High voltage power supply for Nixies, CFL, Neon-Glow-Bulbs etc. for my steampunk objects
 by Junophor
Featured
Hi everybody
This instructable is also a summary of my own experiances in constructing funky light objects using the electronic from a disposal camera, as the knowledge of other projects and constructive ideas from the internet.
So it was my aim to write an clear DIY :-)))))) tutorial which can be followed by everyone who tries to do it for him- (her)self.
Before I started my instructable career, I was looking severeal times in the internet and found a lot of similiar projects which worked with this electronic. There was only one problem to me because nearly all of them had one common mistake: You never saw where to solder exactly the last wire to finish the project successfull!
That´s why I sat down and tried to find out my own best solution. I have to say that I´m not really good in working with electronics and I also can not draw the circuit of the used electronic from the disposal camera but I can show you now exactly where you have to solder your wires to light a flickering candle bulb, a cfl-tube , NIXIE-tube or a Neon Glow Bulb with only using a 1.5 Volts battery. I tested a lot of different disposal camera types (Agfa, Kodak, Fujii) and came to the conclusion that the ones from Fujii work best. Since then I always use only the electronics from Fujii-disposal cameras.
And now here comes my solution in which way I use to work with and I hope that will answer most of your questions about it.
If you follow carefully myt really detailed step by step instructabble, you should get an impressive result.
Before you start please notice two things:
First: There exist two different types of disposal camera s from Fujii which I used: One is driven by an AAA-battery and the other one uses an AA-battery. I call them the "AA-Type" and the "AAA-Type".
Second: Don´t wreck your health and please obay the follwing advices:
***Disclaimers***This instructable works with voltages in excess of 250V. This is more than enough to give you a potentially fatal electric shock if handled incorrectly. If you are unfamiliar with how to work with high voltage, please refrain from performing this instructable. Exercise caution throughout the following steps to avoid electrical dangers and also use insulated tools like pliers and screwdrivers and so on.
If you choose to undertake this instructable, you do so at your own risk.
Please obey that most of the gasfilled CFL-Tubes also contain some Quicksilver (Hg). Dont break them!!!
This instructable involves soldering. A soldering iron becomes very hot during its use, to the point where it can cause instant second-degree burns. Exercise caution throughout the following steps to avoid burns. If you choose to undertake this instructable, you do so at your own risk.
Step 1: How to get the electronic from the disposal camera (AA-Type)
I start the description with the AA-Type which I prefer because to me it seems to have more possibilities.
First you have to cut of the paper. Then you open the plastic part of the camera´s bottom to take the AA-battery out and then open the camera carefully.Then you can take out the electronic easily.
badideasrus says: May 30, 2013. 1:15 AM
i'm no electrical type person, but i believe the warning about dangers of this devise are highly over rated. the first part is that it is warned that the devise creates 250 volts. however it is not voltage that kills or hurts, it is current. and it is powered by at most, two AA batteries. the curent provided by both is not enough to even feel.... and since you removed the capacitor, there is no store of energy that can be released. also, because the bateries have 1.5, or 3 volts depending on configuration, and you crank that up to 250 volts, you are actualy making the devise less dangerous, because voltage and amps are inversely dependant.
correct me if i'm wrong.....
(also, i've used these circuits as tasers to mess with friends and the worst it's ever done (with the capacitor intact....) was burn alittle. (.... it hurt too. >>. but removing the capacitor makes this circuit almost harmless as far as i can tell)
NinjaMidget says: Jan 17, 2013. 9:02 PM
Ok, love the instructable. I did this on several flash units that I had from old disposables. I took an AC reading and it was 570v ac..that's a lot of voltage. I was wondering if I would need to put a resistor in place to hook it up to one of the cfl bulbs since they are normally running on 120v (at least here in the U.S. I know enough about electricity to have a healthy fear of such voltages...any and all feedback would be appreciated.
NinjaMidget says: Jan 16, 2013. 11:55 AM
Awesome instructible! FYI for anyone trying this..those large capacitors can hold a charge for years. I was taking the flash electronics out of several of these cameras from my wedding 3 years ago and a couple of the capacitors gave a pretty loud snap when I discharged them with a screwdriver. Even if you're working with old electronics, be careful around those large capacitors!
GrissleFist says: Dec 10, 2012. 6:29 PM
Pretty amazing! Going to try it out tonight. If you see a bright flash in the sky, it's just me. I am pretty new to electronics and your work is inspiring. Thank you.
ZaneEricB says: Nov 9, 2012. 12:26 PM
wHY ARE YOU SO AWESOME. Thanks...and now to the drawing board!
