3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Home Made PC water cooling
One of the most enjoyable things to do in your spare time is to make gadgets and mods to your computer. This DIY project shows how you can add an efficient water cooling system to your computer using affordable stuff and with lots of fun.
Step 1Tools
Tools
You will need the following:
1.A drill.
2.A normal CPU heat sink.
3.A copper tube. (like the one used in refrigerators)
4.A plastic tube.
5.An aquarium pump.
6.A glass or plastic Jar.
7.Distilled water.
8.Epoxy - Plasticsteel
89 comments
1-40 of 89next »
Apr 22, 2012. 9:39 AMimcmill says:
this step needs definitly more pictures.
does this heat sink have a solid core ? your are just drilling in two holes that connect inside the core to let the water flow ?
Apr 12, 2012. 7:36 PMglacier24 says:
what pump should i use?
air pump or water pump?
Apr 12, 2012. 7:32 PMglacier24 says:
what inside the plastic jar?
and hot do i drill the heatsink??
Apr 10, 2012. 4:49 AMGraffstar says:
i still cannot understand how to drill holes in the heatsink and how to pass water though it...... Can anybody help me ??
Jul 13, 2010. 1:47 PMMinifig666 says:
Is there any way to find the CPU temperature on the phoenix BIOS, or from my OS (Vista)?
Feb 4, 2012. 11:53 PMkedwa30 says:
I like Speccy. But if your hardware isn't designed to find out, the best way is with a candy thermometer. :-)
Aug 6, 2010. 12:47 PMknex hitman gill says:
try speedfan
Mar 19, 2011. 3:57 PMB.F.L.M says:
Just for clarification: The purpose of the 'radiator+fan' is to circulate cool air inside the machine? (would increasing the # of coils cool the air faster?) and the 'water block' is to keep the cpu cool?
Feb 4, 2012. 11:50 PMkedwa30 says:
I think it works best to put the coil and fan outside of the case. The water block transfers heat to the water so that heat is move away from the cpu quickly. Water can absorb and carry more heat because it is denser than air. The coil is where the heat dissipates, aided by the fan blowing air over the coil that is cooler than the water. The flexible clear tube does not transfer heat as well as the copper tube, otherwise you could do without the copper tube and just run a long enough stretch of tube to allow the heat to dissipate. If you wanted to, you could run the tube through a refrigerator. Just keep in mind that the longer the tube, the more friction there will be and thus the stronger the pump you will need. Another improvement might be to solder copper tube to the heat sink rather than drilling a hole in it. Ultimately you want to move the heat out of the case rather than allow it to accumulate.
Mar 29, 2011. 2:59 AMrahimosahra says:
oh gosh!!! I made it but .. how can i make the lighting water? please show the way to do it!!
Feb 4, 2012. 11:37 PMkedwa30 says:
He is using a fluorescent black light which makes the tubing glow because the tubing he used will fluoresce under a black light. There is no need to add dye to the water in this case.
Apr 28, 2011. 3:58 PMdog digger says:
You fill the coolant with a florescent dye to achieve that effect
Aug 20, 2010. 6:57 PMtimator6 says:
Can it run crisis?
Apr 13, 2011. 4:39 PM_Scratch_ says:
Crysis isnt really the best test for computers anymore, I can run it max detail with my AMD Athlon 64 x2 5000+, 4gb ddr2 400mhz ram, and a Nvidia GTS 450. It runs at an average 30fps id say
Apr 20, 2011. 3:26 PMsnowluck2345 says:
I''m just going to call BUL L SHI T. Unless your resolution is 800x600, there is no way you had it maxed out.
Apr 25, 2011. 5:03 PM_Scratch_ says:
Actually, I have a widescreen 1440x900 19", it's an old game, considering the best graphics card then was a geforce 9000 series, I think my 400s series wins out.
Jan 3, 2012. 2:45 PMasmith433 says:
I think the gxt 7800 sires is the best it can run minecraft peace o cake
Jan 3, 2012. 3:54 PMsnowluck2345 says:
no.
