The high powered LEDs used for this Instructable are very efficient, putting out 80-90 lumens per watt, compared to typical incandescent and halogen bulbs. However, they still generate a lot of heat and the lifetime of the LED will be adversely affected by high junction temperatures. Therefore we want to get the heat away from the LED through ensuring good thermal contact with the LED board, high thermal conductivity in all materials, and good coupling of the thermal energy to the surrounding medium (air). The LED star board used for this project has three LEDs on it and has a metallic backplane that is isolated from the LED electronics. This is a good thing. The rest of the LED head-light is built out of copper fittings from the local hardware or home improvement store. To complete the project you will need:
Parts:
Luxeon Rebel Endor star 3-up LEDEndor star lensBuck Puck constant current LED driver3/4" Copper Pipe Cap
1" to 3/4" Copper pipe reducer fitting
Waterproof connector of your choice (I use 2 position automobile trailer connectors)
Supplies:
Conductive epoxy (thermally or electrically)
JB Weld or similar high strength epoxy
RTV silicone or epoxy for waterproofing
Silver solder and flux
emory paper for cleaning copper
Tools:
hacksaw
drill and bits
file
propane blowtorch
vice
hammer
sandpaper
http://www.instructables.com/id/Bike-Light-2011/
http://ledsupply.com/creexpg-w417.php
When I talked to a person at LED supply, he told me this was their latest and greatest and has a few different selections for optics. I've done a dual mount side by side using these and they are very good. Using your design I've also done side by side tubes Bike mounted I call my Double Barrels using these
http://ledsupply.com/luxeon-leds.php
I like these also because of the selction of optics I get a better beam. Thanks for your design and I look forward to making more
One other thing I did was to mount my Buck puck on the battery housing which sits in a top tube bag near the handle bars. No reason for that except not confident enough to square out the end of the tube. CS
Thanks for trying these out and check out my newer design (still about 9 months old) below for a cleaner looking housing.
http://www.instructables.com/id/Improved-high-power-LED-bike-head-light-with-integ/
IMHO the soldering processes are a bit difficult & I suspect the junction temp may be right on the limit ,although even if it should cut the life by 80%, I suppose that's no matter really.
Problem as always is getting a conducting medium to get the heat away & I am not keen on conducting epoxy.
I wish you could hurry the update, I bet you have some real improvements to show us.
If you look at the thermal conductivity of stuff that you could realistically put between the PCB/star and the heat sink there is not a product out there that is better than a conductive epoxy. Conductive epoxies contain conductive particles, and outside of Aluminum Nitride and diamond, the best thermal conductors are all electrically conductive. The difference between a thermal and conductive epoxy is the amount of solid filler. The electrically conductive epoxy is loaded past the so-called percolation threshold and therefore has reduced resistance (both electrical and thermal). The advantage of the isolated backplane of the star board is that you can use a conductive epoxy which has a higher solids content and therefore higher thermal conductivity.
BTW, the new doc is up.
It's the same reason that motorists who put HID xenon lights in a normal lamp housing without a focusing lense get fined and ticketed.
Excellent headlight option. Once focused, you can probably go with a less powerfull setup and your battery pack will last longer. Lithium is the way to go for high power output in a small size.
Lithium batteries are certainly superior in terms of energy density. My latest light has a low and flash mode which extends the battery life of the LiFEPo pack significantly. Like the aforementioned tail-light project, I have been meaning to write this up in an Instructable but have not found the time or energy.
Stay safe!
Standard halogen headlights perform in the 15 lumens per watt range. Typical low beams are 45W and high beams 65W for roughly 700 and 1000 lumens respectively. Sealed beams have compromised reflector designs but still put out a lot of light. Just more spill. So with your high beams on, your old school headlights would be putting out 3400 lumens total L and R. Which is brighter? Now if were talking a padiddle all bets are off.
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/Products/Halogen/StandardHalogenProducts/
Additionally, I think you are confusing the lumen rating and candela rating (http://en.wikipedia.org/wiki/Candela). A 600 lumen light with a 10 degree lens would appear much brighter than a 600 lumen light with a 25 degree lens. The focused light would have roughly 6 times the candela rating and be 6 times as bright. As to which impinges more light onto an oncoming driver's eyes is a complicated function of the optics of the systems in question and the emission pattern of the LED arrays as well as the aiming of the lights. Similarly, the poor reflector of a sealed headlight and the broad spread of the design in general may make them seem dimmer (low candela) than a focused LED but the headlights are still putting out a heck of a lot more light than the LED bike light.