Effluxmind says: Oct 4, 2012. 2:33 PM
Enjoyed your instructable, found it very clear and informative. You need not be able to draw a schematic of the circuit to clearly convey your information. I am not an engineer, have worked in electrical/electronic areas for years and can both draw and read schematics. You succeeded at a very high level where reliance on schematics was made unnecessary. You also hit a very sensitive point on others not showing clearly or at all exactly where to make connections to the circuit for outputs for a particular project. I also found that a very frustrating point in researching this subject. Yes, I can power up a board and investigate with test equipment and trial and error until success is achieved. But man does not advance by continually reinventing or rediscovering what has already been accomplished. It is much more productive to research a topic and work from a good resource. I have found many resources for this topic and many have a very high level of technical expertise on the topic, some with schematics, but you have beat them all. Thanks for the knowledge.
Junophor (author) in reply to EffluxmindOct 4, 2012. 11:36 PM
Hi Effluxmind
Thanks for your kind words. Yes you hit the point why I left the schematic. I could have shown a drawing too (I am able to do so), but what for? Such a schematic might be very helpful to only a small group of electronic engineers, technicans, home constructors or electronic freaks but I thought that it was much better to show the circuit directly so that nearly everyone could follow....
I experienced that a lot of people worked with this instructable successfully (and of course told it to me) and that was my aim!!
Cheers Aeon Junophor
Roryfkl says: May 27, 2012. 10:46 AM
Hi I'm building a bike powered cfl headlight and I could only achieve full brightness on a (AAA-Type circuit) when I bridged the HA(+) ac/dc and the adjacent resistor (directly below HV+ in your picture). Although full brightness was achieved a slight buzzing resulted as well. Any thoughts why this works and will it cause problems in the future for the circuitry? By the way fantastic Instructable! Very thorough and great pictures!
Junophor (author) in reply to RoryfklMay 28, 2012. 11:51 PM
Hi Roryfkl
Very nice idea.
I will try to test your new grip of HV bridged in the described way.
I think there will be no further problem for the circuit to do it in this way but you may test it with one AAA-batterie and let it run down to see what happens. Then you can tell us your result
ebend12 says: May 3, 2012. 9:56 PM
Well your tutorial tells how to do it, but how does it work? What is actually taking a Low V high Amp DC to a High V low Amp AC?
the_don125 says: Apr 18, 2012. 6:25 AM
You totally stole the disclaimers from my similar instructable. :P Its cool though, and great job on expanding upon some of the more unclear aspects of crafting a camera into a HV power supply!
the_don125 in reply to the_don125Apr 18, 2012. 6:33 AM
Just for future reference though, it is generally considered courteous to cite your sources, especially if you copy-paste. :) I don't mind much, but there are people out there who will.
Junophor (author) in reply to the_don125Apr 18, 2012. 1:39 PM
Hi the _don125
I beg your pardon you are absolutely right. I took the disclaimer from your site but only for that reason that I have not known the right words for explaining the danger at that time. Let me say that I am very sad not to mention you as the source that´s my fault.
But let me also say that your instructable was the one which brought me to the job working with nixie tubes and disposal camera flash units besides the other neon gas filled lamps or cfl-bulbs. That waslong before I presented my first instructable here.
So once again sorry for my mistaking and please accept my apology. I will try to do it better in future
the_don125 in reply to JunophorApr 18, 2012. 3:01 PM
No need to apologize. :) I don't mind, and am honestly glad that my instructable was put to good use by someone. That's the whole point of instructables, to share ideas so that others may build upon them!
I was just giving you a caution, there are some people out there that become annoyed if somebody copies their work without referencing it.
longwinters says: Mar 18, 2012. 4:27 PM
Greetings from the Island of Maui:
I tried to send you some pictures of my latest project and my E-Mail would not cooperate, so here is one or two, I would also like to thank you for this instructable because I was able to modify a different HV unit from another camera to work as you say.
The unit did produce a nice glow on one of the bulbs I have sent you when connected to the AC side of the diode.
Oh and there will be a clock on the top of my project to finish it out, plus a pendulam and some weights that are illuminated.
all I phone back up 061.JPGall I phone back up 065.JPGall I phone back up 063.JPG
Junophor (author) in reply to longwintersMar 28, 2012. 11:35 PM
Hi longwinters
Sorry that I have not answered yet. (I explained you why).
Oh this looks very good!!! FIVE points worth!!!!
The wood you used will shine very good after finishing indeed . Very tricky the ankles in the mirror front .There will be surely an interesting play with reflections of the moving pendulum and also the glowing oft the neon lamps .
