Introduction: Home IOT Security System
Picture of Home IOT Security System
The Pictures are Screen Shots from My OpenSource Program Called OpenHAB ..I am using version 1.8 as I am comfortable with it
Step 1: Install Particle Power Shield
Picture of Install Particle Power Shield
You can use just about any Means of installing a Particle including using a breadboard ..But I opted for the Penteon power shield as I needed to have 1-18volt AC input and 12 VDC battery backup in the security panel . if your interested in purchasing the Particle Power Shield with relays contact Particle.io
Step 2: Install 12 Volt DC Power Supply
Picture of Install 12 Volt DC Power Supply
I gutted an emergency light Exit light charging unit with battery and LED light as I wanted to have some light in my Security cabinet to work as well as the Motion Sensors I've installed require 12VDC as a power source.
Step 3: Other Materials You'll Need
Picture of Other Materials You'll Need
You will need to purchases some PIR's(Motion Sensors) they are readily available from Amazon fairly cheap..As well as a Kidde Smoke Relay Module if you have Kidde smoke detectors in your home.I would recommend having Powered smoke detectors anyway as battery units can fail.
I also purchassed
2 x XBees 900 MHZ
2 x Particle Photons (particle.io)
2 x Particle Power shields (I designed and had these made but are available from Penteon.io)
Step 4: Particle Power Shield and XBee Configuration
Picture of Particle Power Shield and XBee Configuration
I am also using an Xbee to transmit motion sensor data from my Camper(Workshop) to the main House using 2 900MHZ XBees and a Particle shield
Step 5: Programs
I used Node Red (nodered.org)as an intermediary between the Particle and my Home Linux Server
I used OpenHAB as (OpenHAB.org) as my home monitoring Program
I will Post the code and drawings of the sensors and controls here in the following days
About This Instructable
1,071views
26favorites
License:
Bio: I'm a journeyman Electrician ,Budding electronics engineer ,I have 2 dogs and a cat and a lust for information and learning
More by jade7272:Complete Raspberry Pi / Nova Wireless Home Monitoring and Automation System ...DIY Wireless Phone Charger & LED ControlHidden Secret Hiding Places Jewelry Box
Add instructable to:
