It took about 20 minutes to go crazy about it and wanting one, but the idea of spending between 200 and 250 U$D was not so appealing.
But TRX, like all great ideas (like Chess rules or Unix design...) has the special feature of being an extremely simple concept with a simple design that give a lot of freedom an different possibilities of use.
Being simple makes it easy to replicate.
This is how I made my "almost professional looking" TRX system with 20 euros during three episodes of "the walking dead" ;-)
DISCLAIMER 1
TRX is a commercial product so all credits for the concept are due to Fitness Anywhere. This is a just replica, or knockoff if you prefer, of their product but cannot stand the comparison to the original one.
DISCLAIMER 2
Using your homemade TRX might result in damaging the equipment, you or your house, specially if you make it out of poor materials or don't do it properly. Don't blame me if you break something.
DISCLAMER 3
As for every fitness equipment consult your physical first and see if it fits for your general body conditions.
With all that said... let's dive in.
Remove these ads by
Signing UpStep 1Materials
When choosing the strap make sure it's not to silky and smooth : we need it to provide friction and not being slippery
- A heavy duty carabiner
- 8 iron rings "small" diameter
- 4 iron ring "big" diameter
- Aluminum pipe we (need about 15cm of that)
- PVC pipe (need about 15cm of that)
- some pins or binder clips
Optional
- Epoxy glue
NOTES ON MATERIALS
As for the straps, rings, carabiner:
- get those materials wisely: make sure that each of them can carry twice the weight of your body or more. You'll be hanging from those and if they fail you might fall and get hurt.
- A carabiner used for climbing is a good choice but might cost you 10 bucks-up.
- Whenever you cut the strap remember to burn the ends to prevent it from unraveling
As for the rings:
- the "small" rings must have an internal diameter that is larger than the width of the strap you will use so that you can loop the strap in them (see pictures)
- the "BIG" ring must have an internal diameter that allows the "small" ring to pass through it (more on this later)
As for the pipes that will make the handle bars:
- you want a PVC pipe that allows the strap go pass through it
- you want an aluminum pipe larger than the PVC one so that it can fit inside, turn around but not too loose. (more on this later)
Add Comment
