3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Home made Hydro Power System
At Fuelternatives we are trying to help consumers find solutions to allow them to use alternative energy sources. We have been working on some experiments to that end and this is one of them...
In an effort to extend the offerings here, I thought it would be neat to include the basics for a hydro electric set up using PVC/standard plumbing fixtures and easily made parts.
I made some interesting discoveries along the way and am sharing them...
I started by trying to make an inline energy take off with a pre-made propeller blade from a paint stirrer. While an interesting thought, I couldn't get any reasonable motion out of it - which reminded me of my physics that the max torque will come with the force applied furthest out radially.
Paddle Wheel Hydro Power.
First things first - physics reminds us that we can make energy only convert it and every conversion includes loss. Next that water pressure from gravity is directly related only to the height of the smooth column flow.
Design plan - knowing that we want a smooth flow but our goal is to move the water out to the radial extremes of our propeller, I created a basic test harness to try and understand how to optimize the hydro power system. The pipes here are really representative of what you would have to install in your environment. I fill up the 5 foot tall 2 inch pipe to get a know water volume for efficiency testing.
The picture below gives a good taste for the workings...
Step 1Water flow
Water flow
The point here is to show the behavior of the water and the wheel. We are aiming the water jets to hit just under tangent to the edge of the wheel so we get maximum effect. Note the whit painted wheel section shows the spin.
A note on performance... You can see the short pipe on the far side is impacting the wheel well, but on the longer jet on the near side needs to be tweaked to maximize impact.
18 comments
Dec 4, 2011. 3:04 PMLefrançois says:
Use you washing machines drain pumps, the vanes are optimized.
Sep 6, 2011. 2:34 AMtaluntain says:
you should put a grey water catcher under it
Jul 24, 2011. 7:29 PMstyryl says:
I've seen some excellent home-made impact wheels like this using old spoons as the vanes on the water wheel. The rounded nature of them increases the power transfer/torque substantially. Good to see.
Jul 5, 2011. 2:17 PMtinker234 says:
so is it a hydren fuel cell
Dec 6, 2010. 12:34 PMjosh.p.drake says:
How much power did you get out of it?
Aug 6, 2010. 4:19 AMshills says:
will it work for science flair.......
Jul 18, 2008. 1:53 PMsdallesasse says:
Also, would like to see some preliminary plans.
May 25, 2009. 1:37 AMdirtwrkx58 says:
check out www.amphydro.com
May 25, 2009. 1:34 AMdirtwrkx58 says:
Check out www.amphydro.com seems like a reasonable price on hyro.
Wouldn't a pair of 45's work better? I.E. less disruption of flow / less friction loss and higher working pressure.
Jul 18, 2008. 4:35 PMLftndbt says:
That's fantastic.... Looking for any new designers? Way ahead of you on this one. I like your idea of using the gravity flow though... You need to look into some jetison nozzle, approx 3 set at different angles. Your design may not work to full potential with that flow.... If not enough back pressure in the pipe to run jets, flip the wheel vertical and turn it into a classic style water wheel with buckets. The buckets collect the water as it spins and much more torque is produced. Check my finalised comment, in regards to taking a stardard highflow pond pump and running it inline in the main from the street. Pong pumps are designed for the purpose, prebuilt, cheap, effective and it works. Great work!!!
Jul 18, 2008. 9:05 PMtheRIAA says:
yes, a water wheel would be much more efficient, but would have to be huge. at least twice the height of the source, and just 2x the height would be inefficient, because near the bottom of the water drpo, the water would push down instead of around the water wheel (a long, tall, convener type water wheel should theoretically be 100% efficient) if the wheel was ginormous, the drop would be almost strait down and very efficient. a system like this, but sealed (maybe those hard drive air motors they have here) could be more efficient than a normal water wheel.
Jul 18, 2008. 10:02 PMLftndbt says:
[http://www.instructables.com/community/Home-Water-turbine-power-plant...-Mini-HELP/ My mini home turbine power plant.]
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:leifjohnston
