Home Made Kinfe
2,663
47
4
Published
Introduction: Home Made Kinfe
Step 1: Start Making a Knife
First you need
• scrap metal about 5mm thick
• drill
• grinder or drop swore
• chalk
Step 2: Mark the Blade Out
I already cut some teeth out on the blade then marked it out. Dont worry if you make a mistake the chalk rubs out
Step 3: Cut It Out
When cutting it out have a tape near by because of the heat !
Step 4: Final Step !
Cut out the back piece of metal and drill some holes in it. You put the hopes in it for when you make a Handel so the adhesive sticks better for a super strong bound. If you want the blade to be painted paint it now before putting the Handel on
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    4 Comments
    A Mapp gas torch will not provide enough heat required for hardening steel unless done with a forge and a very small knife.
    Yeah bud i did but forgot lol to add it i put it in thinners and light it then used map gas on it
    Well... this acually just did the first step: you have a blank now
    There is quite a long way to go to turn a blank into a knife.
    First of those (in iportance) is heat treating the blade
    Just so u know the holes in the tang are actually supposed to hold pins for your handle. You might also want to adjust the angle oc your bevel it looks a little steep
