3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Home Air Compressor Tank Drain Modification
When I got my 30 Gallon air compressor, I knew that I would have to occasionally drain the tank of condensation.  But draining the tank with the provided stopcock was a pain and a better device was needed.
The tank is carbon steel and even with a corrosion allowance, the thought of my tank rusting from the inside out just didn't sit well with me.  I wanted it to last as long as possible.  To make it last as long as possible, I needed a way to drain the tank, drain if often and drain it easily.  The method of draining the tank provided by the manufacturer was a pain at best - ie a stopcock at the very bottom of the tank (see picture).  Having to crouch down and dig thru the spider webs every time I needed drain the water out from the compressor was less than desirable (i'm no sissy, but sometime the little critters give me the willies).
Do I really have to make a disclaimer here about how to not mess with stuff that you don't know how to do like pressurized and electrical systems?  I guess so - PROCEED AT YOUR OWN RISK.  READ THE MANUALS.  CONSULT THE STARS.  TAKE A CLASS.  SPEAK TO A SPIRITUAL DIRECTOR.  DO WHAT EVER IT TAKES TO NOT KILL, MAIM OR OTHERWISE HURT YOURSELF. OR OTHERS.
Step 1The Valve
The Valve
 I knew that a quarter turn ball valve would be the best item to use to replace the current valve.
I wanted to put the valve where I could reach it easier, so that meant installing some piping.  I ended up running it out to one of the legs for protection and ease of operation.
I went with flared copper tubing because the copper was corrosion resistant, you can flare it which makes for easy installation and the flare tool was relatively inexpensive.  Another nice thing about the copper tubing, is that the water no longer sits in the vessel, but it sits in the tubing which can handle water better than the carbon.
The current valve was 1/4" NPT, so I stayed with that.  The assembly consisted of (in order of appearance):
1/4" MNPT by 1/4" Flare 90º
1/4" Copper Tubing
1/4" Flare x 1/4" MNPT Adapter
1/4" quarter turn ball valve - 1/4" FNPT x FNPT
1/4" MNPT x Hose Barb 90º (so the water can be run else where - I just let it blast on the floor)
Zip Tie
Don't forget your teflon tape!
3 comments
Nov 30, 2011. 12:23 AMcharlieb000 says:
this address another problem i see, the long tube allows all the water to drain into the pipe before you shoot it out (resovior), rather than needing to leave the under-tap open and wait for the drips to evacuate with the air. i tell others about this but nobodys interested.
Aug 18, 2011. 3:57 PMMr. E Meat says:
Very nice mod!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:BlasterMcDoogle
