High Voltage Power Supply For Marx Generator
 by Plasmana
Step 6: And the final connections
And finally, solder on the fuse, (safety resistor,) and the wires. It might be a good idea to cover all of that in hot glue, to prevent the wires breaking and causing a huge problem.
Quyzi says: Aug 13, 2012. 7:09 PM
Does it matter if hot and neutral are swapped? I can't find a polarized plug :(
comodore says: Feb 8, 2009. 6:34 AM
The brown and blue wires go to a male receptacle, right? And than you plug that in into 220V, right? In the schematic there is also a 100mA thing, I'm not shore what that is, what is it??? Thanks!
Plasmana (author) in reply to comodoreFeb 11, 2009. 2:49 AM
Yes.
Close, in 240v.
Thanks!
A fuse. :-)
comodore in reply to PlasmanaFeb 11, 2009. 1:33 PM
Thanks, now that i know everything i need, that wasn't clear to me, now I can build it and finally make a Marx Generator! BUHUHUHAHAHAHAHA *cough * *cough * xD
Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
