another note you mentioned that have asperger syndrome, I have asperger syndrome as well, and I am also a bit odd.
robot797 says: Nov 24, 2011. 4:51 AM
i need around 50KV adjustable fron 30KV to 70KV
can it be done with this?
sholtob says: Nov 21, 2011. 11:38 AM
do you connect the live wire from the mains voltage to the hot pin and the neutral to the earth?
zapurva says: Sep 18, 2011. 12:20 AM
Wouldn't 18 stages for a 240V input supply require 36 capacitors and diodes? As per my calculations 1 stage requires 2 capacitors and 2 diodes..
manicmonday says: Nov 21, 2009. 6:17 PM
Does anyone here know how to use one of these to make a Negitive Ion Generator? I'm in the USA using 120vac.
Thanks
FurtherThanTesla in reply to manicmondayJun 24, 2010. 1:06 PM
Im pretty sure that you just switch the ac input wires on the voltage multiplier. That way, the 6kv output will be negative relative to ground. Look it up on google images, because i know I saw a schematic for a negative ionizer that pretty much just had the leads switched from what this guy has
yaly in reply to FurtherThanTeslaAug 22, 2011. 3:54 PM
there is an instructable on that.
DELETED_Robert L says: Jul 11, 2011. 8:36 PM
(removed by author or community request)
Nico N. in reply to DELETED_Robert LJul 26, 2011. 12:43 PM
Hi Robert, I think that in the instructable for the marx generator, Plasmana made his own custom made one that runs off of 1.5v (AA battery). THIS instructable is an alternative that YOU can build that uses 110. This is what I think. I really don't know
Umniscient says: Jun 23, 2011. 11:16 AM
Two questions:
1. Am I correct in saying that each capacitor should be rated for twice the *input* voltage? That is, can I add more stages without changing the ratings?
2. My country uses 110 volts. Should my capacitors be rated for 200VAC or 200VDC?
Thanks!
pyroten says: May 23, 2009. 6:14 AM
Hmm. I'm in a bit of a hard position. I live in Australia and i can't order things online. All i can really use is this hobby store (Jaycar) so i need to substitute everything because i can't find exact matches for the resistors and caps.
Soooo.... Could the:
  • 400v 100nf caps be substituted for two 250v 100nf caps connected in series?
  • 50k 2W Resistor be substituted for two 27k 1W resistors in series?
So what I'm kind of getting at is what can i change around to what effect.
Thanks in advance :)
TANN-MANN in reply to pyrotenJun 4, 2011. 1:30 AM
No probs in Australia, Order online at http://au.element14.com, its all we aussies could need, Jaycar is good, but you will need to order most things...Yeah I know this was posted a few years ago but hey just helping
lasermaster3531 in reply to pyrotenSep 23, 2009. 11:12 AM
for the resistor that will work, but you need to have the caps 200nf each in series to get 100nf together.
volthead in reply to pyrotenSep 14, 2009. 5:20 PM
Try a hobby store which also stocks altronics parts I am about to pick up 10 2.2nF 3kv caps and 30 1n4804 diodes. It depends where you are I am in Bendigo so I have PCB electronics.
duckythescientist in reply to pyrotenMay 28, 2009. 2:32 PM
two 250v 100nf caps in series would give you a 500v 50nf cap. You want two 250v 200nf caps. When caps are put in parallel, the capacitances are added and the maximum voltage becomes the smallest of the maximum voltages of the caps in parallel. When caps are added in series, the voltages are summed (at least when all the voltages are the same) and the resulting capacitance is the harmonic mean of the capacitances. This is the reciprocal of the sum of all the reciprocals of each individual capacitance. Meaning Ctotal=1/( 1/Ca + 1/Cb + 1/Cc ...)
I hope this helps. If I am incorrect, Instructables community, please correct me.
dumle29 says: May 11, 2011. 1:13 PM
does it matter where you connect the neutral and where you connect the phase?
tobyscool says: Mar 12, 2011. 9:17 AM
will this need a 555 timer circuit or it will switch automatically?
jaydenr says: Mar 3, 2011. 12:16 PM
if i build a full wave multiplier with 33 the caps of the same value and the same diodes will it work just as well? also, what is the advantage of building it half wave? and does it matter if the caps are film or ceramic?
Mudbud says: Feb 25, 2011. 8:38 AM
does the input 'Have' to be 120 or 240v? can I just use 16vAC instead? I know it won't generate as much but I will just add more stages to it then.
grampafish says: Feb 12, 2011. 8:38 AM
Could this be driven off of a 330V disposable camera flash circuit
galan0121 says: Jan 27, 2011. 11:36 AM
hi I'm french sorry for my spelling! I had a question... On the first alternate, C1 charges to the peak voltage (325V in my case) and on the second alternate, C2 charges to 2 times the peak voltage (ie 650V). But the problem is that the capacitors are only 400V rated. Can they support such a voltage ?
Thank you for your help, you do a great job!
ziga321 in reply to galan0121Feb 3, 2011. 1:21 PM
Because the voltage which PASSES THROUGH the element is important and not the overall voltage. look up in google for 'voltage difference'.
ziga321 in reply to galan0121Feb 3, 2011. 1:14 PM
jaydenr says: Dec 30, 2010. 12:22 PM
Please can some one tell me where to buy these components in the u.s.a.?
buckminsterfullerene in reply to jaydenrJan 13, 2011. 6:59 PM
Digikey is the best:
 Capacitors- http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=95211150&uq=634305487000988323
Diodes- http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=95211209&uq=634305487000988323
Fuse- http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=95211302&uq=634305487000988323
ziga321 says: Jan 2, 2011. 5:02 PM
What's the max.current using this particular caps and how can I calculate the max.current using different capacitance?
boi tata says: Dec 7, 2010. 4:06 PM
Any special reason on this picture??? I mean, the caps are inverted when soldering (in one cap you the the inscription and other no and other yes and go on....) On a picture ahead, all inscriptions can be seen!!
gammaraptor says: Mar 3, 2010. 4:52 PM
anyone know a cheap place to buy the capacitors in canada? I need 34 caps, and i don't want to pay 20 bucks for it.
geek10102 in reply to gammaraptorNov 28, 2010. 11:13 AM
try using simple spark gaps
if air is a dielectric
then in essence a spark gap is a cap
that what I'm trying anyway
Andreonh says: Nov 9, 2010. 10:48 AM
I am a student at omaha Benson High, my class is trying to build your cockcroft-walton voltage multiplier scaled down, and are running in to some problems. we are using 1N4007 diodes and .003uf 400 volt capacitors we have an input voltage of 6.5 according to our digital osciloscope. our ac powere suply gives us a nice little sine wave. at our fist stage we read 16.5 volts, but when we add a second stage we get a voltage reading of 5.5. any suggestions or ideas as to what we are doing wrong.
sincerly,
Nick Ramm
NHS Vice President
nmrRamm@cox.net
CombineOverwatch says: Nov 8, 2010. 5:29 PM
can you use any less diodes and capacitors with it still working?
grampafish says: Nov 5, 2010. 4:34 AM
could this be powered off of a camera circuit
ARJOON says: Oct 27, 2010. 2:48 AM
Hello plas3manan
w9ill it w9ork if i use the current from your flyback tran3sformer to get even higher voltage. i made mine my arcs3 are only about 36-40mm (about 35kv) long. if i us3e the voltage multiplier w9ill i get longer arcs???????
coolfordy says: Sep 29, 2010. 9:54 PM
if i would build one of these with 6 stages of 240v could i use it to power a flyback ?
spork969 says: Nov 10, 2008. 1:50 PM
"Each stage will add on another 120v or 240v to the voltage multiplier." But 120 x 34 = 4080, not 6000. Do you have your numbers right, or am I missing something?
Plasmana (author) in reply to spork969Nov 11, 2008. 2:56 PM
You missed something...
When the mains AC is converted to DC, the voltage would be higher, because of the peak voltage in the AC lines...
The peak voltage of 120v AC is 179v.
The peak voltage of 240v AC is 339v.
So...
179v X 34 = 6086v
Very close to be 6000 volts.
Gonzik in reply to PlasmanaSep 11, 2010. 8:56 AM
False, the peak voltage of 120V AC line is 169.71V. Remember 120V is the RMS thus the peak will be 120*sqrt(2) = 169.71V. Please correct me if I am wrong.
electricfan in reply to PlasmanaMar 22, 2010. 1:03 PM
Plasmana (author) in reply to electricfanMar 23, 2010. 2:50 AM
No, you will get about 6Kv, not 3Kv, use google to learn more about voltage multiliers.
Padlock in reply to PlasmanaJan 16, 2009. 5:17 PM
Wait... I'm missing something here... 120 VAC is the RMS value. So when you put that voltage into the the converter, the capacitors would charge to 120 Volts... Unless you didn't rectify it? But I can't see how this would work then, because up on a previous comment you said that it would work with Electrolytic Capacitors, which are polarity dependent. "Yes, you can use electrolytic capacitors or ceramic capacitors, but they are not as efficient as the film capacitors..."
spork969 in reply to PlasmanaNov 11, 2008. 3:41 PM
Oh. Thanks. So I can assume that I'm getting 179 volts out DC for every step I have? I need it to be pretty precise. Also, is this a single burst of voltage, or is it continuous?
Plasmana (author) in reply to spork969Nov 12, 2008. 2:57 AM
Yes... It is continuous.
deckland says: Sep 9, 2010. 9:13 AM
i live in the uk (240v) and i made this with 30 2x 220n capacitors rated at 270v ac and 30 diodes (1a 1000v) and when i switch it on and point the end to neutral all i get is a measly 1mm spark.. its bright and quite loud but thats all i get... and i havnt got resistors it this.. i checked all the joints and listend for hissing but it seems as though theres no electrical leakeage. could someone point me in the right direction on how to get this working please... ? please email me at d-e-x@hotmail.co.uk
regards
Declan
jcolefran says: Sep 1, 2010. 10:03 PM
if i substituted these capacitors for 1kv ones like these ,
could i attach your 'worlds smallest shocker' ? (450v output)
and if so would i have to use different diodes?
thanks.
brooklynlord says: Apr 18, 2010. 10:44 AM
When i solder, why are all the joints not shiny? like, they aren't smooth, they aren't shiny.......
p8ntball37 in reply to brooklynlordAug 17, 2010. 2:22 PM
try a hotter slodering iron. its not hot enough.
squalyl says: Jul 11, 2010. 10:36 AM
Can I add more stages to get an even higher output voltage?
mojarabm2 in reply to squalylJul 14, 2010. 2:26 AM
sure you can ! you will get greatest voltages if you add more stages. but take care if youre a amateur cuz it can be SO much daneger than your healt can take. tell me if you done it.
ampeyro says: Jul 5, 2010. 3:21 PM
do you(or anybody else) know if i can do that with different capacitors(diferent capacities in the same circuit)? i'm trying to use recycled parts because i don't want to buy 10 hv capacitors, the "hardware store" is in a very small city and i don't want to scare my neighbours
Ch.Sachin says: Jun 24, 2010. 5:10 AM
Can we use 250v DC as an input
Plasmana (author) in reply to Ch.SachinJul 2, 2010. 10:21 PM
No, it must be AC, DC won't work.
Ch.Sachin in reply to PlasmanaJul 3, 2010. 1:48 AM
Thanx for the help....
HazzWold1993 says: Jun 18, 2010. 7:27 PM
The capacitors are DC so does it matter which way you run them in this setup?
