3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High power LED bike head light with integrated heat sink
Step 9Test Shots
Test Shots
This step just shows some various comparison tests for light output and beam pattern. The first set is in my basement, with the camera set on a fixed 1 second shutter time and distance to the far wall of 25 feet. The first photo is the scene illuminated by a bare 60W incandescent bulb in the ceiling. The second shows the same scene illuminated only by a 10W narrow (15 degree) spot halogen bicycle light that I built. The final pic is of the scene illuminated only be the LED bike light detailed in this instructable. It is clear that the output of the LED light is much greater. However the ability of the LED to put light in a specific spot is not clear. The optics need some work if a spot type light is desired. I plan on taking some outdoor beam shots when the weather is a little more cooperative. Stay tuned.
10 comments
Mar 16, 2010. 4:07 PMbaratacus says:
You don't want to blind other people on the road with you.  Not only will you make motorists angry and endanger people by blinding them so they can't see, but you can be ticketed and fined for opperating a vehicle in a hazardous manner.   The flood light is great for off road applications where you need to see rocks and chuckholes, low branches... but for on-road, you need a focused beam for a light that intense.
It's the same reason  that motorists who put HID xenon lights in a normal lamp housing without a focusing lense get fined and ticketed.
Excellent headlight option.  Once focused, you can probably go with a less powerfull setup and your battery pack will last longer.  Lithium is the way to go for high power output in a small size.
Mar 17, 2010. 11:34 AMbaratacus says:
I agree that visibility is an issue, but putting out 600lm of light in an unfocused beam, That lamp puts out way more light than the 60 watt incandescent bulb in your photos.   If it's as bright as you indicate then that is an issue.  My car has old-school seald headlights and it puts out less light with the highbeams on than that LED light you built.  If that light wasn't focused it would blind anyone looking at it.  You would be visible, but the motorists wouldn't be able to see anything else after they were night blinded by your light.    If you want more visibility then a multi directional lower output light would be a good start. I think the 100 lumen tail light you mentioned sounds perfect, and would do good as a front marker light as well.  In california though, on-road, you would be fined for running a 600 lumen  light  without focusing it.
Mar 18, 2010. 5:54 AMbaratacus says:
I don't dissagree at all.   The police here in my city are ticket happy when it comes to unfocused headlights.   They are'nt very concerned when it comes to satndard bike lights because they don' t typically put out more than 50 lm's of light.  I think a flood will provide you with much more visability than a spot.  I think with your light it may require some focusing for the law enfrorcement  officers to be ok with it.   That of course is pure speculation based on the sample pictures you provided.   Personally I intend to make one of your lights for myself, cause it's just too damn cool a project not to build.   When I do, I'lll be able to see first hand whether or not focusing the light is a concern.   focusing the light  is a very simple matter, and if I do feel it's necessary it will be pretty easy to shape the beam.
May 10, 2009. 6:59 AMfabelizer says:
Very nice! Great job on the instructable. Where did you get your LED and lens? Any info on length of run on a given battery? -fab
Nov 14, 2008. 9:35 AMfrenzy says:
i bought a 4.5 watt high powered light from a cataloge, and this seems MUCH more powerful. thanks for doing it.
what did you use for a battery?
combine with my project and get awesome:
http://www.instructables.com/id/Putting_A_Car_Horn_On_Your_Bicycle/
Nov 14, 2008. 9:05 PMXilStorm says:
lol. if you're riding with other people, you could scare them off their bikes. Just don't do it in traffic =)
Nov 14, 2008. 11:28 AMJonathanPeterson says:
I don't know that a spot lens is really preferable. One of the big problems with led bike lights is that they don't have as much scatter as halogen bulbs, so you aren't as visible to drivers on side streets. If you're throwing that much light out there, drivers are going to know there is something out there - even if it might be a low flying plane.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:jmengel
