3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Home made DIY Grey water system water recycling.
Step 11Update fine tuning
Update fine tuning
Hi
I have been using this grey water system for about 6 months now.
In this time I have had 1 or 2 small problems that I have had to sort out.
The first one is, I have had 2 switches fail. I have put this down to the switches not being able to cope with the current drawn by the relays so I have made a simple transistor circuit to reduce the current going through the switches this has also enabled me to use just 1 relay.
see attached circuit diagram.
the second problem has been when the weather gets hot there is a bit of a smell from the grey water stored in the tank in the loft.
I have calculated that the tank in the loft is holding to much water for to long.
It is holding enough water for 5 days. so I am replacing the tank in the loft with a smaller tank which will hold enough water for 1-2 days. then more of the water will be stored in the tubes outside. and the water will be recycled sooner. and won't be sitting around getting smelly.
2 comments
Sep 8, 2009. 6:14 PMdkstruska says:
Couldn't you just skip the attic tank and have the pump piped directly to the toilet? A small pressure tank and pressure switch would be necessary, but there would be no exposed water inside to stink up the place except in the toilet.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:simon72post
