Holowtech 2 Bearing Change (#2)
1,078
4
Posted
Introduction: Holowtech 2 Bearing Change (#2)
Quick one. There's nothing really "high tech" about my tool for changing Shimano Hollowtech 2 bearings. This time I've upgraded to cheap and cheerful Chinese ceramic bearings (size: 37x25x6mm; bearing symbol: 6805N).
Faster method comparing to old one. Basically I found piece of alloy pipe (quite hard not sure about the alloy type 7075?). I made eight cuts about 20-25mm deep and bent the strips as you can see on the pictures (pic 1, 2, 3) (nothe that the hole on the inside of the cup is slightly smaller than inner dimension of the bearing). Couple of gentle taps with hammer to remove plastic dust caps (pic 4, 5), pry off the seal with thin screwdriver (pic 6, 7) and finally not so gently taps to remove bearings. I had two bottom brackets, one was smooth and easy and second required quite a hammering to remove bearings. I've cleaned all the parts, the cups with 800 sand paper (pic 8) and greased inside. Pic 9 showing my stack mounted in a vice to press new bearing into the cup. Can be anything just two thick washers and 8-10mm screw. I'm quite lucky to have piece of alloy matching bearing dimensions but outer race from old bearing might be used to press new one (pic 10, 11, 12) (bearings needs to be pressed by outer race).
Keep the rolling and all the best in new year!
http://myarseiskilling.me/
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    2 Comments
    I think it is not necessary to use special tools made by yourself, I managed to disassemble this cartrige with steel hammer and flat screwdriver:
    https://www.youtube.com/watch?v=fT0cRpDzhqk
    I agree you can do it like that, but I had 4 out of 5 BB very stubborn, that's why I made it like that. Some say that you can fix anything with screwdriver and hammer ;-)
