3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High Volume Rain Barrel
Step 3Connecting the valve assemblies to the barrels
1. After guaging the positioning of where your barrels will be, determine the spacing between the barrels and specifically between the pipe-threaded bung holes.
2. Cut the 2" PVC pipe (standard hacksaw will do), cutting two small sections for connecting the Tees to the Street Elbows and a larger section for between the two Tees.
3. Insert the pieces between the elbows and tees to make one complete unit.
About sealing the joints:
Using friction or plumbers tape in the joints will allow you to customize the angle of the valve assemblies. If you find that it is leaking, you can cement the joints later. I found this to be beneficial as we could adjust the angle of the spigot assembly to account for filling water cans, water guns, or other items.
4. Remove the two pipe thread bung plugs from the barrels. These are the plugs that do not have the internal threads in the center of the plug.
(I removed the gaskets from the plugs and put them onto the 2" DWV MIP Adapters but this proved unnecessary as the PVC adapters did not screw all the way down into the barrel anyway.)
5. Screw the 2" DWV MIP Adapters into the bung holes of the barrels until tight.
6. Insert the street elbows into the adapters.
With this, the outflow system is complete.
NOTE:
For the single barrel design, insert the vavle assembly into the 60 degree Street Elbow. Insert the elbow into the 2" DWV MIP Adapter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:thebigbarn
