A solar-powered LED lighted cookie jar reminiscent of the Sun Jar designed by Tobias Wong.
"Jam jars store jam, the Sun jar collects and stores sunshine so that you can use it at night."
Pass around the sunshine, Sunshine. (_)v
Components:
1. Ikea glass jar (AUD$3.00)
2. Solar garden light (AUD$10.00)
3. rechargeable battery (AA size)
4. Blu-tack
5. Tracing paper
Tools:
1. screwdriver
2. Utility Knife
3. Glass Frosting spray
Step 1: Bringing them together
Step A:
Rip open the innards of the solar garden light. I know that may sound ambiguous but you'd be able to use a utility knife and surgically dissect the relevent components out (see image). Solar garden lights are easily available at your local major hardware store. If you're in Australia, try Dick Smith Powerhouse.
Step B:
Flip open the ikea jar and place the "solar garden light innards" as shown in the picture. Use blu-tack to keep it all together. Feel free to play around with the placements so the components would fit snuggly into the jar.
Step C:
Cut a strip of tracing paper and place it in the glass jar.
OR
Use a Glass Frosting spray .
Step D:
Close the lid of the glass jar with tender care and you're done.
1-40 of 348Next »
Obstinatus says: Dec 1, 2006. 12:20 PM
Love the instructable. I made two SunJars last night. Instead of using the squat glass jars I chose to use Plastic Jars. I'm planning on using these for camping and float trips so plastic works better. It floats! One problem the frost in a jar sucks. How can I etch a plastic jar?
curious.jp says: Dec 2, 2006. 1:46 AM
Sandpaper? High grit followed by wet - tried this myself, and it just bounced off the glass for some reason ( possibly bad quality paper ). I hear a fine mist of acetone will etch acrylic, but results might be a little uneven. One case modding forum suggests a light spray of satin sealant, provided you get a deliberate undercoating - too much and it just goes, well, satin.
cre8tor (author) says: Dec 3, 2006. 6:08 AM
Post some pictures, would really love to see how it turned out.
Obstinatus says: Dec 3, 2006. 6:46 PM
I made both of these Sun Jars from clear plastic swing top jars I found at Hobby Lobby for 2.99. I have finished etching one jar. It was actually very easy with just some fine grain sandpaper. I tried to etch as little as possible to allow the most amount of light threw. I also did not etch the bottom of the jar as this makes it a handy flash light when walking out into the woods to take a slash in the middle of the night.
erevos says: Dec 10, 2006. 1:01 PM
stencil-cut the shape(s) you want on a sheet of adhesive vinyl, then stick on jar, use thin sandpaper on the gaps and after ure done unstick. :)
guerroloco says: Dec 13, 2006. 1:32 PM
obst -- you etched the inside or the outside of the jar w/ the sandpaper?
Obstinatus says: Dec 14, 2006. 9:47 PM
Just the inside of the Jar.
Derek9Three says: Dec 16, 2006. 12:56 PM
I made a couple of these and planed on making more as christmas gifts but... Is anybody else having problems with the batteries barely lasting? I know it gets dark early but I'm home by 6 usually and mine are already out by then. I bought new batteries and have had the same results on 2 of them. And the window I put them in usually burns the leaves of plants it gets so much sun.
cre8tor (author) says: Dec 17, 2006. 5:36 AM
Yep having the same problem too. Might need to leave them out in the sun. Worked fine for me after that. 5-6 hours of power.
Derek9Three says: Dec 19, 2006. 5:17 PM
I think actually it was the lights I had. I just bought new ones that work much better (all night), were cheaper ($24 for 4) and they fit better in the jar. Because the new ones I got are round I cut out the outer shell of the light so it is a hollow tube shape and placed it in the jar first. The guts of the light sit on top of it and the lid of the jar holds it all together so there is no need for the blue tack.
cre8tor (author) says: Dec 20, 2006. 6:08 AM
Sweeeeet! Man, yellow/amber lights makes it looks so much better. Well done.
Mit says: Dec 24, 2006. 11:59 PM
you should be able to get a nice 'frost' effect on your plastic by scrubbing it with a scotch-bright pad (non-metalic pot scrubber) That how I frost plexiglass.
mhespenh says: Mar 6, 2007. 9:27 PM
Really great idea, thank you! Here is mine, I added some frost stars around the outside, and a sun on the lid, it worked out pretty well, thanks!
richelton says: Apr 13, 2007. 3:54 AM
These are very pretty. I like the idea of mixing new (LEDs) and old styles.
cre8tor (author) says: Apr 13, 2007. 10:30 PM
You know, I want to see someone make a wall outta them! How cool would that be!
Parmzilla says: Jun 5, 2007. 2:32 PM
Hey Derek, What brand were the lights that you bought, and how long did they last? One link said to use Malibu Brand Solar Garden Lights, but they don't seem to fit as nicely as yours do.
