Introduction: Zotz.......ON a STICK!
Picture of Zotz.......ON a STICK!
I love those zotz. If you have never had one, it is a hard candy with a powder inside that reacts to saliva and produces carbon dioxide bubbles, thus forming lots of sour foam. I found out that the three ingredients are an acid, a base and a sweetner. The acid is citric acid and the base is baking soda. (And the sweetner is sugar)
So I found out how to make the powder, but then I thought, why don't I make imitation zotz.....ON A STICK! My mother makes hard candy suckers so I thought, why don't I just put some of that powder in the suckers?
PlEASE VOTE!
Please submit your pictures of the zotz on a stick because I need a good first picture.  I don't have a high quality camera so PLEASE SUBMIT YOUR PICTURES!
Step 1: Step One.... Ingredients
Picture of Step One.... Ingredients
You can use this recipie or use your own hard candy recipe.  I did two batches (one to be the first layer of the sucker and another to be the top) so you might have to do two of these measurements.
-1 cup sugar
-1/3 cup white corn syrup (I used light corn syrup)
-1/2 cup water
-1 tsp. flavoring (you could use 1/2 tsp. but it wouldn't taste good)
-food coloring
-1/4 citric acid (optional for sucker mix)
Things you do need: (For the fizz powder)
-1 tsp. citric acid (not optional for fizz)
-1 tsp. baking soda
-2 tsp. powdered sugar
Other non-food stuff:
-Sucker sticks
-Sucker molds
-awesomeness (optional)
Read the image notes!
Step 2: Step Two...... Setting Up the Molds
Picture of Step Two...... Setting Up the Molds
This part matters about what kind of sucker molds you have.
I put a stick in, put a clip on the mold, put it on foil then spray it with pam.  Your sucker molds should come with instructions.
Step 3: Step Three....... Mixing the Fizzy Stuff
Picture of Step Three....... Mixing the Fizzy Stuff
This part is easy.  All you do is put the 1 tsp. citric acid, the 1 tsp. baking soda and the 2 tsp. powdered sugar.
You can dip your pinkie in the powder and then lick it.  It feels so cool!
Step 4: Step Four.......... Mixing the Sucker Mix
Picture of Step Four.......... Mixing the Sucker Mix
I am reading off the recipe just do what it says.
Combine sugar, water, corn syrup in a small saucepan.  Boil until it reaches 275 degrees then stir in the citric acid (optional) flavoring and food coloring.  Stir intil it cools down to 275 degrees (it will go above 275 degrees when you take it off the stove).  Hurry and look at the next step before the mix cools down to much!
When it heats up to 200 degrees it stays on 200 then goes up all of a sudden.
Step 5: Step Five............ Pouring the First Batch
Picture of Step Five............ Pouring the First Batch
Go over to your molds with the pot full of sucker mix in hand.  Find a mold to start on and pour in a little less then half way.  If you put all the molds in the middle like I did, you can just pour and not spill that much.
Step 6: Step Six........ Putting in the Powder
Picture of Step Six........ Putting in the Powder
This part is fairly easy.  Right before the candy dries, it will be a state of goo where you will get the 1/4 tsp. hemisphere-ish measuring device and put dents in the middle of the sucker.
The sucker should be gooey enough where you can make that dent and it should stay in that shape.  Look at the picture.
Next, put 1/8 tsp. of the fizzy powder in that dent you make and try to keep the powder in the middle.  If you don't, there will be a hole in the side where saliva will get to and use all of the fizzy stuff inside so you won't have fizzy stuff to look forward to when you start licking the sucker.
If you pat down the powder, it should go down into the hole and pack down pretty well.
Step 7: Step Seven...... Make a New Batch
Make a second batch by following step four.
Step 8: Step Eight....... Finishing the Suckers
Picture of Step Eight....... Finishing the Suckers
Get the mix from step seven and fill the remaining space in the molds with the new mix and let it cool.
Step 9: Step Nine........ Removing the Molds
Picture of Step Nine........ Removing the Molds
Ater the suckers have cooled you can finally take the sucker from the mold.  Each mold is different so I won't explain this part.
Step 10: Step Ten................ Voting for Me
Picture of Step Ten................   Voting for Me
You can eat the suckers!
PLEASE VOTE FOR ME
kitzelover (author)2013-04-24
I just tried making Zotz (not on a stick) based on your recipe, and these are my questions:
1. I bought the "sugar free" hard candy package from Loran and it was way too sweet. I have already bought a bag of Truvia to make my second batch, but need to reduce the sweetness of these sugar free products. What can I add to increase bulk without increasing sweetness?
2. I used a hard candy mold, filled halfway up, and let harden a bit, then made an impression and added the powder. Unfortunately, the powder starting fizzing when I added the second layer of melted candy. Anyway to keep the baking soda from fizzing when you "top it off" with more hot candy?
knota (author)kitzelover2013-04-24
Hmm. I have only tried this with sugar and corn syrup. I'm not sure about the first question. But the sugar substitute might set off the citric acid, so you might be out of luck.
ETfonehome (author)2012-06-07
Where did you get all that citric acid??
puppiesrock (author)2010-08-08
is there a way to do this without using molds?
makalove (author)puppiesrock2010-08-12
@puppiesrock, check out scoochmaroo's cough drops instructable. she made her own molds using a pan of powdered sugar. perhaps you could modify that idea. @building king, thanks!! i miss zots!
puppiesrock (author)makalove2010-08-16
oh that looks interesting. ill try it! thanks :)
ETfonehome (author)puppiesrock2012-06-06
Did you and did it work?
QueenQuill (author)puppiesrock2010-09-13
Just buy some molds...they're super cheap...maybe $1 each? At most. Usually you can buy them in sets for a few bucks. Go to your local craft store or baking/restaurant/cooking supply store and pick some up!
knota (author)puppiesrock2010-08-08
You can actually make your own mold if you want to. I made one of the molds I have. Just get aluminum strips and bend it to the shape that you want to. I deleted the reply before this but all it said was you have to use a mold.
puppiesrock (author)knota2010-08-09
oh ok thanks alot!! :p
Dreistein (author)2010-12-04
jalapeno........on a stick
Scurvymcdiggle (author)2010-08-08
i think puppiesrock didn't want to buy a mold which makes perfect sense because buying things is for suckers....yeah...that just happened..you love it. but you could use just about anything for a mold don't buy one purpose crap. might be interesting to see if you could make it out of air dry clay and line it with foil or something then break the clay...because you can just add water and reuse it....i have never made candy myself so i don't know for sure if it would work.
knota (author)Scurvymcdiggle2010-08-09
The molds are cheap though. They are only aluminum strips. I make suckers a bunch so it pays off to just buy them instead of making a million molds just for one batch. (One batch makes a bunch of suckers) You could buy or make them, but if you make suckers alot, buy them.
puppiesrock (author)knota2010-08-10
yea i hadn't made suckers ever so i was gonna try it with home made molds then if i dicide to make them more often i'd buy the molds. i think i will make them more often now though. i liked them. do you know where i could buy some molds? and the clay molds that Scurvymcdiggle mentiond i dont know how well they would work. i think theyd be ok but the foil would make them not as clear and clean. but if its just for family and not for impressing people or anything it would work.
knota (author)puppiesrock2010-08-10
I got the molds from the Gygi store, but I bet you can buy them online. I don't know where you live so I think your best chance is to find the molds online.
QueenQuill (author)knota2010-09-13
Orson Gygi? Do you live in Utah?
knota (author)QueenQuill2010-09-13
Yes!
QueenQuill (author)knota2010-09-14
lol that's awesome! I knew you must, because as far as I know, Orson Gygi is only in Utah. So if I come trick-or-treating at your house on Halloween, will you be giving out zot suckers? lol
puppiesrock (author)knota2010-08-13
ok thank you :)
danm95 (author)2010-08-12
Where do u get citric acid?
