I've had this Hip Street mp4 player for a while now. It, Like a lot of mp3/mp4 players has a built in li-ion (lithium ion) battery. The play time has never been great. but lately I've pretty much stopped using it because it's deteriorated so much, its down to about 1/2 an hour per charge....no good.
so i decided to do something about it
Step 1: The guts
Was a very simple disassembly 2 tiny screws, and the lid popped off, revealing the guts.
Step 2: Taking out the battery
the battery was just stuck in there with some 2 sided tape, Carefully pulled it out
Step 3: Ripping out Some of the Guts
de-soldered the 2 wires, tossed the old battery (in an acceptable li-ion battery recycling bin)
Now to find a replacement
Step 4: New battery Disassembly
the Samsung A660 battery I had laying around was surprisingly easy to Carefully pop apart, revealing the li-ion cell with its protection circuit., a simple check with a multi-meter slowed me which of the 3 pins were positive/negative. I decided to leave the protection circuits alone, I was going to swap them, but decided the battery makers Probably designed the circuit to match the battery
Step 5: Jam it in there
I had to move the built in speaker a little bit, and its a touch to thick...but its capacity is worth it. Now before I could finish I had to wrap something around the battery to protect the circuitry. I used a ESD bag i had kicking around. Then I soldered it in there and
Step 6: Wrap up
Well the results seem good so far. I had fully charged the battery before I did this project, and since I re-assembled (4h+) I have been playing full volume, back light on, and the battery bar still shows full...so, so far so good., only side effects, side of the case is swelled out a speck... I'm not worried about that, and the SD Card reader jammed a little bit the first card i put in it, which also does not bother me...i don't really use the SD slot...and if i need to it still works...just harder to get the card out
All in all I LIKE IT
Would you think this kind of replacement will work with a Nokia Battery(i.e. BL-5C or other BL-Series and other variants of it) or any other cellphone battery?
The Nokia Battery has no protection circuits(obviously the nokia cellphone has the circuits), will this guide still help?
Thanks for the great instructible, I may use this guide as I have an mp4 which is quickly degrading on playtime.
