3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High power LED bike head light with integrated heat sink
For those of us traveling by non-motorized conveyance (bicycle e.g.), visibility is important in both forenoon and post-twilight conditions. The best way to ensure such visibility is through the use of excessively bright lights, of which the latest light emitting diodes (LEDs) are the acme. The following account will detail the process of building an LED based head-light capable of of more than 500 lumens of output using about 6W of electrical power. For comparison, this is the same output as a typical 45W halogen bulb.
Step 1Bill of Materials
Bill of Materials
The high powered LEDs used for this Instructable are very efficient, putting out 80-90 lumens per watt, compared to typical incandescent and halogen bulbs. However, they still generate a lot of heat and the lifetime of the LED will be adversely affected by high junction temperatures. Therefore we want to get the heat away from the LED through ensuring good thermal contact with the LED board, high thermal conductivity in all materials, and good coupling of the thermal energy to the surrounding medium (air). The LED star board used for this project has three LEDs on it and has a metallic backplane that is isolated from the LED electronics. This is a good thing. The rest of the LED head-light is built out of copper fittings from the local hardware or home improvement store. To complete the project you will need:
Parts:
Luxeon Rebel Endor star 3-up LED
Endor star lens
Buck Puck constant current LED driver
3/4" Copper Pipe Cap
1" to 3/4" Copper pipe reducer fitting
Waterproof connector of your choice (I use 2 position automobile trailer connectors)
Supplies:
Conductive epoxy (thermally or electrically)
JB Weld or similar high strength epoxy
RTV silicone or epoxy for waterproofing
Silver solder and flux
emory paper for cleaning copper
Tools:
hacksaw
drill and bits
file
propane blowtorch
vice
hammer
sandpaper
153 comments
1-40 of 153next »
Sep 11, 2009. 7:55 AMmichael.su says:
Hi Jon, I finished the Housing....just have to add thee electronics now :-) Thought you might like to see pictures..... More pictures to come when it's all together. Thanks again for all the help. -Mike
Jun 28, 2010. 6:50 AMmichael.su says:
Hi Jon, I just figured I'd post an update on my light. I've been running it for about 9 months now with no problems at all. It's been completely reliable so far. I get at least 2 hrs of light with a full charge out of it and have yet to run it dry. As far as the heat is concerned.... The extra thermal mass seems to make a huge difference for my light. It barely get's hot at all! Just slightly warm. If you remember, I'm only using 2 of the 3 LED's on the board. because of my battery selection I did not have enough voltage to drive all 3 LED's. (7.2 V 3300 MAh Nimh) That being said, I am running them dangerously close to 1000 mA so they are pushing a lot of light. so far so good (knock on wood) Regarding the optics, I also think the beam is a little too wide for my trail riding. on the other hand my buddy has a light that is too narrow. I definitely need something in the middle of the two. Well, I was googling for new optics since LED supply had no new offerings and I came across this: http://www.luxeonstar.com/Carclo-18-Deg-Tri-Lens-With-Holder-p/10507.htm At 18 deg, I think it may just be the sweet spot I'm looking for. I ordered 2 and will let you know how it goes. -Mike
Jul 6, 2010. 7:20 AMmichael.su says:
never mind on the 18 degree lens. It will ONLY fit on the the luxeonstar boards. you will have to purchase their 3-up board in order to use that lens. it does not fit on the LED supply board. different LED spacing :-(
Sep 11, 2009. 8:53 AMmichael.su says:
Thanks, I thought about machining some fins into it but didn't have the time. I guess I could still groove it if I need to. or attach a heatsink to the top. I also added screws to hold down the Star so I don't have to pot it just in case I burn it out and need to swap it. I am going to put some heatsink grease under it to help with the thermal transfer. Which resister would I need to change?
