This not the cheapest furnace but i had to buy a lot of my supplies. If you are a good scavenger/bargain hunter then your total price will be less than mine. Also propane compared to other fuels isn't the cheapest either, but it is clean and efficient.
Warning/Disclaimer: Working with molten metal is extremely dangerous. I do not claim any responsibly for any injuries or accidents that may occur during replication of this instructable. Always be safe when working with high temperatures and molten metal (don't do anything stupid and always wear safety equipment).
Do plenty of research and know what your getting yourself into.
Some references:
http://www.backyardmetalcasting.com/index.html
http://www.engineeringtoolbox.com/melting-temperature-metals-d_860.html
http://www.youtube.com/watch?v=lX6yFQNnk-A (this a charcoal foundry but there is still much to learn from it)
http://www.youtube.com/watch?v=B5wCVI7jCyQ&feature=related
http://www.instructables.com/id/My-Second-Aluminium-Foundry/step4/Refractory-Support/
Remove these ads by
Signing UpStep 1Materials
Burner:
-1/8" hex cap
-1/8" pipe (i used brass but steel would be better)
-1/8" to 3/8" brass fitting
-3/8" to 1/2" steel fitting
-1/2" steel pipe x3
-1/2" T pipe
-1/2" valve
-1/2" npt to 3/8" nptf fitting
- 1/2" to 1/4" reducer fitting
-1/4" x 2" pipe
-1/4" ball valve
-1/4" male quick disconnet
-3/4" steel pipe about 7" long
-Gas hose
-High pressure valve
Refractory:
-Portland Cement (crucial that its portland not masonry)
-Silica Sand
-Perlite (used in planting it is an aerated volcanic rock that doesn't absorb heat readily)
-Fireclay (i had no supplier of this but i used rutland refractory cement instead)
-Water
Furnace in general:
-Steel pots or pails (avoid galvanized apparently if they get to hot the zinc on them will release toxic fumes)
-1" id Steel pipe for burner inlet
-Drainage pipe about 2" long (leftover from making the burner inlet)
Crucible:
-Scrap sheet metal
-Scrap rod of various sizes (i used 1/4 and 1/8)
Various:
-Steel rod
-Cardboard
-Gaffers or duct tape
-Teflon tape
-Mixing tub
-Propane tank
-Set screw
Safety equipment:
-Welding Gloves
-Safety Glasses
-long pants
-flame retardant shirt or jacket
And of course lots of scrap aluminum to melt
But, why do I need a drainage pipe at the bottom of the foundry?
Please, reply.
In other words, sand is not actually required for curring to occur. However, it is recommended because it helps increase the strength of the concrete as well as slightly reduces heat conduction.
A suggest: in step 9 image, add some ordinary object for size comparison.
