Holy Yerba Mate With a Kick
6,019
16
10
Posted
Introduction: Holy Yerba Mate With a Kick
In this instructable, I will be showing you how to make an incredibly healthy and interesting herbal mixture with Yerba Mate, Echinacea leaf, and Tulsi, as well as a little lemon. This is the perfect morning concoction which tastes great, boosts your immune system and gives you a lasting kick of non-jittery energy. Give it a few fair tries and you'll be sure to love it. Although I wish I could write out the many pages of information available on the three herbs used, I think it should be sufficient to summarize their effects in the following paragraphs.
Yerba Mate is an incredibly healthy caffeinated drink most commonly consumed in Paraguay, Argentina, and Uruguay. Many antioxidants, minerals and vitamins are contained within the plant (actually more than even in Green tea) hence it has been said that it "contains practically all of the vitamins necessary to sustain life". Despite being caffeinated, due to the healthy constituents of the Mate plant it clears your head and gives you a lasting boost of giddy energy with no comedown later, and most importantly no jitters. The complex taste is quite full-bodied, bitter, and mildly earthy.
Tulsi is one of the holiest plants in india, and it is said to promote health in a plethora of bodily and mental departments (Circulatory system, respiratory system, strengthening of the stomach, increased mental accuity etc...). I find that it balances out the caffeine in the mate by giving you a more well rounded state of Awake and aware clarity for the day.
Echinacea leaf, gives this concoction a slightly nutty taste, and although it is not as powerful of an immune system booster as the Echinacea root, I have noticed some rather subtle, but pleasant improvements in my health since I have started using it.
This is my favorite mixture of herbs for morning and daytime. I haven't drank coffee in almost a year (since I discovered Yerba Mate), and I don't miss it even a little. Enough summarization of herbs though, it is time to prepare the Holy Mate!
Ingredients and Utensils:
Yerba Mate Loose leaf (Health Stores usually have some, however I prefer ordering it online since more choices and more authentic Mate is available).
Tulsi Loose Leaf
Echinacea Loose Leaf
1 Teapot
1 Lemon
1 Hollow Gourd (This is the traditional cup for drinking Yerba Mate. You can get it from the internet, or from certain health food stores, or herbal shops).
1 Bombilla (The traditional straw Yerba Mate is drank with. It has a screen at the bottom end so your herbs don't pass through).
Step 1: Fill Teapot With Water
First start by filling up a teapot or something you can heat water in.
Put it on the stove, and let it heat up.
While this is going on you can proceed to mix your herbs, though you should watch the pot and turn off the heat once it is steaming.
You don't want to boil the water. I usually turn off the heat once I see a fair bit of steam rising from the container.
Step 2: Fill Gourd With Loose Leaf Yerba Mate
Fill your dried out Gourd to about 1/3 of its capacity with loose Yerba Mate.
My gourd is large and it takes about 9 or 10 tablespoons of Mate to fill it 1/3 of the way.
Step 3: Add Tulsi Leaf
Add 1 or 2 tablespoons of the loose leaf Tulsi to your gourd.
I've found this is the perfect amount not to overpower all of the other herbs.
Step 4: Add Echinacea Leaf
Add about 1 or 2 tablespoons of the Echinacea leaf (depending on the size of your gourd).
This is the last herb to add, so make sure that your gourd isn't full more than halfway.
This will ensure you can fill it with enough water later and not waste any herbs. The Tulsi and Echinacea absorb water and expand a lot more than the Yerba Mate, so sometimes if you've filled your gourd too far you will only have a few sips of water to take each time you refill it, hence it is desirable to have it full of herbs at about the halfway point.
Step 5: Shake Shake Shake!
At this point, in order to get the more fine particles to stay on top of your mix of herbs (Later will explain why this is necessary), you want to put your palm on the mouth of your Gourd, turn it upside down and shake gently. This part of the process is almost like an art, once you start drinking Mate regularly, you will start to appreciate the shaking.
I prefer a circular motion with slight vertical shakes. This has worked perfectly for me.
After you feel you've given it a thorough shake, turn your gourd right-side-up again and tilt about 45 degrees to the side. You want your herbs to have a tilt inside the gourd at about this angle so one side has more herbs than the other.
Make sure this tilt is kept throughout the rest of the process, though I wouldn't worry about it if it isn't. It does make for a better Mate though.
Step 6: Add Lemon
This is an optional step.
At this point in the process, once your herbs have been shaken and tilted at an angle, you may want to add a few drops of fresh squeezed lemon (not too much) which will boost the vitamin C content of your tea and will also make the mix taste a bit more tart. If you want a less tart taste, don't add the lemon, and the tea will still taste amazing.
Step 7: Wet With Water
Once your herbs have been mixed and the optional lemon has been added, you will want to drizzle a bit of cold water onto your herbs. No need to add too much, this simply serves to protect the taste and benefits of the tea from the hot water which will be added later.
Make sure the tea is still tilted and you could either turn your tap to a slight drizzle and stick the Gourd underneath it, or you could take a tablespoon and use that to get the herbs wet.
After doing this, you should leave the gourd on a surface (in my case a mound of fruits, though you could put it in anywhere where it will be supported at an angle), and wait about 3 minutes for the herbs to absorb the water.
Step 8: Insert Bombilla
Now that your herbs are wet, you can take your Bombilla (the metal straw), put your thumb over the mouthpiece end, and insert it into the herbs at the same angle at which they are tilted. The Bombilla should go into the less full end and you should push in so it touches the bottom of the gourd, but is still properly covered by the herbs.