Plasmana (author) in reply to HazzWold1993Jun 19, 2010. 1:50 AM
No, they are bipolar.
dellmang187 says: Jun 10, 2010. 11:31 AM
where is the best place to learn how to read schematics for beginners
Plasmana (author) in reply to dellmang187Jun 14, 2010. 12:49 AM
I just mainly searched google for varouse types of circuit symbles and memberised them.
wil2 says: May 23, 2010. 6:22 AM
Also, your circuit diagram shows three stages, not six. One full "stage" rectification in a CW voltage multiplier is one pair of caps and diodes. Thus the factor that the input voltage is multiplied to is roughly half what you claim if you do 34 stages in this manner, or around 3000V.
Do you think there are any advantages to using a full wave CW design instead of a half wave like this?
gammaraptor says: Mar 2, 2010. 7:08 PM
sorry, i'm kind of stupid. do we have to buy a transformer to make this work?
Wargasm in reply to gammaraptorMay 22, 2010. 7:37 AM
No. This is a Cockroft-Walton voltage multiplier. It will multiply the mains voltage directly. If you don't have much knowledge or experience with HV or AC mains, i wouldn't recommend building this.
wil2 says: May 15, 2010. 8:59 AM
I can only seem to find fuses with 250V ratings and .25-.5 amp maximums. Is this acceptable? My only goal is to prevent the wall socket from being blown. Thanks.
Also, I live in a 120V area, hence the problem with 250V
electricfan says: May 11, 2010. 12:37 PM
Hi, does the doides have to be rated for half the current the cascade is using? For example if the thing is pulling 1 amp, do the diodes have to be rated at 1/2 a amp?
Thanks,
Paul
randomapps says: Mar 20, 2010. 6:40 AM
if i wanted 22kv would i need higher rated diodes and caps?
Plasmana (author) in reply to randomappsMar 20, 2010. 5:03 PM
Nope.
bombmaker2 in reply to PlasmanaApr 18, 2010. 6:04 PM
So that means I could just add tons if stages to achieve higher voltages, right?
randomapps in reply to bombmaker2Apr 19, 2010. 12:22 AM
 yep lets say if you have 240 volts on the input, each time you add a stage it adds another 240 volts to it so you have 480 volts and add another stage you get 1020 volts and so on you can make it as big as you like and if you get a shock of one of the stages there are not enough amps to kill you
bombmaker2 in reply to randomappsApr 19, 2010. 12:47 PM
k thanks. that is what i thought
brooklynlord says: Apr 18, 2010. 10:52 AM
If i just wanted 6 kVs, do i need to adjust the current limiting resistor?
I've also been thinking about having a swtich to switch from 220-240 volts to 110-120 volts.
qwertyboy says: Nov 14, 2009. 8:39 AM
is the resistor to limit current?
garrys newman in reply to qwertyboyMar 7, 2010. 10:29 PM
in fact, if there is an arc inside the box  the resistor will limit the force of it...
imgeek1337 says: Feb 23, 2010. 6:02 PM
can you use 1N4006 800V 1A diodes instead?
alah says: Jul 2, 2009. 2:58 PM
Does 220 AC have to be 1 phase and neutral or could it be two 110AC phases? Thanks, Alberto.
manicmonday in reply to alahNov 21, 2009. 1:09 PM
I don't know about europe, but in the USA 220vac is always made up of 2 phases of 110vac.
Derin in reply to manicmondayJan 28, 2010. 12:12 AM
In Europe it is one neutral and one 220.
discovery in reply to DerinFeb 11, 2010. 8:00 AM
in Europe is 230v.
brooklynlord says: Jan 19, 2010. 8:14 PM
Does it have AC out? And is it safe to use it as a tesla coil transformer?
brooklynlord in reply to brooklynlordJan 19, 2010. 8:16 PM
im in canada so im using 120v power (Or 110v, not sure, but it doesnt really make a difference..... does it?).
Crtek says: Dec 21, 2009. 11:07 AM
why can't this be used as a marx generator?
it does make sparks just like the marx generator, just not as big/long, right?
i wanna use it to ionize some air...could this work (i bet that a marx genarator would work, but i don't know if this is strong enough...if it's strong enough i'll just use this)
please give me some info
sutiteoj says: Dec 19, 2009. 6:01 PM
hello i am new to this site and i was intersted in constructing my own CW voltage multiplier to power a marx generator. I have all the parts for both and ect. but was wondering how do i simply connect the output source of the multiplier to the input if the marx generator. thanks
Arduino Guy says: Dec 4, 2009. 2:33 PM
Can i use this for a Jacob's ladder
qwertyboy says: Nov 14, 2009. 8:41 AM
couldn't you also imerse this in mineral oil?
tulavatalo says: Oct 29, 2009. 8:45 AM
Will this work with a 12vbattery run through an 230
 inverter
stratos13pao says: Sep 21, 2009. 11:17 AM
can i use 0.1uF 400V Mylar Capacitorsinsted of film capasitors
12V says: May 31, 2009. 1:25 PM
please can you tell me the voltage of my transformer i made (using a wire winder that i made) input was about 10-15v pulsing dc at 8va power and it arced up to about 10mm what voltage is this (needed to be closer to start) but soon the transformer started internal arcing and i haven't tested it yet so can you give me infomation on what voltages arc what distance.(1to 20kv)
volthead in reply to 12VSep 14, 2009. 5:16 PM
It takes 4.3 kv over 1mm to start an arc and 1kv over 1.1mm to keep it going.
12V in reply to 12VMay 31, 2009. 1:27 PM
sorry i mean i haven't tested the new one.
joinaqd says: Feb 22, 2009. 6:25 PM
goddamnit i am afraid i dont have so many unpolarized capacitors...is it possible to change the circuit somehow to make it work with DC?
joinaqd in reply to joinaqdFeb 22, 2009. 6:26 PM
i mean to say, that i want to make use of normal capacitors that are polarized...is there a way to do it?
The 4th Doctor in reply to joinaqdSep 8, 2009. 7:00 PM
polarized will work fine just make sure you put them in right. heres an instructable of a multiplier made with electrolytes(i assume thats what you mean by normal) to to charge capacitors.
http://www.instructables.com/id/SQLX7AMFEAQ3X5G/
a cascade like this is current limited by the small size of capacitors and electrolytes are quite larger in capacity and will draw alot of current in a short circuit and something will pop if you try to make an arc (hopefully not a capacitor, electrolytes are nasty)
i got 35 capacitors and diodes for under 5 bucks and 14 dollars for 25 stages worth of capacitors and resistors for the actual marx plus shipping 29 dollers for a 150kv marx generator
long late comment :/
muttyfutty says: Sep 4, 2009. 12:12 AM
Nice! How did you get such nice solder joints? also, if I used much larger capaciters (10uF), (150uF) what would happen? much bigger ampage? can you use 'odd' caps (different capacity)? Thanks, mike
corbin569 says: Feb 21, 2009. 9:44 AM
What would if i hooked this up to the output of a flyback ?
muttyfutty in reply to corbin569Sep 3, 2009. 11:56 PM
it would blow the entire setup, unless you have rated caps and rated diodes (>20KV)
kikiclint says: Aug 24, 2009. 5:15 PM
what would be the effect of putting smaller capacitors or larger ones in instead of the 100 nf? would you get a smaller or larger current?
Evilthingamabober says: Aug 6, 2009. 10:30 PM
Can you use this without mains power?
kikiclint in reply to EvilthingamaboberAug 24, 2009. 5:12 PM
it needs to use a pulsing voltage. I don't think dc will work.
Stuffses says: Aug 22, 2009. 10:59 AM
The http://www.instructables.com/id/Build_a_simple_Marx_Generator/?ALLSTEPS Instructable used a small battery. how can i do that?
Blackice504 says: Jul 29, 2009. 3:31 PM
hi i am very instreasted in this i was wondering can this be used say on a Generator like a Car alternator so that it give really high voltage like 240volt using bigger caps and if so what sort of amps could i pull from this thanks.
joinaqd says: Apr 7, 2009. 5:52 PM
does it work with a strobe light from a disposable camera? that would be cool.
Plasmana (author) in reply to joinaqdApr 14, 2009. 7:47 AM
Unfortunately not, the voltage is too low...
TheDeviant13 in reply to PlasmanaJul 26, 2009. 10:23 AM
I have actually ran a flash tube with a cold cathode light inverter which pushes out around 1kV ac and the way I got it to arc is one of the wires was hooked up to one end of the flash tube and the other was hooked up to the other end and a metal plate and I was able to get it to light up that way but could not even get a single arc without the metal plate so that might be how you would have to do it with this.
JohnMichael in reply to PlasmanaMay 13, 2009. 9:33 PM
Most of the capacitors I have found in disposable cameras are 330V.
codex653 in reply to JohnMichaelJul 25, 2009. 7:23 AM
yeah but then they are discharged through another transformer that steps it up to way way high voltage momentarily and that's what flashes it.
shuhia says: Apr 27, 2009. 6:40 AM
how i build a mini transformer from 9volt to 240vac(vdc)
codex653 in reply to shuhiaJul 25, 2009. 7:24 AM
yeah it's much better to do what jacksonwalters says. i've been trying to build my own transformers for quite a while now, and let me tell you, it's a pain.
jacksonwalters in reply to shuhiaApr 29, 2009. 8:59 AM
You really just need an inverter. Take a wall wart, open it up, and reverse it so that your 9V supply becomes the 120VAC output. Then you can use like one stage of these diode rectifier things and get it to 240VDC.
asim164 says: Jul 22, 2009. 10:08 AM
Can i use 160 mA fuse instead of 100 mA. Also can i ust it directly 18- capacitor "High Voltage Power Supply For Marx Generator" with Marx Generator.. and what precautions should i use while using with it ? THANKS
Questioneverything13 says: Jul 14, 2009. 2:21 PM
I got 1n5408 (1000V 3A) from here
http://www.taydaelectronics.com/servlet/the-85/1N5408-Diodes-Rectifier-3A/Detail
for $2.50 US for 50 of them The place sell active components cheep
http://www.taydaelectronics.com/servlet/StoreFront
shuhia says: Jul 3, 2009. 11:52 AM
can i use polyester?
shuhia says: Jun 15, 2009. 11:01 AM
any one now how to decrease 240volt ac to 12 vac for a relay 12vac
alah in reply to shuhiaJul 2, 2009. 11:28 PM
Best way is using a 220/240v to 12 v transformer. If not, measure the resitance of your relay´s 12v coil and place a power resistor whose value should be 9 times the coilsresistance.
shanemc01 says: Apr 27, 2009. 3:35 PM
does it matter how you connect the capacitors? I'm talking about the polarity. Do you need to start with the positive or negative?
bylerfamily in reply to shanemc01Jul 2, 2009. 11:05 AM
Film capacitors don't have polarity...
build a BOOM says: May 15, 2009. 1:06 AM
I was reading up on spark gaps, and I found out there is the potential for ozone and nitrogen oxides to be produced, by the ionization of air. How real is this risk ?
biolethal in reply to build a BOOMJun 21, 2009. 7:51 PM
they destroy your lungs and they are overall not very healty... ozone for example is used to kill bacteria in hottubs...
gobitz says: Jun 21, 2009. 2:53 PM
what is the input voltage???
bodo says: May 30, 2009. 7:04 AM
hi everyone it is posible but dangerous eventhough use a ignition coil from a car get 30 kv it alon makes grate sparks and is useful in marx generator also
JohnMichael says: May 26, 2009. 3:28 PM
Is there something similar to the "voltage multiplier" that uses direct current?
rzigmu says: May 25, 2009. 7:31 AM
One question. On Wikipedia you have a schematic on how to build a full wave CW multiplier. I've added the standard half-wave schematic too. I am a bit confused about the connections. In your project you have replaced the ground connection for the multiplier with a 0V return wire leading back from the load, correct? So why is it grounded on the wiki schematic?
