3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Home made turbo Jet
Home made turbo Jet
Hi and welcome, in this instructable we will go through how i made a turbo jet. This is in minimal detail if you would like more detail and photos please visit my website: http://thejetman.webs.com/
VIDEO AT: http://www.youtube.com/watch?v=_t8qsfF32TI
More videos: http://www.youtube.com/watch?v=G_2OUc3sqHk
                    http://www.youtube.com/watch?v=BHHI9QmIrI8
Before we begin as you probably know Propane and LPG are flammable gases so be extremely careful and turbo jets can back fire or explode in certain cases. I am not liable if you or any person or your property are hurt or damaged if you try to build this.
Now for the fun stuff.
Please help me get Likes up on my page on Facebook thanks: http://www.facebook.com/pages/2012-Apocalypse-bomb-shelters-arent-going-to-be-much-good/201889146489535?sk=wall
Step 1
To make something like this you would need a well stocked tool kit which would include:
spanners
a drill to make things easier a drill press
screwdrivers
a welder
an angle grinder
a cut off saw
of course a hammer
a few brains
and maybe a few more things.
The first thing i did was make an oil pump. To make this i used some rectangle shaped pipe, iron plates, hose, welding rods and an oil pump off a Subaru Ute. I welded the pipe to one of the plates, then drilled a hole for the oil pump to fit into( would have been easier to use an oxy). Next  I had to put in the drive shaft to drive the oil pump (make sure the shaft is straight). I then had to seal the tubing using pvc pipe cement.
8 comments
Sep 12, 2011. 5:22 PMChr1spy says:
Yes! :D
Aug 21, 2010. 7:15 PMmr.incredible says:
Great job! Video would be cool. Also Google Sketch-up is great for illustrating things like your drawings. It's real easy to do scale drawings and there are lots of things, like your turbo, that are already created.
My favorite show, no longer running, is Junkyard Wars. There was an episode where they actually created and jet propelled raced cars. One powered with a very similar turbo jet like yours. The other was powered by a pulse jet.
One of the major problems with this type of turbo is they are not designed to handle the heat generated here and will consume themselves quickly. The bearings are the weak link.
Also, even though it is the air intake side, the rubber will quickly get too hot and burn. Try a flexible furnace pipe, or align your fittings better to use a solid pipe.
Instead of drilling all the holes in the inner flame tube, would a tube make of expanded steel mesh work?
Aug 21, 2010. 9:15 AMrredmon says:
so perhaps you could use it for a component of a blast furnace?
Aug 20, 2010. 2:42 PMrredmon says:
what's it for?
Aug 20, 2010. 2:10 PMsageserver says:
video plz...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:brendonl
My name is Brendon and I live on a hobby farm in sunny Australia. My main interests are Gas Turbines (Jet Engines), High Voltage electricity and Computers.
