loading
Step 3: Step Two
After you have applied the ring to the bucket it is time to make straps that will allow it to be fastened to a hiking backpack. These can be made from any material. I re-purposed some used bike inner tubes. Cut the valve off both tubes. Next hook the key rings to the small holes the handle mounts in on the bucket. This gives you a spot to tie the ends of the inner tube to create a strap to tie to a back pack. Next cut two slits in each side of the inner tube to create a loop for a cross strap to thread through the other inner tube. Connect the ends after you have threaded it through the other inner tube.
Strong smells of any kind will attract bears...BBQ, deoderant, bug spray, febreeze, whatever....
This is NOT bear-proof and no one should rely on this in an environment where bears are common. Bears in the continental U.S. can easily weigh upwards of 300 pounds, and that's just a black bear. Go to a place like Glacier National Park and you've got grizzlies to contend with. <br> <br>As other people have mentioned, many parks and national forests have rules for bear-proof food storage, and they're not messing around. The ones they install are made of very solid welded steel and are either Dumpster-style (weighing more than a ton) with steel-covered top and self-locking small openings that require hands to operate or are chained/cemented into place and also made of heavy steel. Certified bear kegs are smell-proof as well as puncture resistant in addition to being able to withstand a hungry and persistent bear jumping on them over and over. <br> <br>Things like Febreeze do not eliminate odors, no matter what the commercials claim; it simply masks them and is in no way sufficient to stop a bear from detecting your tasty morsels. <br> <br>Spend the money and buy a real one if it's actually a concern, or save your money and don't bother making this.
Buy a bear can. As mentioned, if you go to a place where they require a certain kind of can and you don't have it, you'll either have to leave or rent one of theirs if they have one. Besides, for the amount of time it would take, spend the $50. <br> <br>People do and should hang bear cans. A bear may not be able to open it, but they can smell the contents and will spend an undue amount of time trying to open it, inclusive of smacking it, dropping it, and kicking it. Half an hour later, the bear will have left your can three-quarters of a mile away on the wrong end of a 200 foot cliff.
I love the inner tube straps, I could see using something similar on any bear keg (homemade or not,) to fasten to a pack. <br> <br>I think this is a really nice critter proof bucket, but I would have some concerns about using it in &quot;bear country.&quot; The two concerns I would have is the lack of locking mechanism on the screw top (bears have been known to unscrew lids,) and the thinness of the plastic bucket. I determined bear would probably be able to gnaw through a regular bucket. <br> <br>Hanging eliminates these problems by keeping it out of reach, but If you are going to be hanging it, why use a bucket at all? I've never seen anyone hang a bear keg. What is the benefit of this over a simple waterproof bear bag? <br> <br> <br>Additionally, I've been to some National Parks (Grand Teton for example) where they require approved bear canisters during bear season.
EPDM straps (also at Home Depot) might work better than rubber innertubes. They are less prone to oxidative and UV degradation. <br> <br>Also, a thought: could odor eliminator (like Febreeze) be used to minimize the effect of odorous residues after sealing the container?
Very Very disappointed with this Instructable - I miss read the title and thought it said &quot;BEER KEG&quot; :-)
Me too, though, I realize in fact this is perfectly suitable to put beer in. Then it's a bear-proof beer-proofed keg.
About This Instructable
20,134views
57favorites
License:
More by Scottbot:Fine particulate collector on the cheap (I Made this at Techshop) Sweet file and screwdriver holder for peg board. Design for a tool crib caddie and catch all.
Add instructable to:
