Step 4Connecting the barrels to the downspout
If you choose to use a downspout diverter, there are a number of models available on the internet which connect in different ways. While purchasing one will add approximately $30 to the cost of your project, it will also allow you to use your existing downspout system for handling the rainwater when the barrels are full. See http://www.rain-barrel.com/how_it_works.html for a video explanation of how they work in general.
The most common way for filling the barrels is to cut a hole at the top and install a screen over it to keep out debris and mosquitos. As stated above you must also plan for run-off once the barrel is full. As I already had the spare downspout diverter, it allowed me be create a completely contained system. The only holes drilled into the barrels are a series of 5/32" (smallest drillbit I had with me) holes in the top of the barrels to balance the air pressure in the barrels as they fill and empty.
These are the parts I used for connecting the barrels to the downspout, all from my local Ace Hardware:
1 3/4" MIP to 5/8" barb adapter
4' of 5/8" ID (internal diameter) clear tubing
**This hose fit into the opening of the downspout diverter and also allowed for a larger volume of water to enter the barrels at one time.
Installation:
1. I used a 3/4" spade bit to drill out the bottom of the one of the internal threaded bung plugs, being careful not to damage the threads.
2. I screwed the bung plug back into the barrel so as to use my homemade wrench to ensure it was tight.
3. I screwed the 3/4" MIP to 5/8" barb adapter into the threads of the bung plug.
4. I attached the tubing to the barb and secured it with a clamp.
5. I followed the instructions with diverter to install it into the downspout and then connected the clear tubing to it.
6
comments
Add Comment
thebigbarn (author)
says:
thebigbarn (author)
says:
thebigbarn (author)
says:
Add Comment
