3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Home Made Hot Tub For the Football Tailgates!
While enjoy a few drinks at a football tailgate during the Fall of 2008 season I had one of those light bulbs light up over my head!  It seems a lot of my ideas show up while consuming beverage.
Some Frat guys at another tailgate had a truck bed full of cold water...  They thought they were the smartest guys in the world.  So I decided I could out do the Frat guys.  Being that I live in Montana and the weather dips well below the 20's in November I had a challenge.  I started acquiring parts from all over the place.  I got a 150 gallon stock tank from a buddy out in Minnesota when I went to his wedding.  It measured  4ft Diameter and 2 Ft deep.  It fit about 3 people comfortably and 6 uncomfortably!!  We used this small hot tub the first year and upgraded this last season for a 9ft Diameter hot tub!  Go big or go home!  Enjoy!
My interview with the news station.
Step 1Find a trailer and Suitable Tank
Living in Montana has its perks.  One being friends that have farms and trailers you can borrow for free, and two, local Ranch supply stores that will let you buy and return 1000 gallon stock tanks!
The tank is a cattle stock tank.  We had maybe 750 gallons in it.  Don't over fill it or else it will overflow everywhere when people get in it.  We had to ratchet strap it down with lots of straps.  And to prevent to much sloshing during transportation we had to strap a few boards onto the front and back.
25 comments
Apr 15, 2012. 12:59 AMFitzcarraldo says:
Why not up the ante next game season by adding bubbles to that tub?  In the same way that bubbles transform Plain Jane white wine into magical champagne, they can turn your tailgate lobster pot into a tingly, roiling cauldron of excitement.  For a stock tank as big around as yours you probably need the biggest wet/dry vac you can get and 2 inch hose to run around the wall of the tub and to reach the vac.  But hell, you're taking the vac back to Walmart after the game anyway, so who cares what it costs?  It would definitely cool your water down at a faster rate than without bubbles, but you can offset this somewhat by placing the vac inside the Burger King crown guy's car with the heat set to full blast.  Now you're blowing 95 degree air into the tub instead of 25 degree air.
Dec 10, 2010. 8:49 PMglen.relaxnation says:
You should check out the Kiwi Tub www.kiwitub.com It's a great commercial version of this idea. Very portable and durable. I hope to get one myself one day
Nov 21, 2010. 11:43 AMTodd Harrison says:
That looks like a ton of fun!
I have been heating my in-ground pool for over 5 years with a BBQ grill. It was slow so I build a "Cajun conversion" that use two 200,000 BTU Cajun propane burners and now it is much faster.
See details www.redneckpoolheater.com
My Cajun conversion is portable and would heat your hot tub in about 2 to 3 hours. Plus you can turn off the flames if you have to maintenance anything and not damage your pipes. It would be a lot safer and easier to work I would think.
You might want to also take a look at all the others that have built pool and hot tub heaters on my "other photos" page.
Nov 25, 2010. 3:00 PMRainh2o says:
i built a small version of this once...took me all day...how long did it take to build these? Thats a lot of sweating joints!
Nov 25, 2010. 4:56 PMTodd Harrison says:
40 hours
Nov 24, 2010. 3:14 AMt.rohner says:
Very cool
although it's not a very detailed instructable, it gives a general idea of how to do it. I was thinking of something like that for a while myself. Mine would be stationary though. Since it gets cold here as well, insulation will be important. I also want to be able to either heat it with wood/charcoal or with my military gasoline stove. (It's like a Colemans camping stove, just a lot bigger. It has some 20kW power.)
So i could fill some 3 gal of leadfree into the stove tank to preheat. Then while sitting in the tub, enjoy firing it with wood and even grill something on the fire. There is a design on instructables where the coil sits in a converted propane tank.
Nov 22, 2010. 10:58 AMCrLz says:
Hot! no pun intended
Nov 21, 2010. 9:13 AMwolfkeeper says:
I was wondering if you could use the cooling loop of an engine; you could drain it down and plumb it straight in and then clean it up with clean water. The engine already has a heat exchanger and pump in it.
Nov 22, 2010. 10:50 AMpdxcascadian says:
i wouldnt use any part of a radiator or heater from a car, theyre usually full of all kinds of residual gross/bad stuff. Lead, antifreeze and salts.
Nov 22, 2010. 7:07 AMoppie says:
A friend made a portable shower to take to a motorcycle meet. (not all bikers are grungy). He made a heat exchanger connected to his truck cooling system. Basically the same as a marine engine heat exchanger, it was a tank that contained copper coils (marine units are all stainless steel). The tank was in the antifreeze engine loop and the coils heated the wash water. Was the only hot water in the area and he made lots of friends...
Nov 21, 2010. 6:56 PMs_phillips says:
Someone who makes copper coils for beverage purposes once told me to keep the copper from kinking, you can cork one end and fill the tubing with sand. I would think you could use salt instead, then what didn't flush out would dissolve and keep sand out of the works.
Nov 21, 2010. 10:06 AMJeremyNYC says:
another option, quite cool... www.dutchtub.com. you'd have to come up with a pretty cool transport solution though.
Nov 21, 2010. 10:15 AMspiceyweasel says:
.......Is that a hot tub, or a still in disguise?
Nov 21, 2010. 8:21 AMfreecell64 says:
Think you could use a in ground hot tub shell built in to a frame?
Nov 21, 2010. 9:08 AMjblessf says:
Most in ground or framed hot tubs are made of acrylic.. When made of acrylic the tub has to be kept level and not moved, because it can be misshaped and then crack and come apart. So you have to use a material that will have some movement properties. This idea is great!!!
Nov 21, 2010. 10:14 AMspiceyweasel says:
I would say you should take the advice of the good people of Bowling Green Kentucky who build Corvettes and "Wrap your ass in fiber glass" as the saying goes. Plenty of structural strength if you reinforce it with carbon fiber and metal strips and you can form it any way you like. I would suggest making it sit lower on the bed frame and make the wheel wells seating areas in the tub. It will greatly reduce the ride height and put less stress on your truck to tow it. You have inspired me to build one. I will make an instructable project out of it, too. Thanks.
Nov 21, 2010. 8:59 AMpalmerpirate says:
Needs a flux capacitor. Turn that baby into a time machine!
Nov 21, 2010. 9:16 AMPatman27 says:
I think you mean, "Needs more Chernobly!"
Nov 21, 2010. 6:44 AMMikeInMaine says:
750 gallons of water equals 6000lbs. The trailer looks like it can take that load, but is it within the towing limit of the truck and the weight limit of the hitch?
Nov 21, 2010. 7:16 AMpsbuckley says:
Be careful! I've always heard that temperatures above 104 can be very dangerous.
Nov 21, 2010. 7:37 AMSpareiChan says:
That would be an easy fix if you have a heater bypass valve that lets you adjust how much water goes thru the heat coils. You just gotta have a temp gauge and be paying a little attention. Basicly the same way the H/C valve works in your shower.
Nov 21, 2010. 6:30 AMredcore4 says:
presumably you can barbecue food on the charcoal as well? or would the dripping fat make a mess of the pipework?
Apr 28, 2010. 12:36 PMThreeWestCreative says:
Brilliant! hahahaha I was just taking a peek around to see if anyone was making homemade hot tubs (because the store bought ones look so simple) and stumbled upon this. :) This is great.
Nov 21, 2010. 2:38 AMmossDboss says:
people in the Phoenix metro area give away hottubs frequently on craigslist.
this is a cool idea. A DIY hot tub would be simple. as demonstrated here.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:russell.damm
