Home Snowmaker / Snowgun - internal mix by MakeSnow
Featured
Step 13: Step 3 - Build the snowgun (9)
Now it's time to install the nozzles.  Install the two MSM0204 nozzles in the street elbow and T closest to the top.  Remember the Teflon tape on the nozzles as well.  Make sure that the nozzles are parallel to the ground, otherwise you'll be shooting the water at the ground before it gets to freeze.
Install the MSM0304 nozzle opposite the air hose in the T fitting at the bottom.  Again make sure that it's spray is parallel to the upper nozzles.
The picture is a good illustration of how the parts fit together, except the gate valve in this one is 1/4" instead of half inch, but they are pretty uncommon.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
