Introduction: Home Automation Boiler Project
Picture of Home Automation Boiler Project
The purpose of this project is to manage the following automation scenarios in my house:
  • Remote check the outdoor temperature.
  • Remote check the indoor temperature & humidity.
  • Remote control gas boiler (on / off).
  • Automatic control/switch between solar and gas boiler for home hot water.
  • Android & HTML application for all the above.
Step 1:
Picture of
Α. Construction of central operating unit.
Matterials
  • Arduino Uno
  • Ethernet ShieldEmpty Shield
  • Power Supply Unit 12V/4,5Amp DC
  • Outdoor plastix box with IP65
  • Rail terminal blocks
  • Switch Rail Safety Fuse 10Amp
  • Switch Rail Safety 2Amp
  • LM35 temperature sensor
  • SHT1x digital temperature and humidity sensor
  • Servo
  • Relay 5V
  • Εlectronic components (resistors, transistors etc)
  • Relay 12V
Step 2:
Picture of
  • Remote control of outdoor temperature.
  • Read temperature value from analog input A0Remote control of indoor temperature & humidity.
  • Read temperature and humidity values from digital input D5 Remote control gas boiler (on / off).
  • Control gas boiler on/off with relay in digital output D7Trig from indoor therostat in digital input D9 (because my wife wants the classic thermostat at home...)
  • Read solar boiler temperature from analog input A3
  • Automatic selection between solar & gas boiler with servo three-way solenoid valve in digital output D6 for hot water.
  • Read the home water temperature value from analog input A4Manual trig between solar & gas boiler from digital input D8
Step 3:
Picture of
The page includes a manual trigger buttons, status of the outputs and the measurements of the sensors in real time.
Step 4:
Picture of
The Application icon on my mobile phone
The main screen with manual trigger buttons
The password & connection settings option (IP addresss & connection port)
Below you can see the settings you now have the application with red text
The sensors measurements (real time)
About the application..
For more info and Project visit my blog
http://arduinomorfeas.blogspot.gr/
bingdo72 (author)2017-07-02
Hello!
Hope all is well.
This is Jim from WIZnet.
As you might already know, WIZnet is well known for its hardwired TCP/IP chip and its W5100 being used in Arduino’s official Ethernet shield.
We also partnered with ARM as mbed silicon partners, and plan to offer more platforms for makers.
To help makers grow the open source hardware community, we are having an IoT design contest, titled ‘Curation is Creation.’
Come up with any IoT project idea and take advantage of this contest since we’re offering our ARM mbed-enabled WIZwiki-W7500 platform & WizFi310 shield at sample pricing.
To start, register your account at www.CyberMakerSpace.com
This contest will be held from May to August, with 16 prizes totaling $15,000.
We expect and hope that many makers, including members of WIZnet Museum www.wiznetmuseum.com, will participate and share their knowledge.
As this is a contest for the open source community, WIZnet wants to give back the power of the vote to all participants.
Hence, you can vote and provide feedback of other projects from September to October.
More details of the contest are available at www.CyberMakerSpace.com and technical questions are answered at https://forum.wiznet.io/
Hopefully, you’ll find interest in this contest and we look forward to your next creative IoT project!
Sincerely,
Best Regards,
Jim
bingdo72 (author)2015-06-30
This is good.
I have been searching some application references in which WIZnet solution is applied, and found your project using Ethernet Shield.
In the Ethernet Shield WIZnet's W5100 chip is embedded.
If you are O.K. I'd like to post this article in WIZnet Museum (http://wiznetmuseum.com) for others.
seamster (author)2015-01-02
Nice ideas! But how do you control the outdoor temperature? ;)
About This Instructable
5,769views
22favorites
License:
More by ghatzig:Home Automation Boiler Project
Add instructable to:
