Step 6Add Yeast
For only a gallon of cider you will only need about 2/3 of the packet, but you don't have to be too precise. Follow the instructions on the back and dissolve the yeast into a little bit of warm water. Add a tablespoon of Yeast Nutrient to your mix (apples have a lot of sugar but not much nutritional value so adding yeast nutrient will keep your yeast healthy and maximize their efficiency)
Pour the yeast solution into your carboy and agitate slightly to get a good mix. Now put your vapor lock on (fill it up to the appropriate line with water or vodka) and secure it in the top of the rubber stopper. This will allow carbon dioxide produced from the metabolize of sugar to escape without letting bacteria and other baddies into your brew. If you don't have a vapor lock, you can place one end of a length of tubing in the opening of your carboy and put the other end in a glass of water (below the surface). When the build up of gas coming from the tube into the water reaches the atmospheric pressure on the water it will bubble up (which is the same thing that happens in the vapor lock, but a store bought one is much more compact).
I would say it's unlikely that your cider will have been invaded by harmful bacteria in 30 hours. It's actually less likely than a lot of people think (though its certainly a possibility). The major reason to use a vaporlock, in addition to keeping bacteria out, is to prevent naturally occuring acetic bacteria (minute levels in your cider are pretty much unavoiable) from fermenting aerobically. Aerobic fermentation will cause your ethanol to turn into acetic acid (vinegar). By keeping the vapor lock on, the yeast creates a cabon dioxide atmosphere, which prevents acetic acid from producing vinegar.
Also thank you for teaching us this! Without you (and lifehacker) I may never have thought to homebrew! <3<3
