Step 6Add the Border
This is probably the most complicated step to explain. You may come up with a better idea. I read in some AV forum that using black paint - even matte finish ends up being too reflective.
The schematic pic is my best depiction of how I laid out the plastic 1" trim if the black material were not there. In the picture, black represents the wood frame, white represents the plastic trim pieces.
Cut the black material into strips that will cover the border area. I cut mine length-wise into 3rds and cut one of those pieces in half, which gave me four pieces the right size for what I needed. Do your own measuring. It's better to have too much that will just end up folded on the back.
I folded my black material in half to make it thicker.
This is where it kinda gets tricky in the explanation...With this, again, I'm using the measurements for my screen. If you want a bigger border, you may do it a little different. It's important to look at the progression of the pictures along with the following steps. Also, hopefully, the image notes (yellow squares) will help this make more sense.
Start on one of the sides (the 45"/49" sides)
With the screen (painted area) facing up, lay your black material about an inch inside the screen with the excess laying inwards toward the middle of the screen.
Staple along the edge of the black material which will be about 2" inward.
Next, measure and mark all along the side at exactly 2" in with chalk. Also, measure 2" in from the top and bottom.
Take a piece of 1" plastic trim and cut it to 45" long.
Place the inside edge of the trim to the outside of the chalk line (so that 1. from the edge of the frame to the other side of the trim equals 2" and 2. from the inside of the trim on one side to the inside of the trim on the other side - once it's all done - equals 102.5" for the length [or 45" for the hight] of the screen). You'll also want the trim to be 2" from the top and 2" from the bottom.
Now staple this trim piece down on top of the black material (basically over top of where you stapled the black material already. I stapled one direction for the material and then perpendicular for the trim so that I didn't hit any staples when I was stapling down the trim. Through this whole process, always make sure to tap the staples down with a hammer to make sure they are flush.
You can go ahead and do this whole process to the other side as well.
Next, flip the screen over so that the back is facing up, then wrap the black material around to the back. In doing so, you are wrapping it over the 1" trim, covering it up. Make sure the material is taut.
Start this same process over for the length (Ultimately, the top and bottom of the screen). The only difference is that this time, you cut the trim to go all the way to each edge (each side). It's OK if you have to use more than one piece of trim for then length since it's all gonna get covered up by the black material anyway. The last picture in this step illustrates what this will look like once the material is stapled and you put the trim down, but have yet to wrap it around to the back.
Once you complete this for the two sides and the top & bottom, you're just about done.
comment
Add Comment
Add Comment