So let's just agree to disagree and I promise not to ride with my light in CA.
My pack consists of 4 18650 lithium cells. I use 3/4pvc for the case. I put a nice screw top on it so the batteries can slide out. And just tonight have I figured out how to securely fasten it to the bike in a way I like. This has been a great project!
The second picture has version 1 of the battery pack...it failed...
Help me out in clueless at the moment Thanks
Good luck.
One question: is there any reason that the buck puck needs to be in the light unit? The way I'm thinking of doing mine would be more convenient with the buck puck at the power pack. That shouldn't be a problem, should it?
Thanks,
--David
http://i116.photobucket.com/albums/o8/michaelsu_bucket/Bike%20Light/P9180061.jpg
http://i116.photobucket.com/albums/o8/michaelsu_bucket/Bike%20Light/P9180058.jpg
http://i116.photobucket.com/albums/o8/michaelsu_bucket/Bike%20Light/P9180065.jpg
http://i116.photobucket.com/albums/o8/michaelsu_bucket/Bike%20Light/P9180067.jpg
http://i116.photobucket.com/albums/o8/michaelsu_bucket/Bike%20Light/P9180072.jpg
The battery ran for 2 hrs full power with no problem. Not sure what the total run time will be.
The first trail test will be in a couple of days. :-)
-Mike
Update: I've had a chance to tinker around with some of the LED drivers I have laying around. I've found one of the DX drivers I have is a true boost type driver. I've run a Rebel 3-up at >800mA and Vf~10.3V with a 5V source. I've also poked around enough with this circuit to figure out the layout to where I can change both the low and high mode set currents. The circuit comes configured to run pretty hot, with high mode current at nearly 1000mA regardless of what the DX description says. I dropped that to around 600mA and am happy with the output. The strobe mode is nice as well, with current draw <200mA. The strobe is a bit fast but hard to ignore for oncoming drivers as long as no seizures are induced. A bit more pricey but the multiple modes are a nice plus.
http://www.dealextreme.com/details.dx/sku.25516
The above driver is CURRENTLY based on the FP5138 boost IC. No telling how long that will last but after digging around for a long time I was able to ID this chip and make mods to the circuit successfully.
http://www.micro-bridge.com/data/Feeling-tech/FP5138_AN.pdf
If you don't like the extra modes you can simply cut away the bottom (battery side) board with the microcontroller, toss it, and apply the battery - wire to the single post and the battery + wire to the middle post of the three posts on the top board (the one with the inductor). The current setpoint will be 250mA in that case. Just need to change out the resistor on the top to get a different current. It is a 2 Ohm as delivered and by lowering it to a 1 Ohm the current will be 500mA. Equation for current is: i=0.5/R Where R is the set resistance.
http://en.wikipedia.org/wiki/Buck_converter
http://en.wikipedia.org/wiki/Boost_converter
Are there any markings on the 3-pin IC in the center of your board? This is the transistor and should have a voltage rating high enough to handle the expected boost voltage. Another check would be to monitor the signal on the VDrive pin on the ZXSC310 to see if it is truly switching the transistor and to estimate the duty cycle using an oscilloscope.
http://i116.photobucket.com/albums/o8/michaelsu_bucket/P9150053.jpg
http://i116.photobucket.com/albums/o8/michaelsu_bucket/P9150054.jpg
someone on the candlepower forum linked me to a driver board that would work . it's boost configuration and the current could be set @ 300,500, 700, 1000 mA settings.
Not in the budget this time around but a nice concept.
here's the link....
http://www.taskled.com/maxflex.html
If I knew where I stood in the beginning, I probably would have ordered this one.
luckily you can teach an old dog new tricks, I have a better understanding of it all now :-)
...............chalking it up to experience
I figured the battery connections out before I saw your return post.
Yes, I am using a flashlight driver. The one you linked to is on back order so I found a replacement with the same specs locally. This is the one I have:
http://www.shiningbeam.com/servlet/the-40/Circuit-board-1160/Detail
I checked the circuit and it appears to work to some degree. The LED lights up but I have doubts that it is being fully utilized. I don't see is the voltage "boost"
I hooked up a 9V battery to the LED driver board and with a volt meter I get the same voltage coming out of the board as I do going in. Is this normal without having a "load" connected?
In this case the load being the LED's.
On the bright side ( pun intended) I am learning quite a bit here.
-Mike
electronics are not my strong point. That's why I was looking to use your circuit.
What do you mean by "boost Circuit"?
The flashlight drivers are at a great price.