QueenQuill (author)danm952010-09-13
You can get it at grocery stores...either in the baking needs section, or if they have stuff for canning (a lot of stores have big canning supplies displays this time of year). If you can't find it at a local grocery store (I've even seen it at Wal-Mart), then try a baking/cooking/restaurant supply store. Also, craft stores that sell things like cake baking supplies also carry citric acid. Good luck in your search!
ktana (author)danm952010-08-15
You can buy it fairly inexpensively at winemaking supply places, even some beer making supply places have it. Or, if you're willing to wait for delivery, you can usually find the lowest prices on ebay. It is used in the manufacture of cheese, specifically mozzarella, so some rural dairy suppliers carry it. It is also used to make fizzy bath bombs so you can often find it in craft stores too, just make sure it is food grade.
Orn310 (author)danm952010-08-12
At your Friendly Local neighborhood drug store!
danm95 (author)Orn3102010-08-13
Oh, ok, thanks. I was thinking chemestry kit when i saw citric acid, and i didn't think of canning supplys! thanks.
knota (author)danm952010-08-12
I get the citric acid from a canning supply-place. They use it for keeping fruit and such fresh.
indiegoober (author)danm952010-08-12
you can maybe use ascorbic acid instead and get it at walmart... it is sold to keep fruit from browning right near the pectin
tireswing (author)2010-08-07
I found Zots again at World Market in Richmond VA in the vintage candy section. OK, I'm now officially old. Where were the lavender pastilles? They did have clove and teaberry gum though. I only wish I had thought of this! I have all the ingredients in my cabinet..... Hmm....perhaps an unexpected "pop" in some gelatin.....Another mad scientist dad fail in the making! Thanks!
QueenQuill (author)tireswing2010-09-13
Lavender Pastilles? I've never heard of them...what are they? Sounds interesting!
scoochmaroo (author)2010-08-07
How is it I've never heard of zots? I love fizzy sour things and I love candy. This one wins a vote from me!
QueenQuill (author)scoochmaroo2010-09-13
You're probably too young to remember Zots!
knota (author)scoochmaroo2010-08-08
I am waiting for the approval of the contest(s). I am in the stuff on a stick and dadcando contest. Please vote for me on both!
Uh, I was going to vote for your entry to "on a stick" contest but I didn't see the entry. You may want to check that..........
knota (author)tireswing2010-08-08
I am waiting for it to be moderated. I published it about two days ago so it should be on the contest pretty soon today. The only rules are that it has to be food.... on a stick. I think mine are food..... on a stick. Also voting hasn't started yet but it will in about two weeks.
yeolddingdong (author)knota2010-08-24
ill buy one!!!!!!!!!!!!!!!
knota (author)yeolddingdong2010-08-25
I would sell them, but I don't know how I would get it to you. If I mailed it, there is a possibility of it getting broken, or moldy, etc. If you find a way I will be happy to sell them to you.
spenfisher12 (author)knota2010-09-07
for the mold plastic wrap for the breaking thing bubble wrap
riku-riku-chan (author)2010-08-23
I can't wait to try this! You have my vote.
DrBlind (author)2010-08-12
Fantastic thanks for sharing, I know suckers can be easy to make but I haven't yet made them. I look forward to making them fizzy! You're Awesome, thanks for taking the time to put this together.
marvay (author)2010-08-12
I also recently found Zotz and Razzles at a local store. Razzles were fun, is it candy or is it gum??? Who knows. But Zotz were the best. I never could wait to get to the middle, so I always crunched it to get that fizz. And for some reason I loved how they came in the strip of 5. I wondered how I could make these at home. This is great! Thanks.
knota (author)marvay2010-08-12
Guess what? I tried to "Crunch" these home made zotz and they are really tough so unless you get a hammer, the only way you can get to the center is by licking it!
skelly7447 (author)2010-08-08
STUFF ON A STICK!!!!!!!!!!
About This Instructable
19,562views
78favorites
License:
More by knota:An iPod Projector - Made From Trash!Drastically Improving the Speed, Life, and Performance of your R/C HelicopterChopstick trainer with only a rubber band! (and chopsticks)
Add instructable to:
