Step 3The plumbing
We have a 2 inch feed line, but we want it to come out in a tight and aimed water jet. Given that we reduce from 2 to 1.5 inch "T" then plug the "T" ends with 1 inch reducers that then tie into 1 inch "90" bends and in this case, we have the other end of the 90 be a 1/2" compression fitting so that we can use 1/2" copper pipes as our jets.
Copper pipe is easily bent to shape and the tips flattened to maximize the impact on the paddle wheels.
At this point only the compression joint is tight both to the copper and the PVC so that all other angles and parts are just pressure fit, allowing me to change them as needed. To get the far side jet angled so close, it uses a 90 degree compression fitting that you can make out with effort in the back of the picture.
comment
Add Comment
Add Comment
