Introduction: Hockey Puck Bench Block
Somewhere in my jewelry making tool reading, I saw a hockey puck bench block. It is a nice handy thing to have for holding small items while filing, sanding or sawing. The rubber puck allows a semi sticky surface to hold things. I choose to mount my puck on a tapered piece of wood, which can be clamped to the workbench. Either laying on the workbench or hanging off, this is a very versatile tool fixture to have. The puck takes a lot of punishment and is quickly replaceable.
Step 1: Items Needed and Design
Items
Hockey puck – I used a real traditional rubber hockey puck. 1
inch thick by 3 inch diameter
Wood – 8 inch long by 3 ½ wide by ¾ thick. Wood should be
larger than dimensions for ease of sawing
Screws - 1 ¼ length general purpose phillip heads – I used three
Phillips - screw driver
Drill and drill bits - 1/8 inch diameter bit for the wood through-hole. I used
a ½ inch diameter bit to chamfer the holes edge, to recess the head of screw.
Saw – coping saw, power band saw
Sand paper and files
C-clamp or ratchet clamp
Household scissors
Optional – I use 110 pound card stock to put my patterns on.
This provides a thicker piece of paper to trace around.
Design
The design of the base is my idea of having the block hang
off a bench; to allow ease of sawing and filing.
With using a wood extension in my design; I wanted the
puck close to the edge of the wood as possible. Even
with the height of the puck, during sawing or filing; very little wood
around the puck is needed (I added only a ¼ inch). If you want, cutting the wood the same size as
the puck would be ok.
I am stuck on the rule of three, well not that rule of
three; but my rule of three. My rule of three, is it is easier to balance things with 3 items.
I am in constant pursuit to stay balanced. Therefore, I used three screws to
hold the puck to the wood base. The screws are approximately 1 inch from the
edge of the puck and 1 inch apart from each other.
Step 2: Cut Out the Wood Base
I made a copy of my sketch design on 110 pound card stock to make a template/pattern. I cut out the template/pattern with standard household scissors. Using
a standard pencil, I traced around the template/pattern on to my piece of wood.
I
am fortunate to have a power band saw. Using the band saw, I cut out the base. Using files, then sandpaper I soften the edges of the fresh cut wood - to avoid splinters.
Step 3: Drill and Screw Puck Down
I poked through the template/pattern for marking the hole locations.
I used a hand drill and 1/8 inch diameter drill bit
to create the through-holes. A hole larger than the screws makes it so the puck
can be drawn down (tighten) to the wood. So depending on what type screw you are using, go
with a bigger drill bit. The screw should drop in the drilled hole.
Then I used a ½ inch diameter drill bit to chamfer the holes; to recess the
head of screw.
Well anyway - plainly - I drilled some holes.
Note:
I did not drill into the rubber puck. The pucks are soft enough to just screw
into.
Step 4: Finished Hockey Puck Bench Block
I made several hockey puck bench blocks.
I gave some away, I kept a few.
I keep a few extra pucks for
replacement.
Step 5: Modified Bench Block
On one of my bench blocks - I added my wire forming fixture.
Workshop Contest