So if I want to make a full wave multiplier (I'll be using a transformer before the multiplier), the "AC input" wires are live and neutral, "DC output is + x kV and "GND input" is a 0V return wire leading back from the load? Or, does "GND input" connect to the centre tap of a transformer? If so, where's my 0V return? Do I just have to make one from the source to a ground connection? This puzzles me.
Pomno��evanik napetosti Cockroft-Wotton.gifCockcroft_Walton_Voltage_multiplier.png
Plasmana (author) in reply to rzigmuMay 25, 2009. 3:59 PM
For the full wave multiplier, the "GND input" goes to the center tap of the transformer. and the 0V return is "GND input".
rzigmu in reply to PlasmanaMay 26, 2009. 1:01 PM
One more question. Could you just simply split the live wire into two wires and run them into the AC inputs while running the common neutral into GND input (i.e. could you eliminate the need for a center tapped transformer)? Thanks for all of your help and sorry for my bad english :-)
ranzau says: May 23, 2009. 2:41 AM
Would 350VDC at low amps be fine for this. thx
jacksonwalters says: Apr 26, 2009. 12:37 PM
Two questions: How is it that the capacitors only rated at 400V are handling the 6kV and doesn't each stage of this do the exact same thing as the stages in a Marx generator? Why build both?
rocketman221 in reply to jacksonwaltersMay 22, 2009. 6:43 PM
because the capacitors are connected in series. and a marx generator needs a high voltage input (at least several kv) the voltage multiplier just runs off the mains.
xxfoxracer9xx says: May 11, 2009. 3:56 PM
what program did u use to make ur schematic, i cant seem to find any good programs
rocketman221 in reply to xxfoxracer9xxMay 22, 2009. 6:39 PM
I use TinyCad its easy to use and its free.
robot797 in reply to xxfoxracer9xxMay 15, 2009. 5:23 AM
electronic workbench (multi sim) paint (must has steady hand)
xxfoxracer9xx in reply to robot797May 15, 2009. 7:59 PM
wow thats nice for paint
robot797 in reply to xxfoxracer9xxMay 15, 2009. 10:45 PM
i could do it in paint before i had a program i did it by hand or with paint.
HOWITZER says: Feb 12, 2009. 5:08 PM
hi...emm..the input is 127vac???? please help...........
Plasmana (author) in reply to HOWITZERFeb 16, 2009. 2:25 AM
I really don't understand what you are trying to say...?
HOWITZER in reply to PlasmanaFeb 17, 2009. 3:08 PM
hello, my question is: if the input voltage is any 127V outlet in my case
miiwii3 in reply to HOWITZERFeb 21, 2009. 6:59 PM
where the wires do you live?
HOWITZER in reply to miiwii3Feb 22, 2009. 11:29 AM
127Vac
pyroten in reply to HOWITZERMay 22, 2009. 5:57 AM
i think he meant what country ur in lol but i dunno. maybe i'm wrong
ranzau says: Apr 23, 2009. 7:43 PM
would bigger diodes mater
Plasmana (author) in reply to ranzauApr 24, 2009. 12:19 PM
It depends...
build a BOOM says: Apr 24, 2009. 4:16 AM
Is there a way to make this work with pulsating dc
Plasmana (author) in reply to build a BOOMApr 24, 2009. 12:15 PM
Yes, this multiplier can work on full wave AC or half wave AC, (half wave AC is same thing as pulsating DC).
egpacheco says: Mar 11, 2009. 8:25 PM
Plasmana. great Instructable!! congratulations. You can built two multipliers with the diodes inverted and in that way you get one + and one - multiplier with double potential difference. this reduces the ripple that comes out of a longer cascade. One question: the 50k 2w resistance shouldn't be placed in the high voltage output (in the spark gap) instead of in the mains connection?
egpacheco in reply to egpachecoMar 16, 2009. 12:59 PM
I mean you can do something like this (credits, wikipedia):
egpacheco in reply to egpachecoMar 16, 2009. 1:27 PM
By the way my fist cascade is working great. I powered a rotating ion motor, nice sparks and corona discharge inside broken lamps. I also suggest to use at least 100K resistance for safety reason and put them in the HV side of the multiplier so it protects when there is a discharge to ground. Remember that more than 50 mA can stop the heart (I know that the multiplier works with much less than that, but is better to be in the safe side of the road). And Plasmana thanks a lot for your work in this and other instructables!!. :)
Gonras says: Mar 14, 2009. 5:13 AM
Hey ho, I already try for a long time to make that damn simple thing, but It doesn't work !! every single one does work, two in a row works, 3 works still but isn't that effective anymore and 4 stages are getting worse voltage output than 3....!!!!!!!!! so what's wrong with that sh§$%? I have no Idea what to do :(
tulavatalo says: Mar 10, 2009. 7:16 AM
Cab you use this on a 9v battery
11010010110 in reply to tulavataloMar 13, 2009. 6:43 AM
this thing needs ac to work. 9 V battery is dc
you can add 555 chip and h bridge to make 9 V ac
then to get 6 KV you need 6000 / 9 = 667 capacitors and diodes. a bit too much
on low voltage sources an inverter circuit (like circuit with flyback transformer) works better
novice2 says: Jan 4, 2009. 9:49 PM
Plasmana, can you please spare some time to do an instructables on the circuit that you used to drive this voltage multiplier ( the one that used the single AA battery). Thanks.
novice2 in reply to novice2Jan 4, 2009. 11:05 PM
Found it !
egpacheco in reply to novice2Mar 11, 2009. 8:17 PM
Were did you find it? TIA for your help
tulavatalo in reply to novice2Mar 10, 2009. 10:31 AM
Were did you find it pls reply
HVLC says: Feb 24, 2009. 9:55 AM
I have used 4 electrolytic caps 400v 330uF each 2 connected in series .it worked fine but i have been short circuiting output to get sparks(through water). then all of then suddenly blew up. do you think that was because of short circuiting or not? my input peak voltage was the mains 339v so stage voltage was 679v but caps voltage in series was 800v. thx.
Plasmana (author) in reply to HVLCFeb 26, 2009. 6:03 AM
If they are cheep capacitors, then they are most likely have been destroyed by shorting them out harshly. Good capacitors should not blow up by shorting them harshly...
HVLC says: Feb 16, 2009. 7:14 AM
hi I've made a voltage multiplier for 110v ac input ( i converted 240 to 110) (i used the electrolytic caps (68uF 400v), i had 3 cascades, it worked fine.i have got up to 900v. but when i try using ceramic caps instead(222pF 1kv) it doesnt work.(output goes to a few volts). can you please suggest me some idea.(i have already bought 20). thx.
Plasmana (author) in reply to HVLCFeb 16, 2009. 8:13 AM
Your ceramic capacitor multiplier probably works just fine. All multimeters that reads voltage takes up little bit of current, so your voltage multiplier cannot supply enough current to give your multimeter accurate readings. Also, the smaller the capacity rating the capacitor has, the less AC current can go through.
HVLC in reply to PlasmanaFeb 16, 2009. 10:01 AM
thanks
The 4th Doctor says: Feb 11, 2009. 10:13 PM
very nice so if you take out/lower that resister will you get more current until too much current goes threw and parts start frying and with diodes can you add them in series for twice the voltage ratting or in parallel for twice the current ratting thanks in advanced
comodore says: Feb 8, 2009. 6:34 AM
The brown and blue wires go to a male receptacle, right? And than you plug that in into 220V, right? In the schematic there is also a 100mA thing, I'm not shore what that is, what is it??? Thanks!
Plasmana (author) in reply to comodoreFeb 11, 2009. 2:49 AM
Yes.
Close, in 240v.
Thanks!
A fuse. :-)
comodore in reply to PlasmanaFeb 11, 2009. 1:33 PM
Thanks, now that i know everything i need, that wasn't clear to me, now I can build it and finally make a Marx Generator! BUHUHUHAHAHAHAHA *cough * *cough * xD
Thanks!
acaz93 says: Jan 25, 2009. 5:57 PM
Plasmana, I was Wondering if this could be powered with a disposable camera , you know , for increased "mobility"
Plasmana (author) in reply to acaz93Jan 29, 2009. 3:21 AM
It can be powered by a disposable camera, but it burns out too soon and the electronic modification are complex.
Xellers says: Jan 16, 2009. 11:39 AM
What is the approximate current output? I am wondering if I can use this for a Tesla Coil instead of a wimpy flyback transformer, or an expensive NST.
Plasmana (author) in reply to XellersJan 20, 2009. 3:32 PM
You should stick the flybacks, because the voltage multiplier only gives out less then 5 mA...
somethingtodo says: Jan 7, 2009. 9:29 PM
can you use any other kinds of capacitors ?
Plasmana (author) in reply to somethingtodoJan 9, 2009. 12:34 PM
seabeepirate says: Dec 13, 2008. 9:27 PM
I just want to make sure I understand. This will produce DC power correct?
coilguncannon in reply to seabeepirateDec 16, 2008. 8:51 PM
yes because the ac current can not oscillate because of the diodes
seabeepirate in reply to coilguncannonDec 16, 2008. 11:08 PM
Thanks, I never would have thought to try this... I had somewhere in the back of my mind the idea that it was possible, but I don't think I could have figured it out.
trooperrick says: Dec 4, 2008. 7:13 PM
Alright so I did it with 50 stages instead of thirty four, I hardly got any sparks, should I try removing stages or what. Also do the diodes burn out if you heat them to long with a soldering iron?
Plasmana (author) in reply to trooperrickDec 7, 2008. 1:24 AM
Did you make sure all the diodes are facing the correct direction?
trooperrick in reply to PlasmanaDec 10, 2008. 6:46 PM
Yeah, I also made sure all of the solder connections were good.
Plasmana (author) in reply to trooperrickDec 11, 2008. 2:31 PM
Odd.... Try switching the input wires, if that does not work, check the diodes, a single diode that is malfunctioning can affect and become the most annoying problem from the voltage multiplier..
the_mad_man in reply to trooperrickDec 10, 2008. 11:36 PM
maby you burnt out something?
burningsuntech says: Nov 26, 2008. 7:19 PM
Plasmana Great Instructable! I like the idea of parafin instead of mineral oil for preventing arc over. Parafin is less messy. raving apache
Plasmana (author) in reply to burningsuntechDec 7, 2008. 1:24 AM
Thank you!
cowscankill says: Nov 19, 2008. 10:41 AM
Does this make a one time spark or a constant electric spark?
Plasmana (author) in reply to cowscankillNov 24, 2008. 7:46 AM
One spark at a time...
scienceboy63 says: Oct 23, 2008. 3:57 PM
is USA a 200 or 400 volt country?
wirecutter in reply to scienceboy63Nov 9, 2008. 4:29 AM
110 V @ 60 Hz
Plasmana (author) in reply to scienceboy63Oct 23, 2008. 4:15 PM
USA uses 120v AC (170v peak AC).
geeklord says: Nov 4, 2008. 7:40 PM
Yea, After killing a transformer plugging it in to a wall I'm kinda nervous ataching anything made by me into the wall
Carlos Marmo says: Oct 30, 2008. 2:28 AM
Wonderful Work! Congratulations!