Apr 25, 2011. 5:05 PM_Scratch_ says:
I do get some fps spikes when it loads a new area, but after it loads, it runs on very high at 30-45FPS
Apr 25, 2011. 6:35 PMsnowluck2345 says:
I'm pretty sure an 8000s series was the highest. The 9000 series was not more powerful than an 8800GTX or Ultra. Also, people, were running 3 of those in sli and still not maxing out the game. A GTS 450 realy isn't that powerful. Your graphics card is considered similiar in its processing ability to a 8800 Ultra or GTX. Even though it is many years newer, it is a lower model, so it doesn't compare favorable to an older model card that is higher on the heichary chart. I bet that my computer would still outperform yours even if I switched in my old 8800GT. The important specs are 2x2.8ghz Nehalem quadcores, 10gb ram, a ATI/AMD 5870, a 500gb and 2tb hardrive.
May 16, 2011. 11:01 AM_Scratch_ says:
Also, the 5870 can be outperformed by a gtx460 and mine comes pretty close to that. A 500gb/2TB hard drive isn't important for playing games, unless it has a higher read speed.
Apr 27, 2011. 3:31 PM_Scratch_ says:
And i know someone will say "well just becasue its overclocked doesnt make it equal to a 460" benchmarking-wise, its pretty close, off by maybe 5FPS on a game, not too noticeable.
May 29, 2011. 3:13 PMsnowluck2345 says:
460's are not outperforming 5870s in any common games or benchmarks
May 29, 2011. 3:01 PMsnowluck2345 says:
It takes alot of overclocking to make them similiar, and the reason I don't overclock is because of the amount powerconsumption increases in relation to your speed increase, its insane. Also, the hardrive arrangement does matter when you put them in stripping raid/raid 0. I added a second 500gb and they are running in raid 0, so speed is increased.
Jun 5, 2011. 4:55 PM_Scratch_ says:
For loading the games....
Jan 3, 2012. 3:55 PMsnowluck2345 says:
what else would it improve?
Jan 3, 2012. 4:04 PMsnowluck2345 says:
but those are just storage now, I have dual 256gb ssds now. My dad gave them to me bcause his old laptop, a sony z series, was by a sony technition twice, so sony refunded his money and let him keep the broken laptop. So I got its ssds. Needless to say, I was very happy.
Jan 3, 2012. 1:34 AMasmith433 says:
very nice have you thought about making the cooper tubing go around the CPUs heat sink it might improve the cooling performance but very nice set up. I would not recommended using a RAID controller because if the RAID gets wet bye bye computer. (past experience) :)
Dec 9, 2010. 7:17 AMmayur.phadte says:
I think ur motherboard looks very small for your case
Jan 2, 2012. 8:23 AMRagenule says:
Looks like he is using a Micro-ATX form factor Mainboard in a case capable of ATX form factor.
Oct 12, 2011. 11:23 PMbellezaa says:
Thank.
Feb 26, 2011. 10:23 PMSamuraiGoose says:
How do you fix the tubes into the block? I think that is the most important step and you miss it. Nice instructable anyway.
May 29, 2011. 9:01 PMcopin123 says:
that's the exact reason I'm trolling the comments.
Aug 23, 2009. 4:53 PMrimar2000 says:
Seems easy, simple, fast and cheap. I will do it, thanks. Maybe I'll do some reform, such as encapsulating the heat sink and make the water flow within the capsule. I think too it is a good idea to use antifreeze liquid.
Mar 5, 2010. 5:14 PMlegless says:
Using antifreeze is a bit unnecessary if the liquid is never likely to freeze. Chances are it won't happen inside a house. If your house is that cold then you probably aren't going to have much problem keeping your PC cool.
You could maybe replace the water with something like mineral oil as long as the pump could handle it.
I guess one could "gut" a bar fridge and use the mechanicals to cool the PC.
May 29, 2011. 3:14 PMsnowluck2345 says:
not enogh wattage. A fridge isn't meant to take that kind of load. Use an ac unit or a dehumidifier.
Nov 14, 2010. 2:58 PMusername299 says:
antifreeze doesn't just stop the water freezing, it will improve heat transfer and most importantly stop corrosion of any reactive metals in your project, avoiding particles which damage the pump.
Dec 26, 2011. 8:24 AMsnowluck2345 says:
antifreeze decreases the waters heat transfer. fail.
Mar 27, 2010. 8:48 PMSmAsH! says:
Wouldn't condensation be a problem with this?
Nov 3, 2010. 7:54 AMcocodog13 says:
condensation cannot happen if the liquid dosnt drop below ambient room temperature. therefore in a system with an air cooled radiator condensation insn't possible.
1-40 of 89next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:bo3bo3
