Intro: Holga Tweak: Fix for loose film spool and uptake.
On some Holga models there is a black foam pad that sits between the film and uptake spools and the camera. The pad is rectangular in shape and serves...
Hot Glue Gun - (the kind used for general crafting, some consider this a cool gun)Hot glue stickScissorsFun Foam (Black 2mm thickness, comes in 12 by ...
1. Insert your glue stick into your hot glue gun according to manufacturers directions and heat up. This should be craft glue and not some sort of mol...
2. When the glue is heated and pliable, remove back of Holga like you would when you are going to change films. Remove uptake spool. If the pads are i...
7. We start from the left hand side, the unexposed film roll side. The smooth rolled part will go into the film roll compartment facing up toward you ...
Step 9: Press into place and repeat with other side.
9. Press pad into place, positioning it as told in instruction 7.(prior frame) Hold firmly for a minute or until glue sets. 10. Repeat with the right...
thanks so much for this tutorial - i have glue gun but no fun foam. that's sad. i have 2 processed rolls to pick up today - both ate the sponge. i'm going to do some shooting today and will try the cardboard jammy maneuver for now, but while i'm out i'll find some foam. i think my holga was punishing me for buying a nikon d40 and a macro lens and falling in love with another camera... silly holga, don't you know my heart is always yours??? thanks again!!!
Bio:Darin Barry is a Native American activist, writer, and photographer. As an activist, Darin was on the payroll of the New York City based political satire media campaign, Billionaires for Bush, Oil Ch...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
