Step 3Construct the cups
You will use the first, second and third forms to make aluminum foil cups.
Once the cups are formed fold back the edges or use a pair of scissors or a knife to cut the edge of the first and second cups to make the heights of the cups about 1" to 1-1/2".
Make the second cup a bit shorter than the first by cutting off about 1/8".
Cut a circular (or other geometric shaped hole) centered in the bottom of the larger second cup about the size of a quarter or a little larger. You can increase the size after testing the results by burning a little alcohol. If you have enough pieces of aluminum you can use trial and error to find the optimum dimensions.
In the first cup cut out triangler sections about 1/8" deep around the top edge and about 1/8" to 1/4" apart. These will be the intake vents.
In the second cup cut out similar triangles about 1/2" deep and 1/2" apart. If you have a piece of aluminum that is big enough you can make its diameter a little larger than the cook pot and go all the way to the top instead of using cutouts for the exhaust ports.
Add Comment
