THIS IS A STEP BY STEP PROJECT, PLEASE READ ALL THE STEPS BEFORE YOU COMMENT!
If you do that I'm sure we'll get along famously.
This is an internal mix snowgun, meaning that the air and water mix inside the plumbing. Because they mix inside the plumbing there is a risk that the air may back up the water, or that the water will back into the air lines. I recommend using check valves on both the air and the water lines (not shown) in order to limit this risk.
The author, instructables.com, and any supplier mentioned in this instructable is not liable for any damage or injury that result from following these instructions. Please know that with all do it yourself projects there are inherent risks which may or may not be foreseen, and that precautions to protect yourself should be taken throughout construction and operation of the snowgun. You will be working with high pressure water and pressurized air, both of which can be dangerous, please wear hearing and eye protection when you are using your snowmaker.
These plans are more detailed, but for a printable copy either print these plans online, or visit http://www.makesnow.net/FreeSnowmakerPlans.php for a selection of home snowmaking plans.
Step 1: Parts List for the home snowgun
Snowgun:
Only use high pressure pipe fittings, using fittings not rated for high pressures may result in injury.
(3) 1/4" T fittings
(2) 1/4" Street Elbows (one side is male thread, one side is female thread)
(3) 1/4" Pipe nipples (male thread on both ends)
(2) 1/4" - 1/2" Bushings (1/4" female thread, 1/2" male thread)
(1) 1/2" gate valve
(2) 1/4" hoses (no longer than 10 feet) (www.princessauto.com)
(1) 22mm pressure washer fitting (we used a female one because we had hoses made up, you should use a male threaded one if you have a 22mm fitting on your pressure washer's hose)
(1) 1/4" air quick connect (female thread if you are using a hose, male thread if you are using your own hose)
(1) stand (needs to be at least 4 feet tall
(1) MSM0304 nozzle (available at www.makesnow.net)
(2) MSM0204 nozzles (available at www.makesnow.net)
(1) roll of teflon tape
Tools:
(2) Pliers
Air Compressor:
Must be oil lubricated, and produce at least 5.5CFM at 40 psi
Pressure Washer:
Between 1.3gpm and 2.5gpm
Step 2: Step 1 - Teflon Tape
TIP: Try and wrap the teflon tape the same way as when you screw in when you're attaching it, this way you wont get loose end that come up and peel it off when you attach your fittings.
Step 3: Step 2 - attach your fittings to the hoses
Put the air quick connect on one hose, and the 22mm pressure washer adapter on the other hose.
Reminder: Teflon tape should be on these threads too!
Step 4: Step 3 - Build the snowgun
Step 5: Step 3 - Build the snowgun (2)
Step 6: Step 3 - Build the snowgun (3)
Then take that T fitting and connect one side of that T fitting's top to the nipple from the last step (see picture for final product)
Step 7: Step 3 - Build the snowgun (4)
Step 8: Step 3 - Build the snowgun (5)
Step 9: Step 3 - Build the snowgun (6)
Step 10: Step 3 - Build the snowgun (7)
(picture coming soon)
Step 11: Step 3 - Build the snowgun (8)
Step 12: Step 3 - Build the snowgun (8)
Step 13: Step 3 - Build the snowgun (9)
Install the MSM0304 nozzle opposite the air hose in the T fitting at the bottom. Again make sure that it's spray is parallel to the upper nozzles.
The picture is a good illustration of how the parts fit together, except the gate valve in this one is 1/4" instead of half inch, but they are pretty uncommon.
Step 14: Step 4 - Get ready
Position your snowmaker on your stand, ladders work well, or you can even just use a tall stake as long as it's got some substance to it, there will be a fair bit of pressure from the water spraying out of the nozzles.
Now Move your pressure washer and air compressor close to the snowmaker so that the hoses will be able to connect to them.
Lay out your hoses and set up your extention cords (if you aren't using gas appliances), remember there is a bit of power being drawn here so you will probably need a dedicated circuit for each the pressure washer and the air compressor.
Step 15: Start making snow in your backyard!
1) Close your gate valve all the way
2) turn on your air compressor
3) turn on the water flow to the pressure washer
4) connect your snowmaker to your air compressor (you should be able to hear the air coming out of the snowgun)
5) turn on the pressure washer
6) open the gate valve slightly (the bottom nozzle should now have a very fine billowy mist coming out of it)
7) make snow!
If you are having trouble making snow at this point your probably have your gate valve open too much or it is not below 28F or -2C.
The picture above isn't this snowgun exactly, I made some modifications to it, but it's essentially the same layout with an extra nozzle and pressure gauge.
If you liked this Instructable visit my external mix snowgun guide as well: http://www.instructables.com/id/External-Mix-Snowgun/
Here's a video of the snowgun running at the 1.5 hour mark, -4C (~25F)
http://youtu.be/xuviX086dPs
Visit Our Store »
Go Pro Today »
We're giving away a free external mix snowmaker at www.facebook.com/makesnowdotnet.
Very simple instructions, to enter simply make a video over 1 minute in length describing what you would do with all the snow you will make.
On November 6, 2012 at noon whichever video has the most likes wins and the person who posts it will be sent a free MSX-250H external mix home snowmaker from MakeSnow.Net!
The air compressor should be rated for continuous duty (generally belt drive and oil lubricated) but they are very difficult if not impossible to find at reasonable prices. That said most air compressors are under rated for period of performance (and over rated on horse power) and so if you keep them cool they will last for a long time. I have had the same air compressor for the last 3 years and it was $200 and I have run it for 8+ hours without any issue, but it was outside, so it was nice and cool.
On the low end (1.3gpm, -2C or 28F, high humidity) it will make about 30 cubic feet of snow each hour.
On the high end (2.5gpm, -7C or 20F or colder, low humidity) it will make about 70 cubic feet of snow each hour.
Snow's density varies but is usually between 2 and 3.5 gallons per cubic foot (uncompacted). So you could cover an area 20' X 20' in about 6 hours with 6" of snow on the low end, or an area about 30' X 30' in 6 hours with 6" of snow on the high end.
- 20' X 20' X 6" = 200 cubic feet
- 1 cubic foot = 1728 cubic inches (12" X 12" X 12")
- (1728 cubic inches per cubic foot) X (200 cubic feet of snow) = 345,600 cubic inches
- 345,600 cubic inches of snow / 12 = 28,800 cubic inches of water (12" of snow = one inch of water)
- 28,800 cubic inches of water = ~125 gallons of water after 6 hours
That's a lot of water. And 30' X 30' X 6" of snow is about 280 gallons of water over 6 hours.
The other difference is that the water is premeasured with an external mix snowmaker, while an internal mix snowmaker requires some work to get it set right, but after you get it set once you'll be able to quickly get it again.
@BrettB0727:Yes: At 1.5gpm that would be 90 gallons an hour, or 540 gallons for a 6 hour run, for a 2.5gpm that would be 900gallons for 6 hours or 150gallons an hour.
@angie12: For a pressure washer just about any will work, typically the running pressure will be between 400psi and 600psi. The higher you mount it the dryer your snow will be, however the further the snow will drift away, in general it needs to be over 4 feet from the ground. As for the 5.5CFM at 40psi that's an air compressor rating. 5.5 cubic feet of air per minute at 40psi.
Like how many PSI
Thanks
looks cool
Any preference as far as internal mix or external mix goes?
I can remember skiing through the fog night skiing.
Reminded me of being in a white out in the Aleutians.
You suppose an inch and a half fire hose could be used at home to snow the front yard before the neighbors get it ?
