Holmo Lamp IR Controller Hack
978
13
Posted in HomeLife-hacks
Introduction: Holmo Lamp IR Controller Hack
About: Why pay for stuff when you can make, build, hack, macgyver it. They are better and cheaper 100% DIY.
I recently bought a Holmo floor lamp from ikea to place on a corner off the living room, i place a led lamp for a mood light.
This lamp comes with a foot switch to turn on and off the light, this is a ideal solution for a walk true but not for my case.
So i had the idea to place a IR controller to turn on and off the light in the comfort of my couch using the TV IR remote to send the signal.
Using some electronic parts we can use the keys of the TV remote that doesn't have any function and use them to turn on and off the lamp.
Step 1: Watch the Video
Watch the video and see how the project works.
Step 2: Gather the Material
You will need for this project:
- PCB board
- Project box
- IR sensor
- 5V power supply
- ATMEGA328P-PU
- 2x 22pF capacitors
- 16Mhz cristal
- 10K resistor
- 1K resistor
- 100 ohms resistor
-12 ohms resistor
- BC548 transistor
- MOC 3020 optotransistor
- TIP 226 triac transistor
- Power cords
- Power strip
Step 3: Get Started
Using the arduino prototype board we will connect the IR sensor output to digital pin 11, negative to ground and Vcc to positive 5V.
Run the Arduino IDE and open the IR Sniffer sketch, Upload and open the serial monitor.
On the IR remote choose a key that you want to use to turn on an off the lamp and press in front of the IR sensor. A code will appear on the serial monitor, this is the code of the IR remote key, copy this to the Holmo Lamp IR Controller Hack sketch and upload.
Step 4: PCB
Using the schematic i made the PCB, a simple bare bone Arduino, i took out the shield of the IR sensor and place on top of the PCB.
I made a window on the project box and place a red filter from a old VCR to block some of the natural light this will block any interference to the IR sensor.
We will use digital pin 12 as the output to trigger the lamp to turn on and off, and the digital 11 to receive the IR signal.
The MOC 3020 runs with 3 volts so i place a 100 ohms to limit the 5 volt power supply.
This optotransistor will trigger the triac to give the 220v fase to the lamp.
Step 5: Lamp
I run the power cables true the inside the shade cover, on the hall side.
The IR receiver will be on the top of the lamp this will give more signal coverage, a place a small amount of hot glue to secure the receiver.
On the base of the lamp a place a power strip to plug power to the power supply and the receiver, to hide away the connections on the base a cut a small cardboard rectangle to cover it up.
Step 6: Possible Debugging
If you upload and it appears a error like " TKD2 was not declared in this scope " see this video to fix it.
Step 7: Final Thoughts
This simple project is a nice upgrade to the Holmo lamp using the TV IR remote to trigger on and off like any other device.
Tell me on the comments below what applications you will use this for.
Please subscribe to my YouTube channel
https://www.youtube.com/channel/UCL-jpfIywlIeSoJ-....
And follow me on Instructables
Thanks for reading
You're still here, go and make this project!
    • Flowers Challenge
      Flowers Challenge
    • Casting Contest
      Casting Contest