Feb 4, 2011. 10:40 AMhydronics says:
check it out..... I used an Epoxy mold that allows for side lighting... or 180 degrees of light.
http://www.instructables.com/id/Bike-Light-2011/
Apr 25, 2010. 5:28 PMSeezor says:
I've made this and I like it.  Easy to make and use.  Very simple mounting.  The only thing I did not like was the light itself.  Not knowing I got the one you suggested and it just does not do it for me as far as a good beam.  I will be making another to be helmet mounted using this led.
http://ledsupply.com/creexpg-w417.php
When I talked to a person at LED supply, he told me this was their latest and greatest and has a few different selections for optics.  I've done a dual mount side by side using these and they are very good.  Using your design I've also done side by side tubes Bike mounted I call my Double Barrels using these
http://ledsupply.com/luxeon-leds.php
I like these also because of the selction of optics I get a better beam.  Thanks for your design and I look forward to making more
One other thing I did was to mount my Buck puck on the battery housing which sits in a top tube bag near the handle bars.  No reason for that except not confident enough to square out the end of the tube.  CS
Apr 1, 2010. 12:10 AMpeterlonz says:
Good detailed instructable.
IMHO the soldering processes are a bit difficult & I suspect the junction temp may be right on the limit ,although even if it should cut the life by 80%, I suppose that's no matter really.
Problem as always is getting a conducting medium to get the heat away & I am not keen on conducting epoxy.
I wish you could hurry the update, I bet you have some real improvements to show us.
Apr 13, 2010. 11:56 AMmichael.su says:
I'm also looking forward to it!
Apr 3, 2010. 7:22 PMMACKattacksnipe says:
steam punk-ish
Mar 30, 2010. 8:07 AMwiredcur says:
Looking forward to it!!
Mar 16, 2010. 4:07 PMbaratacus says:
You don't want to blind other people on the road with you.  Not only will you make motorists angry and endanger people by blinding them so they can't see, but you can be ticketed and fined for opperating a vehicle in a hazardous manner.   The flood light is great for off road applications where you need to see rocks and chuckholes, low branches... but for on-road, you need a focused beam for a light that intense.
It's the same reason  that motorists who put HID xenon lights in a normal lamp housing without a focusing lense get fined and ticketed.
Excellent headlight option.  Once focused, you can probably go with a less powerfull setup and your battery pack will last longer.  Lithium is the way to go for high power output in a small size.
Mar 17, 2010. 11:34 AMbaratacus says:
I agree that visibility is an issue, but putting out 600lm of light in an unfocused beam, That lamp puts out way more light than the 60 watt incandescent bulb in your photos.   If it's as bright as you indicate then that is an issue.  My car has old-school seald headlights and it puts out less light with the highbeams on than that LED light you built.  If that light wasn't focused it would blind anyone looking at it.  You would be visible, but the motorists wouldn't be able to see anything else after they were night blinded by your light.    If you want more visibility then a multi directional lower output light would be a good start. I think the 100 lumen tail light you mentioned sounds perfect, and would do good as a front marker light as well.  In california though, on-road, you would be fined for running a 600 lumen  light  without focusing it.
Mar 18, 2010. 5:54 AMbaratacus says:
I don't dissagree at all.   The police here in my city are ticket happy when it comes to unfocused headlights.   They are'nt very concerned when it comes to satndard bike lights because they don' t typically put out more than 50 lm's of light.  I think a flood will provide you with much more visability than a spot.  I think with your light it may require some focusing for the law enfrorcement  officers to be ok with it.   That of course is pure speculation based on the sample pictures you provided.   Personally I intend to make one of your lights for myself, cause it's just too damn cool a project not to build.   When I do, I'lll be able to see first hand whether or not focusing the light is a concern.   focusing the light  is a very simple matter, and if I do feel it's necessary it will be pretty easy to shape the beam.
Feb 19, 2010. 10:40 PMspeeddemon2008 says:
Thankyou so much for making this! you have inspired me to make one so I did. I made it last spring and have enjoyed ever since. I ended up using a cree M-CE led.  I then used the thermal paste to glue a 1in and 3/4in pipe cap back to back and followed your directions. I have had fun with the battery pack though, its been a struggle.