Plasmana (author) in reply to Carlos MarmoOct 30, 2008. 3:05 AM
Thank you!
plcrules says: Oct 22, 2008. 4:46 PM
i really need to no how do i power up the capacitors and power them down again
Plasmana (author) in reply to plcrulesOct 23, 2008. 10:31 AM
heimo says: Oct 9, 2008. 9:01 AM
Hi I was thinking if you want to make this thing variable do you think you could just add a light dimmer switch/potentiometer at the start of the circuit to control the input voltage
Plasmana (author) in reply to heimoOct 9, 2008. 12:49 PM
Yes, you can use the light dimmer to make the voltage variable.
heimo says: Oct 9, 2008. 9:20 AM
sorry I forgot I need the code for 400v ones cuse I live in 220v country
Plasmana (author) in reply to heimoOct 9, 2008. 12:47 PM
Look on step one.
heimo says: Oct 9, 2008. 9:10 AM
also do you have a product code like the ones for the diodes "18 1N4007 diodes" this code do you have it for the caps cuse I can only order anything if I had this code
sabre says: Oct 5, 2008. 3:50 PM
what would be the differance between a 1N4007 and a 1N4005 diode?
Plasmana (author) in reply to sabreOct 8, 2008. 5:34 AM
The 1N4007 diode can handle 1000 volts. The 1N4005 diode can handle 600 volts. You can use 1N4005 diodes, but they are more likely to be destroyed by voltage spicks than the 1N4007 diodes...
scienceboy63 says: Oct 3, 2008. 8:37 PM
can you power a jacobs ladder with this
Plasmana (author) in reply to scienceboy63Oct 8, 2008. 5:31 AM
No, this device make pulse discharges.
killerjackalope says: Sep 26, 2008. 1:24 PM
Hum, seems reasonable... One issue at the moment is the fact that I know the people in the maplins near me don't know a capacitor from a transistor and don't know a pig from a cow... On the upside if I jargon them while getting the bits I'll be able to build two and start a farm by the time I leave...
Plasmana (author) in reply to killerjackalopeSep 26, 2008. 2:14 PM
Yeah, the employs at maplin are just dumb... I one time asked them for a battery charger for my 7.2 rechargeable battery for my RC cars, they don't know what I was talking about and they think I am looking for a lead acid battery charger!!!! So I have to go through the whole catalog to find the part I want and point it out for them... And recently, maplin has stopped stocking a lot of electronic parts and increase price for the other still-stocked electronic bits, it is just driving me mad so I quit buying stuff from maplin and now buying much much cheaper and better quality stuff from Farnell. The capacitors you see on this instructable no longer exist in maplin's stock storage.
kruser495 in reply to PlasmanaSep 27, 2008. 2:29 PM
do you just hook this up to the 120v house outlet?
Plasmana (author) in reply to kruser495Sep 28, 2008. 3:03 AM
Hook what up? The voltage multiplier?
kruser495 in reply to PlasmanaOct 2, 2008. 3:25 PM
is there any other rating i can use? i want to go with radioshack...
kruser495 in reply to PlasmanaSep 28, 2008. 2:03 PM
yep. what do you use to power the multiplier?
Plasmana (author) in reply to kruser495Sep 29, 2008. 2:40 AM
Yes, hook it up to mains power as you can see in the schematic.
kruser495 in reply to PlasmanaSep 29, 2008. 4:38 AM
thanks! do you think i can find all the components at radioshack?
Plasmana (author) in reply to kruser495Sep 29, 2008. 3:48 PM
You should be able to, I am not too sure...
Plasmana (author) in reply to PlasmanaOct 1, 2008. 4:10 AM
Okay, here are the diodes. Unfortunately, radioshack only sells a package of various diodes, you only need 1N4007 diodes...
And the capacitors are very expensive...
I recommend you to buy your stuff from online store, they are so much cheaper than radioshack...
kruser495 in reply to PlasmanaSep 29, 2008. 6:15 PM
would you be able to look on the website and see what parts i can use?
Plasmana (author) in reply to kruser495Oct 1, 2008. 4:12 AM
kruser495 in reply to PlasmanaOct 1, 2008. 4:38 AM
yeah, i will order online. did you get my pm? also, what is the amperage the marxs gives out, if i were to touch it would i die if i only got shocked on one hand.
Plasmana (author) in reply to kruser495Oct 1, 2008. 4:09 PM
Sorry, I got your PM. I guess the marx generator spits out 5 to 20 amps to ground, I am not to sure... And, getting shocked on one hand from the marx generator, it really really depends on your health, luck, and what condition (place, air, what your other hand is holding) you are in... I cannot answer that question. But, please, always try avoid getting shocked.
killerjackalope in reply to PlasmanaSep 26, 2008. 4:36 PM
Oh dear, that's not good, I'll see if the electronics dept. in tech has any of the stuff or feel like ordering it... Farnell? None here as far as I know, damn and blast... Yeah I've had some mess ups there before, I asked where are the loose components and ended up on a tour of the computer bit followed the hobbies bit before he realized I meant the stuff you solder bin...
Plasmana (author) in reply to killerjackalopeSep 27, 2008. 12:18 PM
Farnell, my favorite online electronic store, they have a massive stock, and their products that maplin sells are much cheaper!
And Farnell is orange like Instructables!
killerjackalope in reply to killerjackalopeSep 26, 2008. 1:28 PM
Also I'm guessing current draw is small at 100ma, thinking Ex-lamp cord would do fine to add a switch... Oh just out of question any guesses on how many stages it'll work until it pops?
Plasmana (author) in reply to killerjackalopeSep 26, 2008. 2:27 PM
No, the current draw is much less, average 7.5mA, the fuse is used for just incase something may go wrong. And that is a good question, for this type of voltage multiplier, I successfully manage to make a 43 stage multiplier without any problems. So I would say about 100 stage in air is high enough. If you have it under wax, I would say a few hundred stages might work without problems.
killerjackalope in reply to PlasmanaSep 26, 2008. 4:44 PM
Hmm just checked Ebay after the whole maplin realization, 200 1n4007 diodes for £1.99 + £1.45p&p The caps aren't around, there are 10pf 400V and 0.1uf 400V though... Think they could be a substitute? The end result of this is still AC or do the diodes rectify it while doing their job? Anyway if I can find caps of a suitable capacitance then I'm in business, one way or another...
