Step 4Attach the Screen Material
If need be, iron your material.
Lay the material out flat and put your frame on top.
I suggest using some help for this part. I did it by myself and it was tedious stretching it out tight/taut. If you get it pulled as taut as you can and there's still some wrinkled looking areas, do not fear. At least for me, I had some wrinkled looking areas, but after I painted, they disappeared.
With the frame centered, fold one side of the material over and staple away.
-- As a side note, I used longer staples to staple the wood, shorter ones to staple fabric and longer ones for a later step of adding the plastic trim.
Pull the opposite side as tight as possible and staple it down the same way. I started at the center of the other side and, as I pulled tightly, worked my way, stapling, towards the outer edges.
Finish off the other two sides of the rectangle.
Add Comment
