iImage Information
In this Instructable I will teach you how to build a High voltage power supply using an Ignition Coil.This project uses a 555 timer based circuit.We use a 555 IC because an ignition coil needs a squire wave signal to power it. so basically the 555 timer is making pulsed DC electricity which powers the ignition coil.
Step 1Danger High Voltage!!!
iImage Information
This project shows how to make a High voltage power supply which produces about 30 or more MA, which is enough to Kill you! so Don't try this if you are not experienced with high voltage!
have to do
Capacitor smoke is a smell that lingers around the workbench long after the cap dies.
http://www.powerlabs.org/highvoltage.htm is the owner of the image, you've just cropped it so the "(C) http://www.powerlabs.org"
Do you have permission to use that graphic?
Any one with idea should help me send d contribusion to gaftech03@yahoo.com
