Introduction: Home Automation With Raspberry Pi Using ROR
Picture of Home Automation With Raspberry Pi Using ROR
The aim of this project to control home device like bulb ,fan ,TV etc using your existing smart phone.
What's required
1 Raspberry pi 2
8 GB ,class 10 micro sdcard
1 USB wi-fi adapter
1 USB power adapter 5V
1 USB power cable
8 channel 12v Relay module
12 v power supply for relay module
These commonly available free software would be required:
Download “Hotspot Manager” from play store
Basic Connections
Plug in the provided USB wi-fi adapter to one of the Raspberry Pi's USB Ports.
Connect the micro USB cable to the raspberry Pi and provided USB power adapter.
Your Raspberry Pi should power up and start booting as soon as power is applied.
Configure Hotspot maneger
Open hotspot manager and create new hotspot with user “pi” without qoutes and password
“raspberry”.
Start the hotspot
Go to clients tab where you will see connected wi-fi user
Note down the ip of connected pi
Wait for 2 minut to configure server to start
Now go to the browser and type your ip:3000
After that you will see the default 8 device
You can edit name as you want with edit button
Now your device is ready to operate (Bingo!!!)
seamster (author)2015-06-03
Nicely done. Thanks for sharing this!
AmitK14 (author)seamster2015-06-04
Thanks Seamster
Its my first project on raspberry pi
AmrA22 (author)2016-01-07
Do I need to make any programming for Raspberry pi?
AmitK14 (author)AmrA222016-01-08
yes this project need some basic knowledge ruby programming then you can use
Please let me know if need more help on this project
jessicalim25 (author)2015-08-23
Do you know how to build our on software using this raspberry pi? For my final year project I want to build a home automation system just like you, if you don't mind would you like to share with me? If I have a problems with it, will you help me
AmitK14 (author)jessicalim252015-08-24
If you want this project go through on below link
http://www.shopclues.com/home-automation-using-ras...
i can help on each section of this project
Let me know if you have any problem in any area
About This Instructable
2,696views
44favorites
License:
More by AmitK14:Smart HomeLinkIt One SMS Based Home AutomationLinkIt One Music Player Via Bluetooth
Add instructable to:
