Home Theater Under $500 (tips and tricks)
I managed to construct a relatively large projection theater, by cutting corners, doing a little deal hunting, and making some things on my own. For under $500. Everything I have done can be scaled down for you on home, for either a temporary or permanent installation.
Step 1Acquiring the projector
If you have a projector, you can skip this step.
Otherwise, there are a few ways to go about getting an LCD projector for about $300. Personally I got mine from a friend who was selling one, similar to the price of comparable models on ebay.
Another way is to check local computer junk stores, thrift stores, and flea markets.
Be weary of cheap projectors without bulbs, if you are handy (or can wait around for me to write up my instructable on it) you can improvise your own bulb for ~20.
I'm a little too lazy to cite sources but if you are adventurous you can build your own from scratch.
Also do some research to make sure your projector has enough power to fill your selected wall or screen with the ambient light of the room... check manufacturers specs for this.
so $100-$300 for the projector
32 comments
Nov 4, 2011. 4:37 PMDimitrios says:
Hello, you mentioned that you can improvise your own bulb.
I have a Vidikron Crystal III LCD projector, but the bulb needs replacing and I don't want to pay $250 for a bulb. The unit is only one lamp life old. But I have saved it for many years.
Can you or anyone if I can do a nifty trick or retrofit with a cheap light or by bypassing the light ballast/transformer and just my own type of light in there?
It has a projector light with a reflector. I'm thinking maybe use a car headlight bulb or something. Any help would be appreciated
Aug 7, 2009. 8:23 PMalbylovesscience says:
do you live in a loft or somthing i know of no house that has any livingroom type basement room
Mar 11, 2011. 10:32 AMJAYDAWG40 says:
what youve never seen a house with a finished basment are you kiding me. lol i live in an underground house the whole thing is a basment
Feb 16, 2011. 3:30 PMabadfart says:
the basement in my parents house is a nice big room perfect for a home theater
Sep 24, 2009. 9:36 PMRossiroller says:
"How do you change the volume on the tv while the stereo is on at the same time? Why do you want to listen to the stereo and the tv at the same time? Because I like to party." Great Instructable
Feb 11, 2011. 8:52 AMslothman says:
great movie
Dec 23, 2010. 4:54 AMkbhasi says:
lol
May 15, 2010. 11:01 PMJon123 says:
lumenlab.com/forums.  You'll find everything you need to know about DIY projectors there.
Jan 1, 2010. 3:26 PMsheepsimulator says:
Good instructable.  I did something similar to this in college.
Jan 21, 2009. 1:58 PMbwpatton1 says:
I'm a very cheap person, so this is the right instructable for me.!~!~!~! I bought my surround sound from walmart for $40, it works great for me (but I dont have to have GREAT quality just somewhere between Little and medium) I plan to build a home theater system on about a budget of $200. Ja, Im cheap!
Jan 12, 2009. 4:07 PMHycro says:
Yea, a lot of audio systems today can be garbage, the system on my computer isn't even designed for a computer, is only rated for a total of 250W (one 100W amp driving two 5 1/2" two way speakers, and a 150W amp driving two 10" subs) with one of the amps being made in '89, and the thing out-performs my mom's 1000W surround system, which was more than 3 times the cost of my set up, and my 250W 2.2 system out-performs in both sheer volume (even high-volume bass) and in quality. The amp I have for my subs is designed to be a stereo amp that can drive two 16 ohm speakers at 30W max continuous, two 8 ohm speakers at 40W max continuous, or two 4 ohm speakers at 50W max continuous.
Jan 4, 2009. 8:46 PMYerboogieman says:
Yeah, craigslist doesnt have free projectors, and new projectors, arent cheap. :-)
Aug 23, 2008. 11:36 PMThatInstructablesGuy says:
Great Instructable!
So you say you got a projector for 300$ Can you tell me the name of it? Or even better, can you tell me the resolution of it, and the display technology?
How did you get the image so big with a 300$ projector? Am I thinking on spending too much, or is that just a sweet deal?
I'll be doing something like this soon, so the sooner you can answer me the better :)
Thanks in advance!
Jul 23, 2008. 5:15 PMKarnivore says:
Whoa, this is thorough... It's a little bit out of my league money and experience-wise, but I'm bookmarking this one for the future. Great going! -Karnivore
Dec 7, 2007. 8:47 AMkidNeutrino says:
What color did you end up buying? Do you have the Sherman Williams number to share with us? thanks kN
Jul 10, 2008. 10:34 AMDerin says:
its white
Jan 26, 2008. 2:06 PMNickDeWolfe says:
I have a real Goo screen. And while you may be able to simulate the basecoat portion of the coating...you won't get the same performance as the Topcoat. I watched my projector on the wall first...then on the basecoat for a day and then I did the topcoat. It was actually a pretty impressive gain in image quality. I am moving my set-up into my basement and I will use Goo again. Just my 2 cents worth.