The lamp on the right photo looks very stylish I love it !!! This fits perfectlly in!!
I am longing for your presentation.
Thanks again for the bulbs my brain is already working........;-)))
ricks says: Mar 11, 2012. 8:42 AM
My 13YO child is trying to build a home-made Geiger Counter. We have the GM tube created (we think) and are at the voltage stage where we need something in the 350-550 dc volts to allow the GM tube filled with helium gas to sense a ray passing through the tube.
It appears that if you take your feed from the DC side, the power is steady as shown by the tube staying lit. Is the DC voltage high enough or could you envision any changes to this Instructable to meet this need?
We are not electrically that knowledgeable, but want to get there if we can.
Thanks.
mrayw says: Feb 24, 2012. 9:35 AM
Looks cool. Any idea about the voltage or how much current it can put out?
makermike says: Jan 6, 2012. 12:19 PM
Great instructable! I have a question about the lifetime of the electronic circuit when driving a bulb. Since the electronics were designed only to operate the flash for, let's say, 24 exposures, operating a bulb continuously is really running it outside of its design specs.
Any experience in how long to expect the circuit to work before something blows?
Thanks!
Junophor (author) in reply to makermikeJan 7, 2012. 6:28 PM
Hi makermike
If you don´t raise up the voltage for more than 3,0 Volts, you can use this electronic circuit as long as other electronic circuits too. The only "weak" part is the transistor which might get too hot (and then melts/blows) if you take too much voltage.
Yours Aeon Junophor
techno guy says: Dec 23, 2011. 6:21 PM
If you use the ac part from before the diode, then can you use it to power a transformer?, because I heard that transformers work best with ac voltage.
tutdude98 says: Dec 23, 2011. 11:06 AM
can this kill you??
cmlucht says: Nov 21, 2011. 6:23 PM
what is the dc output voltage? thinking about making mini electro static speakers
techno guy says: Nov 17, 2011. 6:36 PM
Is it possible to use this to power a really tiny cathode ray tube?
Junophor (author) in reply to techno guyNov 17, 2011. 11:28 PM
Hi techno guy
Nice avatar indeed.
I dont-Think so becaiuse you normally need al litte bit more amps to generate th cathode beam.
Take care of you while trying because of the possible x-ray!
Yours Aeon Junophor
zack247 says: Nov 2, 2011. 4:47 PM
i was wondering if i could use one of these to power a CCFL, thanks!
hanelyp in reply to zack247Nov 17, 2011. 8:34 AM
Since the compact florescent tube is being driven in "cold cathode" mode, I'd expect the circuit to work for a CCFL (cold cathode florescent lamp). Best way to know for sure is to try it.
Junophor (author) in reply to hanelypNov 17, 2011. 11:25 PM
Hi hanelyp
I really do`t know if it works. Isn´t it so that a ccfl needs about 1.000 Volts?
Please report about your tying and experience.
Yours Aeon Junophor
astrong0 says: Nov 17, 2011. 10:01 PM
AH yes... i remember now.... power down the capacitor first.... damn that hurt...
jjmns73 says: Nov 14, 2011. 5:34 AM
could you ramp this up to have an output of 120 ac with an in put of 12 dc
Junophor (author) in reply to jjmns73Nov 14, 2011. 8:12 PM
Hi jjmns 73
I think 12 Volts are to powerfull The transitior will oergeat very fast and the electronis breaks down.
But as you can see in my description you can reach nearly 210 Volts (AC or DC) by using a lamp an when measuring without a lamp the HV contact s you`ll get more than 300 Volts AC or DC
jjmns73 in reply to JunophorNov 14, 2011. 1:48 PM
hi junopher,
thank you for you help,what do you think a good in put would be? i have seen this instructables i am new to this site and it has peeked the tinker in me
imBobertRobert says: Nov 2, 2011. 2:08 PM
i cant believe how detailed this is!
Junophor (author) in reply to imBobertRobertNov 2, 2011. 3:24 PM
It´was a pleasure to me
But this seems to be the only possible way to put all important facts one time togther so that everyone could follow the steps successful
Yours Aeon Junophor
imBobertRobert in reply to JunophorNov 2, 2011. 4:24 PM
well im just glad that you arnt one of those people who skip the important stuff. keep up the good work!
Winged Fist says: Nov 2, 2011. 6:21 AM
Thanks for this detailed Instructable, and for the window into the secrets of your Steampunk magic! And thanks for telling us how not to burn, poison and electrocute ourselves!;-)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