Derek9Three says: Jun 5, 2007. 5:29 PM
Hampton Bay
I bought this 4 pack at home depot, they fit nice and snug when you cut off all the excess plastic.
alezavala says: Jun 15, 2007. 11:09 AM
Hi, can you tell me the size of the glass jar or the lights? there is no Ikea where I live and I don't know where to find the jar... any help? thanks
Derek9Three says: Jun 16, 2007. 10:59 AM
The mouth of the jar is just under 3.5 in dia. and it is about that high too without the lid. I looked all over for a jar near me but ended up having to get it at Ikea almost an hour away.
alezavala says: Jun 16, 2007. 1:03 PM
thank you, i will keep looking, the closest ikea in my case is three hours away... but thanks again
Imperialist says: Sep 19, 2007. 11:40 AM
Kudos to the author of this project, it cost me about $32 bucks total for materials to make 4 sun jars. The lights I bought were Malibu brand garden lights but couldn't gut them easily since the wires were soldered and stuck to the plastic base of the lights. I knew it would be hard to find any cheaper lights (these were $15 for 4) so decided to saw the plastic bits off w/ a saw I had from taking metalsmithing class in college. They turned out pretty awesome but the amber colored leds are probably what I'd use if I were to make some more. Thanks again cre8tor Y-.-Y
ilovetea says: Nov 5, 2007. 4:45 PM
I read your responses but could not find the type of lights you used. Could you give me the link or the name of the lights? Much appreciation
dgs says: Nov 10, 2007. 12:41 PM
Just finished making one myself. It's a really nice thing to have or to give somebody as a gift :)
tobiko says: Dec 23, 2007. 3:28 PM
My set of 6, really like how they turned out, gonna look great in my dorm-room.
Yerboogieman says: Jan 12, 2008. 3:02 PM
i just got a candle at safeway that was already frosted
jaysen says: Jan 26, 2008. 3:33 AM
Thanks! Great instructable and a great gift too...my girlfriend loved them! The only difference I did was to put in clear glass stones instead of the tracing paper or glass frosting. It took a little work to move the stones to hide the jar's internal wires from obvious sight but the end result was great! I just got the stone in the glass/vase area at Wal-Mart for a couple bucks. Here's a couple pics of the final product:
wwilke says: Jan 30, 2008. 2:52 PM
where did you get your LEDs?
killbulletbill says: Jan 30, 2008. 6:37 PM
Whoa. Nice.
jaysen says: Jan 30, 2008. 11:34 PM
I got the solar lights from Home Depot...I'm pretty sure they're Hampton Bay. I just got the plastic ones in the four pack for $20. I also forgot to mention that I replaced the cheap rechargeable batteries that came in the set with some Energizer 2500 NiMH that I picked up at Wal-Mart...it made the lights glow brighter and longer. They added about a couple bucks to the total cost of each jar but I still estimated mine at about $12 each.
wwilke says: Jan 31, 2008. 11:32 AM
sweet, thanks i went to home depot but i could not find them there, they might be an old model or something they were hard to find, i bought Malibu's amber ones, not sure how bright they are yet i have to pick up my jar... but you said the 2500 increased the brightness and duration? then i guess I'll have to pick up one of those...anyways thanks for the info. On another note does anyone one here know the amount of power that is generated by the the solar panels... on average i guess each brand could be different, i was considering adding more leds to the same panel, but was curious how much that would effect the draw (double i assume?) and if it did affect the draw would i need to add another battery, and as such would adding another battery effect the board that controls the lights...i believe AA's are 1.2 volts... does including two AA increase the voltage, or does double the batteries have no effect on the potential difference? obviously i am worried that including two will short the board. thanks.
cloner says: Feb 3, 2008. 11:52 PM
cool! what makes the yellow color of the light? :D tnx
jaysen says: Feb 4, 2008. 3:33 AM
The pack of lights I got were already amber/yellow, so no modifications were needed for the LEDs...just check the box before you buy. It just so happened that the cheapest box I could find was also the color I wanted. Its all just depends if you want to make sun jars (amber) or moon jars (bluish).
n00d135 says: Feb 17, 2008. 5:36 AM
if you are in the uk B&Q do a pack of 2 solar lanterns for £4 but many petrol stations have them for dirt cheap as "promotions". if you fill the jar with glass beads there is no need to fix the components to the jar as they just sit buried in the beads. also colored beads would give a nice effect. i've found the solar panels to be crap behind glass (window or jar). open the lid and stick it outside if you want to use it that night. i guess the windows block some vital part of the spectrum either uv or ir which the solar panels may make use of. nice instructable, creative not complex! (the best kind)
tintin says: Mar 5, 2008. 7:08 PM
HI JAYSEN
YOUR PROJECT'S REALLY COOL.. CONGRATULATIONS.
galyon94 says: Apr 23, 2008. 1:59 PM
Good Instructable!
I've done tree from the Slom (IKEA : 1.5€ ~2$) and solar garden light (10 for 20€ ~27$).
The middle hasn't filter (from the other similar instructable)
Thanks for this birthday's idea =D
mcgyver says: May 11, 2008. 7:04 AM
Each LED draws about 20mA on the average. Different LEDs require different voltages. Ultrabright white leds usually needs about 3.4v if I remember it correctly. Reds and Blue LEDs need lower voltages. You need to put a resistor in series with the LED you wanted to add. The value depends on the LED and the voltage it needs to drop to ensure that the LED received the correct voltage and current.
hogzilla says: May 12, 2008. 7:10 PM
WOW.. The evolution of INSTRUCTABLES!!! SUPER-NEATO!! Great idea! Thank-you!
Phoghat says: May 30, 2008. 4:53 AM
I liked the original idea Jaysen, but adding the clear glass stones is kewl. I have a crapload of multicolored glass bits that are usually used on the bottom of an aquarium and I'm going to try those. It should be easier to hide the wires as the bits are smaller than the stones.
lovemetal1 says: Jun 10, 2008. 7:28 PM
what kind of light did you use its super bright?
horselover1324 says: Jun 22, 2008. 5:18 PM
how big those jar you have.
1-40 of 348Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