You are now almost ready for your morning tea!
Step 9: Pour Hot Water Into Gourd
Your teapot of water should be more than done by now. If the water is too hot (steaming far too much), then I would recommend waiting a little bit before adding it to the Gourd.
What you want is a temperature of water which is neither too hot to drink, nor too cold to extract the ingredients of the tea, so a slightly steaming pot of water is best.
Once this has been achieved, simply pour the water slowly into the emptier end of your gourd until you have filled it to the top. You may want to leave the tea for a minute before you drink it, but this is not necessary since it will be drank through the Bombilla.
You're done! You can now sip from the Bombilla and enjoy all the glories of Holly Mate, and its glorious kick of clear-minded energy.
Several Tips though:
1. Water is finished when your Bombilla makes that great empty cup straw sound we all know.
2. You can refill the gourd with hot water quite a few times after each cup. No herbs are wasted (I usually use my mix from the morning all day, resulting in probably about 7 or even 8 great tasting refills).
3. IMPORTANT!!! DO NOT STIR THE TEA WITH THE BOMBILLA!!! No, seriously though, not only will you possibly clog the Bombilla or end up drinking some of the leafage, but if someone else is preparing the Mate who has been doing it for a while, you will surely frustrate them. My mom always stirs it and my heart jumps (I've told her many times! lol). Either way, it is quite unnecessary to stir this mix.
4. Yerba Mate is considered a communal drink, so traditionally people will get together over some Mate (somewhat like people do with coffee). When you are enjoying Mate with friends, only one gourd is needed. The gourd is filled and first drank by the host. The tea is quickly drank, then refilled and passed to the next person who quickly drinks it too. This is done until everyone has had a gourd-full.
When drinking with friends, it is somewhat rude to "Bogart" the Gourd. It isn't like coffee, which you can sip on slowly. You quickly finish the drink, refill it, and pass it on.
5. The first sip of the morning usually brings a big smile to one's face. I enjoy drinking it in the sun, then doing a quick stretch or two. This makes for a fantastic morning and start to one's day.
6. You can drink this across the day, and even though it will keep your head clear and energize you, you will still sleep fine (or at least I find that this is how it goes).
7. This is the mixture I've found to be most pleasant to my taste buds, but you're welcome to modify and play around with the herbs and distributions as you wish.
For more information on any of the herbs I've used, here are some sites which I enjoy:
http://www.goyerbamate.com -Carries Paraguayan, Argentinian, and Uruguayan Loose Leaf Yerba Mate, and has alot of good info. (Not the only place to buy Yerba, but I've found that they have my favorite selection).
http://www.mymateworld.com/yerba_mate_health_benefits.htm -More Yerba Mate info (also the main site I believe sells the loose leaf too.
http://www.holy-basil.com/ - Tons of information on Tulsi and its health benefits (anti anxiety, immunity booster etc..), as well as historical info and anything else you might need.
http://en.wikipedia.org/wiki/Echinacea -The glories of Wikipedia =P. Has a bit of info on Echinacea.
ENJOY!
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    10 Comments
    I made this with a french press as an experiment, and I checked here to see if I was on track. Still looking for Tulsi, but I have plenty of regular basil in my garden. Very tasty. Inexpensive, considering I can top up the press with water and use it all day (something that is hard to to with my gourd and bombilla). And natural vitamins to boot. Great Instructable!
    give rosemonte suave yerba mate a try i love it! goes of arouns $20 for 4 kilos on ebay. ill have to give this a try with the tulsi and organic wild grown echinacea as it covers the prairies around me.
    You made it all wrong! You should press all the Yerba to half the Mate, then let luke warm water soak in for a few minutes. Then keep the Yerba shoved to one side and wash it down slowly as you are drinking it. This will make the yerba last longer. This is how they drink it in Uruguay. And they mostly use strait yerba.
    In Brazil 2. With hot water. Not boiled, but very hot.
    sick gourd and bombilla, sadly my gourd cracked... nothing glue cant fix. just try lots of mate like three big gourdfulls... two if your sane and youll be pritty jittery and use normal caffine and it will boost you to next year
    Yerba mate is great. I've been drinking it for ten years. Much better for you than coffee. I use loose leaf and mix it with some green tea or white tea when I want some clerity. I'll have to try the Tulsi tea as well. Teavana has some good yerba mate mixes too. I use their perfect tea maker. It's nice but hard to clean if leaves get under the mesh screen. They have a new one where the mesh comes out. I'm planning to upgrade soon. I haven't used a gourd in a long time. I should prob get a new one.
    Very cool. I was just looking at a very hard to obtain Yerba Mate bottled brew imported to the USA by individuals recently, however that brings the cost up to around $75 a case. A bit steep for me. This looks better anyways :-) (PS: the bottled version I was looking at is called Club-Mate).
    I have been skipping the gourd and been making my own tea bags of Mate~quick and easy in the morning~could all your suggested ingredients be combined and made into tea bags?
    Yeah, definitely! Personally I use a French Press, but I've used teabags before, and it works just fine. I just think this method has a much stronger taste, and takes more of the nutrients out. Plus you can refill it throughout the day. =)
    Provecho!! What I would not give for some empanadas and a matecito right now. Some day I may try Yerba Mate with Tulsi and Echinacea leaf . Good Instructable.
