****DISCLAIMER!!!!!***** I AM NOT RESPONSIBLE FOR ANY INJURIES, DEATHS, LOSS OF PROPERTY, EXPLODED BIRDS, OR DESTRUCTION OF THE PLANET!
Step 1: Materials
MATERIALS:
>Some old keyboard with LED`s for the capslock, numlock ect.
>Another keyboard (It wont get taken apart, and it will still work perfectly after using it)
>Wire (any kind will do)
>Power supply (One that will power the motor, witch will probably be only a few volts) I used a wall adapter.
>A relay that dosen`t need much power to trigger it. (I used a solid state (light) relay)
>BB gun or other type of (mostly) harmless weapon
>Ammo for your weapon of choice
>Some kind of motor to pull the trigger.
>Computer with internet (it will be safe)
>Bird (optional)
TOOLS
> Eye-ware
>Pen
>Dremel or other rotary tool
>Something to test the circuit (an led will do)
>Tape!
>Project box of some kind
> Scissors
>Miscellaneous tools. Pliers, screwdriver, ect.
>Soldering stuff
Step 2: The keyboard
Then take all the stuff out.
Step 4: Soldering
UNPLUG THE KEYBOARD
Remove the LED that flashed by either desoldering it, or cutting it of.
Then solder 2 wires onto the circuit board where the LED was. IT WILL BE HARD TO SOLDER WIRES ONTO THE TINY LITTLE BIT OF SOLDER ON THE CIRCUIT BOARD. BE CAREFUL NOT TO SHORT IT OUT BY DRIPPING SOLDER BETWEEN THE CONNECTIONS ON THE CIRCUIT BOARD. IF YOU NOT AN EXPERIENCED SOLDERER, YOU MAY WANT TO ASK SOMEONE FOR HELP.
Step 5: Testing
Unplug the keyboard.
Step 7:
Step 10: The Trigger puller
Step 11: Testing (again)
Step 12: Here we go!
Step 13: Final setup
Make sure its still plugged into the computer...
Step 14: Download...
http://www.autohotkey.com/download/AutoHotkeyInstall.exe
Step 15: Auto hotkey
Right-click an empty spot on your desktop or in a folder of your choice.
In the menu that appears, select New -> AutoHotkey Script.
Type a name for the file. (preferably one your enemy uses allot)
Right-click the file and choose Edit Script.
On a new blank line, type the following:
"Send {NumLock}"
(without quotes, case sensitive)
Step 16: Now, put the file somewhare...
Right-click-drag the file to the desktop, and select create shortcut.
Right-click the shortcut, and select properties.
Goto the shortcut tab.
Select change icon.
Change it to the icon of the filename you gave it in the last step.
If you cant find the icon, select browse, and goto program files>{the program you want}.
It will probably be in there somewhere.
Visit Our Store »
Go Pro Today »
I need to update this tutorial. I made when I was 11, and it kinda sucks now that I have an arduino and other microcontrollers.
