3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Home Made Suet Feeder
Most people would agree that to have a great variety of birds in your backyard it behooves you to have a wide variety of feeders and feed to attract avian diversity. Feeders range from tubes filled with seed, cages filled with suet, bottles filled with sugar water, and even just a shallow box placed on a pedestal filled with bread crumbs. There are countless different ways to feed birds in your backyard and I just knew the world wouldn't be able to properly function if I didn't throw out my own idea. :-) This project is easy to build, won't take up very much time, and if you're like a lot of Instructables Users you already have everything you need to complete it!
Step 1What You WIll Need
What You WIll Need
The tools needed for this are very easy to come by and like I already have said, you probably have everything you need.
One Landscape Timber about 18-24 inches long (46-61 centimeters for my Rest-Of-The-Planet friends).
Drill
3 different sizes of spade bits (also known as a paddle bit) I used a 1/2 inch (1.3cm), 5/8 inch (1.6cm), and a 3/4 inch (1.9cm).
Some means of hanging the finished product from a tree or shepherd's hook. Somehow or another I couldn't find any zip ties (I know, I know!) so I used a length of chain I had lying around.
Suet to put into your finished feeder.
10 comments
Sep 23, 2008. 5:53 PMI_am_Canadian says:
I also make my own suet to put in a suet cage. Its really good. It uses mostly lard, cornmeal, flour and rasins. Ask me if you wish the get the recipie
Jun 16, 2008. 6:31 AMfake_faux says:
I'm with leebryuk, suet is the hard white fat found around kidneys and loin cuts of meat. You could get it as off cuts from your local butcher or if you can't face handling the real stuff (and in the UK) you can get lard (reduced, pure suet) in block form from your local supermarket - peeps traditionally use it as shortening for pie crusts. That way you know that the suet you are using is fit for human consumption and therefore fit for avian consumption. To add the wild bird seed: cut the lard (suet) in chunks and place in saucepan on a low heat until it softens. It is important to do this process slowly so that you don't overheat it and change the nature of the fat in any way. The fat doesn't have to become completely liquid, at the point at which it is the consistency of a paste you can take the pan off the stove & stir in the wild bird seed (sunflowerseeds, millet, kibbled maize, pin head oats, red dari, whole wheat). Let the mix cool until it is of a consistency suitable to spoon into whatever feeder or mould / form you choose. I put out suet cake in winter when it is gobbled by squabbling hoards of starlings and a band of blackbirds who are known to take advantage of their size & therefore ranking in the pecking order.
Jun 13, 2008. 7:30 AMalaskanbychoice says:
I use to make something similar. I used peanut butter and bird seed as the energy food. The birds loved it, but so do the squirrels.
Jun 13, 2008. 10:46 PMleebryuk says:
I know what you are saying about peanut butter. Peanut Butter is the crack cocaine of the animal world.
Jun 16, 2008. 6:42 AMfake_faux says:
A thought, you'd have to be very dedicated to clean the residue of old peanut butter from the feeder before replenishing it with more. Unfortunately rancid peanut can harbour a mold/fungus that is harmful to birds.
Jun 13, 2008. 1:28 PMimpulse94 says:
Be aware that some landscape timbers are treated in order to prevent deterioration when in contact with soil. The last batch I bought even had a warning about handling with bare hands. You might want to insure that you get an untreated timber so you are actually feeding the birds rather than killing them. It might not weather as well but will be more friendly to the wildlife!
Jun 12, 2008. 11:40 PMleebryuk says:
Isn't suet the edible fat around kidneys and such? If so, suet is some sort of seed cake bound by fat?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Sunkicked
I was born at a very early age...