My pack consists of 4 18650 lithium cells. I use 3/4pvc for the case. I put a nice screw top on it so the batteries can slide out. And just tonight have I figured out how to securely fasten it to the bike in a way I like. This has been a great project!
The second picture has version 1 of the battery pack...it failed...
Feb 23, 2010. 8:52 PMspeeddemon2008 says:
I have mounted my light to the underside of my handlebars, so the switch is at the bottom usually. I dont even have the back of the case to the light covered. I figured rain isnt likely to come back and hit it from the back side, and I keep my bike indoors. So no I have not had any problems with rain yet... but there is most definitely a possibility since I do live in Oregon, rain all the time. I drive my light at 700ma and it is rated for 740 lumens at 700ma. My friends all say it looks like a motorcycle from head on, and when I ride past someone I often hear "Oh geez, I thought that was a car." I do keep the light pointed down as I do not want to blind anyone, but there is still enough scattered light to illuminate street signs. Im tempted to make an Instructable about my battery pack, for specific use with this type of high draw bike light, and more universally for the 18650 battery cell; what do you think?
Feb 5, 2010. 11:47 PMJr Hacking kid says:
I want to make this but...... i have no idea on what voltage to power it. i want to power it with some duracell 2650mah AA battery cause i can get them cheap at my swap meet but.. i don't know  how many  do i have to buy.
Help me out in clueless at the moment Thanks
Feb 6, 2010. 2:07 PMJr Hacking kid says:
oh they are rechargeable 1.2v 2650mah AA battery so in my case i need 10 of those to get 12 volts right what if i have 12 battery cells will that work also and yea im just going to make it according to your plans i like how it looks and i can just buy all the parts in one place without waiting for the parts  to be shipped all the way from china to hawaii. thanks for helping me.
Oct 17, 2009. 10:29 AMdcbrc2 says:
Really nice job on this: I really wanted to "do it right" using a driver and LED's, this really gets me going.
One question: is there any reason that the buck puck needs to be in the light unit?  The way I'm thinking of doing mine would be more convenient with the buck puck at the power pack.  That shouldn't be a problem, should it?
Thanks,
--David
Sep 23, 2009. 11:13 AMmichael.su says:
That looks good Jon. Very good price considering how few options there are out there for this application. The multiple modes are not real useful for me, I just like on/off. I pretty much stick to trail riding but at the price, I can deal with it. I can't get the link to the datasheet you posted to work. not sure if they are just having server problems but what did you need to do to modify the circuit to lower the current output?
Sep 11, 2009. 7:53 PMmichael.su says:
update, Using a 9 volt battery instead of my 7.2 nimh I get an ammeter reading of 52 vs the 7.5 reading so the input voltage is directly related to the current. It does not appear that I am getting any voltage boost from the LED driver board. Perplexing to my feeble mind. I took everything apart and wired in the second LED driver board in to rule out damage to the first one creating a problem but the test results are pretty much the same :-( Not sure where to go from here....... -Mike
Sep 15, 2009. 6:17 AMmichael.su says:
Thanks for the suggestion. I added a 47 uF (50v) Capacitor. No change in voltage or current. :-( I saw that LED supply offers a "boost puck". looks like it's just what I need. it's a bummer that they are only regulated at 350 mA though......if only they had a 500 mA version. I can't seem to find any other similar products around the net. Have you seen any other LED drivers that are designed to boost voltage? not enough people using this stuff yet I guess....
Sep 15, 2009. 9:33 AMmichael.su says:
Yikes! I understand the theory of the 2 circuits but can't seem to apply them to the physical board I have :-( If I get you a good quality close-up picture of the board do you think you could tell what configuration it is? or maybe you could link me to a couple pictures of similar circuit boards with the different configurations? The writing on the transistor is "7N3" -Mike
Sep 15, 2009. 6:16 PMmichael.su says:
ok, here it goes......
1-40 of 153next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:jmengel