Plasmana (author) in reply to killerjackalopeSep 27, 2008. 10:33 AM
Yes! Get the diodes, that is a good deal, and the 0.1uF is the same thing as 100nF capacitors, so get those as well. And at last, you feed the voltage multiplier AC power, the diodes will do the rectifying and multiplying job, then the output will be high voltage DC.
killerjackalope in reply to PlasmanaSep 27, 2008. 12:38 PM
Hmm, would this make an acceptable jacob's ladder supply because with the spare caps and diodes I'll end up with I should be able to make a second one, unless I go for 100 stages... Do you think that breaking it up in to blocks of stages would cause much problems with the function of it assuming the connecting wires were well insulated from one another and soldered to avoid and corona discharging...
jinventive in reply to killerjackalopeSep 27, 2008. 12:19 AM
The 0.1uf caps. should be fine because 0.1uf is also 100nf.
killerjackalope in reply to jinventiveSep 27, 2008. 12:39 PM
Moment of incredulous stupidity on my part, I forgot that it's that way round, thought for some reason it went uf pf nf rather than uf nf pf...
scienceboy63 says: Sep 29, 2008. 2:41 PM
what does it plug into? The wall outlet?
Plasmana (author) in reply to scienceboy63Sep 29, 2008. 4:15 PM
Yes.
westfw says: Sep 26, 2008. 2:26 PM
For safety purposes, it would be better to isolate the multiplier from the mains with an "isolation transformer." Unfortunately, those are typically not so easy to find, and rather expensive. (So in your Marx generator movies, were you powered from the mains, or from the camera inverter + multiplier? I thought the spark rate was awfully high for the camera based circuit, but then again, it does use much smaller caps...)
Plasmana (author) in reply to westfwSep 27, 2008. 10:41 AM
Yeah, I would use isolation transformers,however like you said, they are expensive and hard to find. That is why I added a fuse into the circuit, to prevent something bad happening...
Yes, I used a inverter from a camera as a part of the power supply for my marx generator, but then it burned out... I made another one and it burned out again. That is why I came up with this new design.
And what do you mean by does use much smaller caps?
Derin in reply to PlasmanaSep 28, 2008. 10:52 AM
two step down transformers with same voltage wired as having one step-up would be a good enough substitute to an isolation transformer
Wire it like this:
Mains                   Isolated mains from second xformer-----------|             |---------------------------------------------------------~~~To device                    |  +12V   |           |-------------|           |             |           |------------ |-----------|             |----------------------------------------------------------~~~To device
Plasmana (author) in reply to DerinSep 28, 2008. 2:11 PM
Yes, I know what a isolation transformer is. The problem is buying the transformer maybe a bit expensive, and bulky...
Derin in reply to PlasmanaSep 29, 2008. 12:11 AM
Yes,I know you know,and you could salvage the transformers from electronics...
Plasmana (author) in reply to DerinSep 29, 2008. 3:45 PM
Yeah, the problem is I don't get enough electronics and you need two that has the same ratings...
westfw in reply to PlasmanaSep 27, 2008. 6:01 PM
  • what do you mean by does use much smaller caps?
Well, the flash itself has a cap of about 100uF, while the caps in the multiplier and marx generator all all fractions of a uF, probably not exceeding 10uF even counting all of them in parallel.
Plasmana (author) in reply to westfwSep 28, 2008. 10:30 AM
Okay...
thermoelectric says: Sep 26, 2008. 4:02 PM
This is pretty cool, Would putting more stages in make the output of the marx generator higher]
*Yay, Plasmana finally made it after i kept bugging him And probably a lot of other people ) :-)
Plasmana (author) in reply to thermoelectricSep 27, 2008. 10:33 AM
LOL! Like about 20 people is bugging me to make this instructable!
thermoelectric in reply to PlasmanaSep 27, 2008. 5:36 PM
Yeah, Thats why I said *Yay, Plasmana finally made it after i kept bugging him And pprobably a lot of other people) :-)
Plasmana (author) in reply to thermoelectricSep 28, 2008. 10:23 AM
JUADLOL
thermoelectric in reply to PlasmanaSep 28, 2008. 2:50 PM
Yay...
Plasmana (author) in reply to thermoelectricSep 29, 2008. 3:05 PM
Yeah...
thermoelectric in reply to PlasmanaSep 29, 2008. 3:26 PM
LOL
Kn1nJa says: Sep 27, 2008. 8:57 AM
I found these caps on farnell...
"CAPACITOR, CLASS X2, 100NF, 300V"
http://export.farnell.com/jsp/search/productdetail.jsp?sku=1166464
Plasmana (author) in reply to Kn1nJaSep 27, 2008. 10:44 AM
Wait, what is the mains voltage does your country use? I could probably find much cheaper ones for you...
Kn1nJa in reply to PlasmanaSep 27, 2008. 3:00 PM
110 (USA)
Plasmana (author) in reply to Kn1nJaSep 28, 2008. 9:34 AM
Okay, this capacitor should be suitable for your needs...
LinuxH4x0r says: Sep 26, 2008. 6:05 PM
Awesome! I'm building one as soon as I can get some capacitors!
Plasmana (author) in reply to LinuxH4x0rSep 27, 2008. 10:41 AM
Okay, good luck!
Leesam says: Sep 26, 2008. 10:20 AM
Could this be extended for higher voltage? I could understand more of a need to case in paraffin with higher voltages, just not sure if the parts could handle it.
Goodhart in reply to LeesamSep 26, 2008. 4:40 PM
up to a point, after which either the diodes or the capacitors may break down, OR arching starts to occur.
Plasmana (author) in reply to LeesamSep 26, 2008. 2:02 PM
Yes, you can extend the voltage multiplier for higher voltage.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
