Step 7Fasten to the Wall
I put the finished screen up to the wall centered exactly, then measured from the edge of each wall to the middle of the 1"x3" on each side (this should be the same on each side if you want it centered). then I screwed in these hardware pieces - a screw with an O-ring - to the back of the frame making sure that the screw portion was short enough that it wouldn't protrude out the front of the black border area (that would be ugly).
On the ceiling, I used screws with open-ended hooks. I made the holes and used drywall anchors to give it enough strength to hold up the screen (trust me, if you're not screwing into studs, you need drywall anchors). Remember, if you're hanging it close to the ceiling, you need enough wiggle room to get it hooked and unhooked.
Like I say, you may find a solution you like better for hanging yours. This way works for me and I can easily mount or dismount it from the wall when not in use.
Add Comment
