This burner is Lionel's "Oliver-Upwind" Burner design over at http://www.backyardmetalcasting.com/
Specific Link: http://www.backyardmetalcasting.com/oliverburner1.html
This is by far the simplest burner design I have found, and he does a pretty decent job of explaining the process. I improved the design slightly and have some suggestions for construction.
SAFETY Statement : Fire is hot, propane is potentially explosive, power tools and welders can hurt you in many spectacular fashions. Please take proper precautions to avoid losing eyebrows and digits.
Remove these ads by
Signing UpStep 1Materials
- 6 Foot Braided Steel Propane Hose
- 1/8" ID Black Pipe and Connectors
- #57 Drill Bit
- 3/4" ID Steel pipe
- Old rusty propane tank
The propane regulator I found is variable from 3-35 PSI, and was the most costly part of this build at ~$40. Hopefully I'll get a lot of life out of it. The 3/4" ID pipe was one that I had laying around, and is not the same size as 3/4" black pipe.
Note that you can mix brass and black pipe fittings to get whatever configuration you need. Brass connectors are more expensive, so use whatever black pipe pieces you can find.
Notice that "Higher Pressure" in propane terms doesn't mean the same thing as regular compressed air. Most BBQ grills run at 3 - 5 psi, and the big turkey fryers run at 15 psi.
I probably have my regulator set at ~18 psi. I could have saved $30 by getting a fixed 15 psi regulator, but this one looks a lot cooler (definitely makes it worth the extra $25...).
In the video I made you can see my crucible that I used for over 30 aluminum pours.
You can have a look at my foundry blog for more info:
http://www.flamingfurnace.blogspot.com/
Liquid fuels would most likely produce a more yellow flame since the more complex molecule burns in more stages than a gaseous fuel. Think about a Coleman camp stove - it starts off with a yellow flame when you first pressurize the container then turns blue and self-sustaining when the flame is hot enough to vaporize the incoming fuel. A propane stove generally starts off with a blue flame with no pre-heating.
Of course, pressurized liquid shooting out of a nozzle in a stream with an ignition source is called a flame thrower, so dont do that.
As long as all of the propane is burned before it exits the foundry, all of the potential energy of the fuel should be expended in heating it up (right, thermodynamic physics? It's been a while). You're right that welding it reduced my my ability to adjust the flame, but didnt completely eliminate it - the flame quality also depends on the length of the burner tube, the end point aerodynamics (affected by a flange, which I dont use), and internal aerodynamics and routing (I have none to speak of).
Anyway, this response is a little longer than I intended it to be, but you asked for it! :-) The foundry is complete, but I have yet to fire it up since I'm letting the refractory cure. That's the next Instructable, coming soon! Thanks for the comment, and let me know if you have any more questions.