What voltage would be required for it. As everyone else is I'm working on a limited budget here otherwise I would just copy your setup exactly. ( I may in the end anyway just would like to know how this all works )
I have a couple of batteries similar to these laying around with a charger that I was thinking about using:
http://www.trademe.co.nz/Toys-models/Radio-control/Parts-accessories/Batteries/auction-239267008.htm
I could put one in a water bottle or something like I've seen with other batteries.
What components do you think would best utilize them?
Thanks again,
-Mike
The efficiency of the boost circuit (link below) on the flashlight circuit I linked to is >90% at higher supply voltages so you will NOT lose runtime or light with your chosen battery. For example, the 7.2V 3.3Ah battery you linked to has ~24Wh of energy in it. Running the 3 LED star at 800mA and Vf of 10.3 will consume 8.24W and output about 600 Lumens running for somewhat less than 3 hours. 600 lumens is a blinding amount of light, approaching car headlights so should be plenty.
I would tune the current down to about 500mA personally by changing out the resistor on the circuit board to a 0.04Ohm based on the data sheet linked. This will reduce the heat sink requirements, as well as increase the LED and battery lifetime. Good luck.
http://www.diodes.com/datasheets/ZXSC300.pdf
The above is geared towards 12VDC or 12VAC halogen bulb replacement but you can bypass the diode bridge if using a 12VDC battery and desolder the MR16 "bulb" pins. You are left with a compact, constant current driver with pretty high efficiency (>90%). Regardless of what the specs say, the boards I got (3W) were set for ~650mA output and can be changed by swapping the current set resistor. The circuit will drive 3 LEDs in series if your supply voltage is high enough, the limitation being thermal shutdown of the driver chip. If I recall correctly, I've gotten both PT4105 and PT4115 chips on my boards depending on batch. See below:
http://www.zhaoming.com/bbs/u/2008/07/01/13021214907053.pdf
If you want to run a boost type circuit, look for the flashlight driver boards on DealExtreme. Many of them are not constant current, so read the forums and reviews. I've had good luck with the one linked below:
http://www.dealextreme.com/details.dx/sku.3256
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3794
Battery Space
Run time depends on a lot of factors, for rough guess divide battery WattHrs by LED wattage. For example, 12V 2Ah= 24 Wh and 2.4hours runtime at 10W.
The conductive epoxy I used is http://microcenter.com/single_product_results.phtml?product_id=0210267
If you were redoing this project now, would you go with the micropucks instead?
http://ledsupply.com/micropuck.php
So, if you are going to use only a 1up Rebel star then you can use a 9.6V battery. A 2up will also be fine. However, you cannot run a 3up from 9.6V unless you find a 3-up wired in parallel.
Additionally, I don't know that you'd need the additional RC motor heat sink if you are only running a 1-up LED star. Good luck with your project.
-Jon
I know everyone has been commenting and asking about battery options, and I do like the LiFePo (small 4cell is a big plus), but it's a bit pricey. Battery-space.com also said there's a hazard fee of +$20, so it would be a $80 battery + charger for 1350mAh. I may have to just drive up to richmond to pick the thing up. I wonder if they take walk-ins...
By the way, I have zero practical experience in electronics or soldering, but your instructable was such that I have confidence in working it.
Lastly, do you know of any clean 2 LED stars out there? I'm really keen on trying to get a standard 6v or 9.6v battery pack so I can make these en masse for my biking buddies. I like my friends, but not enough to buy them LiFePo batteries and chargers =).
Thanks!
http://www.instructables.com/id/Ultimate-Night-Vision-Headlamp---500%2b-lumens-with-/?commentflag=1197172770613#CL3Y7GCF9T3NLK1
Try collaborating with the author next time for a single consolidated instructable. Because it's kinda annoying to hear the same thing twice. However, I think this has a better explanation. Cheers!
The project that you linked does not deal with heat dissipation very well, this one seems much better. I'm going to replace my home made 12v halogen bike light with one of these. There are a few features in this instructable; http://www.instructables.com/id/Bright_Luxeon_LED_Bike_Light/ that I'll be using as well. The rc helicopter heat sinks are a great idea. One 3-diode module is enough for me though.
Great instructable, thanks.
NewEgg sells thermally conductive glues in their fan and heatsink section.
You also might be able to use JB Weld which is available at your local auto or hardware store. It is a metal filled epoxy that is strong as well. No data on its thermal conductivity, but it is cheap and handy.
Good luck.
what did you use for a battery?
combine with my project and get awesome:
http://www.instructables.com/id/Putting_A_Car_Horn_On_Your_Bicycle/
