Home Automation Using HC-05 BT Module
1,162
8
Posted in TechnologyWireless
Introduction: Home Automation Using HC-05 BT Module
About: I am an undergraduate student pursuing B.Tech in EEE(Electrical and Electronics Engineering).I am passionate about creating new stuffs using technology and hungry to learn more and more.
Using Home Automation one can remotely control any number of devices through a smartphone.
In this project we will be building an Home Automation system using HC-05 BT module with arduino and control the devices through an app developed using MIT app inventor.
You can recreate this project to automate devices in your room !!
The video is provided in the last step.
Step 1: Components Required
You will need the following components
>Arduino Uno R3
>LED ( Red x1 , Blue x2 )
>Breadboard
>Jumper wires
>Two Pin plug ( x2 )
>Bulb ( x1 )
>BT HC-05 module
>2 channel relay
>Power Distribution Board
>Smartrphone with an app installed to control the devices
>2 resistors with value of one resistor double than the other
Step 2: Build Voltage Divider for BT HC-05 Module
Since RX & TX operate on 3.3V logic
We need a voltage division of 3.3v for the connection TX of arduino -> RX of module
We have used two resistors of values 10k and 20k.
We have Vin=5V
According to calculations Vout=20k/(20k+10k) *5V so Vout =3.3V.
Step 3: Connecting BT Module With Arduino
Make the following connection:
Bluetooth Module Pin => Arduino Pin
TX => RX
RX => TX
VCC => VCC
GND => GND
Make sure you have colorwise arrangement as in the image (To avoid confusion at a late stage)
Step 4: Connecting Relay With Arduino
We make use of a Relay(an electromagnetic switch)which provides isolation between the high (the BULB) and low (the ARDUINO) voltage circuit.
Make the circuit connections as follows
>COM terminal (relay) => Supply from mains
> NO terminal (relay) => Supply line to bulb
>VCC (relay) => 5V ( arduino )
>GND (relay) => GND ( arduino )
>IN1 (relay) => D8 ( arduino )
>IN2 (relay) => D9 ( arduino )
Step 5: Connect the Devices
Since we are using a two channel relay we will be controlling two bulbs as our devices.
-connecting supply from mains to COM terminal on relay board.
and supply to the device to NO terminal on relay board.
Step 6: Add LED for Indication
This is not an compulsory step and is only meant as 'fail-safe' step meant to prevent blowing up of devices!
Before connecting the high voltage devices connect two LED which can be used for test purpose .
Red LED ( indicating device 1) => Digital pin 6
Blue LED ( indicating device 2) => Digital pin 11
Step 7: Upload Sketch
Download the attached arduino sketch and upload it using arduino IDE.
If you don't have an IDE, download from https://www.arduino.cc/en/Main/Software
Step 8: Build Your Own Customised App
I made use of the MIT app inventor to design my own simple application to control 2 devices through my Smartphone.
Here is the link to learn about making an app for yourself
I am also attaching an apk file of my application designed for this project.
Step 9: Control Devices Using Your Smartphone
-Open up your Smartphone
-Start your device bluetooth.
-Run the app designed for Home Automation.
-Pair up with the HC-05 BT module.
-Control desired devices.
Step 10: Watch Tutorial
I hope that you found this instructable useful.
The demonstrative video is also attached here.
Automate your room now !!
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    2 Comments
    Is there any need for Voltage divider if I use NodeMCU?? Because NodeMCU gives 3.3v in the digital pins
    This looks real fun. I'll connect devices such as my laptop to turn them on and use remotely although there might be better ways to do it which I don't know about.
