Home Made LED Bulb
6,779
57
Published
Introduction: Home Made LED Bulb
Today we fabricate a LED bulb, recycling material we have at home.
We need the following materials:
  • Bulb used
  • Switch Transformer 220V - DC 12V 1A.
  • White LED strip
  • Plastic pipe
Step 1: Dismantle the Bulb
Dismantle the bulb to utilize the cap.
I remind you that the inside bulb must be dispose in a recycling point.
Step 2: Dismantle the Transformer
Dismantle the transformer, and solder wires to 220V metal parts.
Step 3: Assembly
Insert the bulb cap and the transformer inside the plastic pipe.
Step 4: Sticking Strips
We glued the LED strips on the plastic tube
Soldering strips together with special attention to the polarity soldering the output of the transformer
Step 5: The Result
This is the result:
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    3 Comments
    The cilinder plastic should be drilled to keep the leds cool and you can use one long strip to avoid soldering
    Inside you can mount those cheap remote controls for on/off or color change depending on the LED strip
    Strips have limited air access.
    1. Does it have enough cooling?
    2. How bright it is in comparison to 40W, 100W incandescent?
    3. What wattage leds are on the strip?
    that's cool! I bet it is very efficient!