Dec 1, 2007. 2:04 PMslim_jim says:
Might I suggest putting something on the screen worth seeing? The image doesn't really inspire.
Oct 18, 2007. 11:51 AMVIPER2475 says:
You can use my Automotive Head Light Projector Mod to revive a old projector.
http://www.instructables.com/id/Head-Light-Projector-Mod-V1.2/
Jul 11, 2007. 12:01 PMbobparker says:
Nice ideas. A few suggestions that may be helpful depending on budget/timeframe. Tigerdirect.com often has projector screens a lot cheaper then most places (not $50, but might be worth it for some budgets). These sales tend to be very short term (over a weekend or just a day) - sign up for the goofy email list or see if someone can keep an eye out for you at the outlets stores (2 in Chicago area). The day after Thanksgiving (in the US) usually has some screaming deals, often on fair speakers for cheap prices. I usually pick up a pair every year and keep putting them around the house, or office or garage, or patio or friends or computer or.... Spring / early summer is the best time for Church Rummage sales, community Garage Sales, Flea Markets to keep an eye out for all sorts of speakers and old electronics equipment. If you find an extra receiver/amp - you can use it with a subwoofer to more easily control the bass depending on whether you are sharing your space with others (amazing how loud everything gets when she 'has to' go to bed). Keep up the good ideas.
Jul 4, 2007. 8:59 PMPadawan Maker says:
Jun 29, 2007. 11:43 AMPunkguyta says:
[[Video(I think the most appropriate name for this instructable might have been "Poor man's DIY Home theater". Bignerd was right, this is a budget system, the fact that you tried to bring some kind of knowledge of hi end system setups into this and try to apply it to 1970's speakers kind of makes me worry. You were worried about putting the front speakers out of phaze? Well then why did you only turn the top one (smacks head)., {width:425, height:350})]]I think the most appropriate name for this instructable might have been "Poor man's DIY Home theater". Bignerd was right, this is a budget system, the fact that you tried to bring some kind of knowledge of hi end system setups into this and try to apply it to 1970's speakers kind of makes me worry. You were worried about putting the front speakers out of phaze? Well then why did you only turn the top one (smacks head). If you want to see a quick setup of what I have for a surround system, then take a look here:
Jun 3, 2007. 11:18 PMawesomeallan says:
(removed by author or community request)
Jun 4, 2007. 9:47 AMBignerd100 says:
Very resourceful scrounging of materials. I'm afraid that your advice on things involving sound quality were pretty far off the mark though. Granted you were doing this on a total budget less than that of ONE good speaker, but inaccurate information is worse than the omission. There is a loose hierarchy to the order in which technical aspects of sound quality should be given notice.
Jun 4, 2007. 1:18 PMroyalestel says:
Hey share the wealth. Post the list so we can all have it right here. Perhaps then Gamer6460 can add it to the instructable so as not to lead anyone astray.
Jun 5, 2007. 10:38 AMBignerd100 says:
Relative efficiencies of the replacement drivers, phase shifting with analog EQ, faux surround sound by playing stereo in the rear, define "loud" and what watts has to do with it, wide frequency response equating to quality, wire myths, etc. It's hard to nit-pick a supper budget set-up but the electronics industry is built on misinformation. Most of what you read on the outside of a box or in a stereo mag is just bunk. Your best bet if you were to try this for the stated budget would be to scrounge just as he has done. Buy matching pairs of functional speakers from the thrift store (a crappy pair that matches will sound better than a great pair that do not). Buy an old pro-logic receiver that was of high quality in it's day (Sony ES, Denon, Amfi, Nakamichi, NAD, or the like). These sell for next to nothing because the surround format they provide is antiquated. It does do a better job than a stereo receiver with A&B outputs run as faux surround though. Use lamp cord or whatever you can find at least 18AWG. No EQ. Sit back and enjoy budget bliss.
Jun 5, 2007. 11:47 AMroyalestel says:
Thanks, friend. Bignerd100 rides off into the sunset . . .
Jun 4, 2007. 3:08 PMAlexTheGreat says:
I got a broken from my school for free, and fixed it. it only had a broken cooling fan.
Jun 3, 2007. 9:19 PMBurningApple says:
This would be kickass to make. Love it. "+".
Jun 3, 2007. 9:09 PMjeffreyf says:
I used screen goo to make a screen at home about a year ago. Rather than paint it directly on the wall, I built a very large wooden frame, stretched some cotton canvass over it, gesso-ed, and then used screen goo. Truth be told, it wasn't noticably different from the white wall I had been projecting onto before, which was covered in Benjamin Moore Super White.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Gamer6460
