High Voltage Switch Mode Power Supply (SMPS)/Boost Converter for Nixie Tubes
This SMPS boosts low voltage (5-20 volts) to the high voltage needed to drive nixie tubes (170-200 volts). Be warned: even though this small circuit can be operated on batteries/low voltage wall-worts, the output is more than enough to kill you!
Project includes:
Helper Spreadsheet
EagleCAD CCT & PCB files
MikroBasic Firmware Source
Step 1How does it work?
How does it work?
This design is based on the Microchip Application Note TB053 with several modifications based on the experience of Neonixie-L members (http://groups.yahoo.com/group/NEONIXIE-L/ ). Get the app note - it's a nice read of only a few pages :
(http://ww1.microchip.com/downloads/en/AppNotes/91053b.pdf )
The illustration below is excerpted from TB053. It outlines the basic principle behind the SMPS. A microcontroller grounds a FET (Q1), allowing a charge to build in inductor L1. When the FET is turned off, the charge flows through diode D1 into capacitor C1. Vvfb is a voltage divider feedback that allows the microcontroller to monitor the high voltage and activate the FET as needed to maintain the desired voltage.
19 comments
Feb 10, 2009. 7:07 PMjoinaqd says:
ummm.....whats a nixie tube?
Apr 5, 2011. 3:18 PMdainichi says:
A nixie tube is a neon indicator that instead of displaying a little dot, can be used to display numbers or symbols. They were used to indicate numbers before they invented the LED or LCD.
A quick web  search for "nixie tube" would provide you with far more information than I can or care to include in a posting.
Feb 23, 2011. 1:53 PMptorelli says:
Ian,
How do you fab your boards? Do you use a home etch kit or do you order online? Most places I've checked are pretty steep for one-off orders. Got a recommendation?
Thx,
PT
Jan 28, 2009. 2:53 PMhithisishal says:
Hey man, thanks for the instructable!
Nov 19, 2007. 6:08 AMbumsugger says:
Nice concise,informative instructable,with more than enough info. PS 15Milliamps is enough to kill you.
Jun 21, 2008. 1:43 PMbumsugger says:
In the UK it IS .015ma @ 230volts........................
Jun 21, 2008. 8:18 AMDerin says:
no 500 ma
Feb 8, 2009. 10:27 AMMicRoelelectronica says:
0.06 A through the heart, but 3A from fingertip to fingertip wont kill you.
Feb 9, 2009. 2:50 PMbumsugger says:
Not if the fingertips are on the SAME hand,but if they ARE on different arms,then the current path IS across the chest,and hence very likely through the heart.
Feb 10, 2009. 8:09 AMMicRoelelectronica says:
Yeah, forgot to mention that. you're right! anyway, its better not to use yourself as a high voltage wire......
Feb 11, 2008. 7:39 AMsnarfer says:
First of all, thank for this excellent instructable. The spreadsheet is really great. And the idea of calculating the charge and discharge times of the inductor rather than the inductor size, is something most vendor application notes leave out. Very educational. There is a note at the end about making it possible to implement this with power supply less than 7 volts. I think in order to do that you would need to use a different FET, because the IRF740 only fully turns on at 8 volts. I don't know if it's possible to find a logic level FET that works up to this kind of voltage, my local distributors don't stock them. In fact it might work better with a power transistor like MJE13005. Well that is just a guess, but in case anyone is trying to build this circuit to boost from very low voltage it could be interesting to think about FET selection. I am experimenting with implementing this topology but based on dsPIC30F1010 instead.
Apr 30, 2007. 8:52 PMJohntron says:
Hey Ian,
Would it be possible/feasible to make a 300W power supply with something like this? Obviously, some modifications would be required.
I'm building a hot-air rework station, and having trouble finding a (cheap) power supply in the 300W range. I've always wanted to make your SMPS, and it would be cool to use it in my project. The PSU would be used to power a heating element like this: http://www.sparkfun.com/commerce/product_info.php?products_id=73
I would need to be able to adjust the power going to the heating element, so the pump would probably be powered separately just to keep things simple.
(I want the couch on your website)
Sep 6, 2006. 5:25 PMgardenyu says:
Hello: I wonder if this converter can step up from 12V DC to 300V DC, if so, what is the main component to change? Thanks a lot.
May 24, 2006. 6:23 PMlemonyx says:
Hi Ian Great job on the PS. Having a problem finding R2 & R3, do you have mfg #'s? I'll be building your PIC programer as well. Hope to hear form you. Thanks Charles
May 24, 2006. 5:09 PMMao Mao says:
Hi... Sorry if I missed it but how many Nixies can you light with this PSU? (at once I mean) Thanks - Shahar
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
125
Author:ian(DangerousPrototypes.com)
