3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High Volume Rain Barrel
My wife and I purchased an esthetically pleasing rain barrel for the front yard. After experiencing the benefits there I began looking to build my own system for the backyard for the garden, the landscape, and for play. As I reviewed many online plans and products, I found a number of good ideas. This design I developed differs in that it does not require any drilling/cutting of holes in the barrel for the water flow and the volume of water passed through the system, especially the output, is as high as possible, limited only by the attachment at the end of the hose.
NOTE:
In my case, I knew we wanted a 2 barrel design, the same plan can be followed for a single barrel design. Modifications will be noted throughout the instructable.
Step 1Out Flow Parts List
Out Flow Parts List
  • last photo ←
Here are the parts that I used and the price. This is for building the piping and valve assemblies to draw water out of the barrel. The parts needed for bringing the water into the barrel are handled separately in step 4. All of the following parts can be purchased at Home Depot.
2 2" DWV MIP Adapter - $0.90 each
2 2" DWV Street Elbow 90 degree Spigot x Hub - $2.01 each
1 2" PVC Pipe (2' section pre-cut) - $2.21
2 2" PVC Tee - $2.49 each
2 2" x 1-1/2" PVC Drain Waste Vent Flush Bushing - $0.86 each
2 1-1/2" x 3/4" PVC Schedule 40 Bushing Spigot x FIPT - $1.27 each
2 3/4" Short Galvanized Nipple - $0.98 each
** I chose not to use this but instead got the PVC schedule 80 (gray) equivalent from my local Ace Hardware for $0.79 to prevent as much metal in the design as possible.
2 3/4" PVC Ball Valve - $2.94 each
2 3/4" MPT x 3/4" MHT adapter - $3.53 each
** While my local Ace Hardware did have this piece in plastic for less, I chose to go with brass here to better withstand contact with the metal threads on my hoses.
1 can of PVC primer and cement - $6.96
NOTE:
For a single barrel design you do not need the Tees or the PVC pipe. You have the option to change the 90 degree Street Elbow with the 45 degree Street Elbow to reduce the bend of an attached hose.
59 comments
1-40 of 59next »
Oct 5, 2011. 6:31 PMgafarmboy says:
Very Well done. The step-by-step process was well thought out with excellent instructions. I will be working on a similar project this weekend using this tutorial as a guide.
Thank you
Gafarmboy
May 25, 2011. 3:09 PMEric T says:
If you thredd a steel pipe niple into those bung plugs "caps". The plastic plug breaks out. No drilling is required. = Less chance for blood :)
Jul 25, 2010. 5:29 PMBuzzinski says:
Nicely done. This is what we use in Australia. http://www.gough.com.au/tanks/default.htm typically all new home built here (Queensland) have to have a rain water tank (Barrel) of a minimum size -( from memory I think it is 5000 litres) installed prior to the final building inspection. Not a bad idea for a very limited amount of storage but 3 small suggestions. 1) Pour a concrete slab under the blocks to stop them falling over. 2) use flexible hose instead of rigid plactic pipes between the barrels. If one tilts or falls the flexible hose will not break like a rigid pipe will. 3) Raise the barrels another foot and you will get more water pressure for a slightly longer hose run.
Aug 20, 2010. 9:12 AMMeggz says:
O yeeeaaaahhhhh that is the way downunder, strange adaptive fukkers we are! My parents & grandparents before them etc etc have been doing this -what we call 'improvising' for so bloody long now it is beyond me why I really have to bother to utter the words!!! O and thank you so much for your insight hahahahahahaha
Jul 25, 2010. 6:49 AMLandMime says:
I live in Indiana and the problem I had with using a plasic valve is even though I emptied the barrel prior to winter enough water sat in the valve which froze and caused it to crack. I would suggest metal for cold climate valves.
Aug 1, 2010. 6:29 PMjpatano says:
Great instructable!! I just ordered a diverter, and I found someone locally selling barrels for $20 each. Looks like I will have a fun little project for next weekend. I originally had a question about how well the barrels would fill due to the input hose being at the bottom, but I then saw it had been answered in another comment.
Oct 1, 2009. 4:59 AMbuteomont says:
Nice 'ible, but where do you get the barrels?
Jul 26, 2010. 7:19 AMthreewheela says:
Car washes oftten give these barrels away for free. The liquid soap they buy comes in these 55 gallon drums and whats left over in them when u get them can be easily washed out.
Apr 25, 2010. 6:37 PMscratchr says:
Just ask the water treatment plant.
They use them for cleaning chemicals.
Oct 18, 2009. 12:13 PMhandprints says:
Great instructable!  I called all of our local bottling companies and they ranged in price from $30 each to $10 each.  the $10 was at our Pepsi bottling company.  We were able to fit 9 in our truck.  I think it was a little overkill on my part, but they are useful things to have AND if I don't use them all, I'm sure someone else can use them.
Jul 26, 2010. 12:07 AMdugthegreat says:
You are not in a earthquake zone ; So I understand you do not need to secure it . I live in a earthquake prone home; so I think there is a need to secure the rain barrels
Jul 25, 2010. 2:39 PMDavid Catriel says:
Very nicely done. The barrels, though - where did you get them? Are these specifically made for rain collecting or did you repurpose them from something else?
Jun 4, 2010. 2:32 PMKindlekat says:
This was SUCH a great Instructable! I actually became Pro just so I could download the PDF and see all the pictures. THANK YOU for individually labeling and taking pictures of all the PVC parts. While I am quite the handy gal (I work in a theatre scene shop, and know my way around more power tools than the average joe) I was not as familiar with the plumbing. With your clear lists of parts, I was able to find everything I needed at Home Depot with some help from an associate, and make an easy substitution when they didn't have one of the parts I needed. My system is fully built now and tested, I have one or two slow leaks, but I should be able to remedy that with some PVC cement soon. I researched a lot of these rain barrel systems here on Instructables, as well as the internet in general and by far your design was the easiest to follow, assemble, and made the most sense. I will be posting pictures soon!
Jun 7, 2010. 5:44 PMKindlekat says:
Wanted to add the pictures of my finished system! Because I did not have the downspout diverter, I picked up what looked to be a downspout adapter and used that. I also used a barb adapter in the top of my barrel, for overflow, and those were my only changes. Thanks again!
Jun 11, 2010. 12:29 PMKindlekat says:
I definitely expect some overflow in a heavy downpour, which I've accepted as my fate when altering the design. However, I just tested the barrels at half-full and there wasn't enough pressure to get anything out of my hose at all. I'm hoping that once they are full there will be enough pressure. Also, I was using the 100-150 foot hose the previous renters had left, which I suspect might be the problem. It might just be too long of a hose to keep the pressure going, so I will get a shorter hose and see what happens.
Jul 12, 2010. 1:33 PMKindlekat says:
The hose was definitely the problem! A 25' 3/8" hose works perfect!
Jul 9, 2010. 4:37 AMEmilinIowa says:
I found an 1100 gallon barrel/tank on Craigslist. It now resides beside our barn with twin inputsfrom barn roof, North side direct, South side piped over and the tank is full. Two valves with hose connections water the garden, horses, etc.
Jun 21, 2010. 7:46 AMnuttman says:
From the picture, it looks like the rain diverter is slightly below the top of the barrels. Is this correct? With the holes for balancing air pressure, I would think the diverter must be below these; Water overflow would come out the top of the barrel through the holes, rather than backing up the diverter. I've been thinking about taking 1/2" PVC pipe and making a "periscope" out of the tops of the barrels for balancing air pressure. The diverter could be mounted slightly higher than the top of the barrel, and the periscope would extend above the diverter. Any thoughts on this? Do you have water come out of the top holes when the barrels fill completely?
Jun 23, 2010. 6:58 AMnuttman says:
Screening is a must! Anyway, my point was that anyone using a diverter such as this (mine is a RainReserve) must be aware of the mounting level in relation to the top of the barrel. Too high, and water will want to overflow through the top of the barrel rather than back up the tube to the diverter as intended. (In a heavy rain, I'll bet the pressure of the water trying to get out through the little holes may still back up to the diverter.) The vent pipe idea (or "periscope") simply allows for some leeway in the mounting height of the diverter. As long as the end of the vent pipe is above the overflow mouth of the diverter, there should be no problem. It's all about water seeking its own level. I think this is what's great about these projects. There's so many ways people can customize them. Thanks for all the great information and details you provided about yours!
Jun 5, 2010. 7:42 AMCyraxlynx says:
wow this great...
Jun 4, 2010. 2:14 PMdcole64 says:
Hey Barnsie! Congrats on being a 'featured' project. Now I just have to figure out how to modify it for our southwest gutters and a rain chain.
May 22, 2010. 2:08 PMTaztrophe says:
Absolutely love the simplicity of your design. I've been browsing looking for the perfect configuration for my barrels and your plan looks perfect. I'll be doing a homemade filter for inflow as I'm diverting the whole downspout versus buying a diverter but rest looks great.
My only question is why did you decide to put two ball valves for outflow on your system versus one? I had planned only one but I'm interested to hear your experience before I commit either way.
Oct 23, 2009. 9:41 AMwingrider78 says:
Do your barrels fill completely???  I was under the assumption that they needed to be filled from the top...one of the instructables I read said that the water will only rise as high as the entry point of the water...so with it being at the bottom, I wouldn't have assumed that the barrels would have filled.  I must have misread something somewhere...
How can water coming into your barrels in a 5/8 line compete with the pressure of the rising water to completely fill the barrel???
May 14, 2010. 11:54 AMnorthwoods74 says:
Oops--one last question.  Did you use pvc cement on all the parts (except for the ones with threads)?  I'm assuming you did, and as I look at my parts I have one concern: once you get the whole thing together, is there any way to get it apart?  Seems like it would be hard to get the outflow assembly off the barrels if there was ever a problem.  No biggie, still a fantastic setup, just wondering if you had a solution for that.  Thanks!
May 14, 2010. 11:46 AMnorthwoods74 says:
Thanks for the reply--can't wait to try it!  Great instructions, by the way--especially the part where you use Home Depot's actual terms for the parts :)
May 13, 2010. 10:25 AMnorthwoods74 says:
I second Wingrider78's question; I don't understand how you can be filling that thing efficiently through the bung on the bottom--wouldn't the pressure of even a half-full barrel push the water right back out the hose and up into the downspout?  Can you please explain?
May 1, 2010. 5:19 AMJakeg says:
Hey,
     I know that I commented on this before but I since I decided that I am going to build this I need something from you. I was just wondering how long is this setup from the edge of one barrel to the edge of another.
                                             -Jake
May 5, 2010. 4:00 PMJakeg says:
OK, Great... I just needed that info so I could set it up on the side of my house. Its on a hill so I have to dig it out and pour concrete to make it level. Once again, Thanks =]
Apr 23, 2010. 4:38 PMJakeg says:
I am so excited that you posted such great, informative information for all of us people... I am definitely going to work on doing this project for my summer home. We are actually just starting a garden now and my mom wanted a better, greener way to feed the garden veggies. Once again I thank you for such a great instructable. =)
Mar 18, 2010. 2:27 PMwingrider78 says:
Hey there...how many of those 5/32" holes did you have to drill to allow the barrels to fill and empty smoothly??  I have purchased a diverter and am just waiting for it to come now so I can build the system in your instructable...I can't wait :)
1-40 of 59next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:thebigbarn
