Hold Down Toggle Clamp
2,043
62
12
Published
Introduction: Hold Down Toggle Clamp
After I saw in
the forum an inserted link from Stromer to me about so-called hold down toggle clamps, I decided to recreate them in principle. A CNC portal milling machine would be predestined for this project. But since I do not own one, or have a possibility of use, I first built a prototype for photos with the scroll saw. The photos of the items I edited with a graphics program, so that all fit on a DIN A4 sheet. The result is a 21cm long and 8cm high toggle clamp with a reach of 55mm.
Step 1: Template
You need a 9mm thick multiplex board on which you can apply the printed DIN A4 template by means of spray adhesive. So about 20cm x 30cm. I had a slightly larger plate and cut off the supernatant with my band saw.
Update here is the link for the template
https://www.izzyswan.com/product/toggle-hold-down-clamps-free-plans/
Step 2: Cutting Parts
Then saw off all parts on the scroll saw.
Step 3: Drilling
With the help of a drill stand you drill holes with a diameter of 5mm into all parts. Also the holes for the M6 threaded rod. Then take an M6 tap and cut an M6 thread into the pressure pad and into the lever. As Andruckklötzchen I have used a remnant piece of a 25mm thick Bucherundstabes. Turn the threaded rod in and counter it with M6 nuts. In order to be able to adjust the threaded rod more easily, I used a wing nut at the top.
Step 4: Final Assembling
just screw all togehter and lacker
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    12 Comments
    Nice job.
    I did it in metal (https://www.instructables.com/id/Grampo-De-Aperto-...
    Do you have a drawing you can scan in or a CAD drawing file you can attach?
    i used from this link
    http://youtu.be/oyL0w1aVDP8
    Can you please make a copy of the template available for others to download?
